OME BP-51 versus Fox Level 4
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AgingDisgracefully, Jul 9, 2018.
  1. Jul 10, 2018 at 9:20 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Not to start a debate but I have NEVER heard of that. The consensus seems to be
    King/ADS
    Fox
    OME
    Icon
    Bilstein
    etc
  2. Jul 10, 2018 at 9:27 AM
    AgingDisgracefully
    AgingDisgracefully [OP] Well-Known Member
    Peter
    2016 Tacoma SR5 V6 4X4
    So you are saying that is the quality order? Thanks
  3. Jul 10, 2018 at 9:53 AM
    christyle
    christyle 107
    Chino Hills, CA
    2014 Raptor
    I've never heard of King listed as the top quality... I HAVE heard of their QC issues, noticeable different quality levels between "normal" and "race" stuff and a large fanboy base that skews perception
  4. Jul 10, 2018 at 10:01 AM
    honda50r
    honda50r Not a Mallcrawler
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    stealthmode and JoeCOVA like this.
  5. Jul 10, 2018 at 10:29 AM
    christyle
    christyle 107
    Chino Hills, CA
    2014 Raptor
    I hear a lot of King fanboys, but nothing factually based saying they have good longevity or quality. I'm open to being swayed if you have anything that supports that?
    arnette64 likes this.
  6. Jul 10, 2018 at 11:45 AM
    JoeCOVA
    Joe
    Colorado Springs
    This probably isn’t the thread for that but that argument goes both ways. I’ve never seen anything factual that are bad, just haters who skew perception. See how that works.
    There are hundreds or thousands on this forum with zero issues.
    We can just agree to disagree
  7. Jul 10, 2018 at 11:48 AM
    christyle
    christyle 107
    Chino Hills, CA
    2014 Raptor
  8. Jul 10, 2018 at 11:53 AM
    JoeCOVA
    Joe
    Colorado Springs
    That article is almost 3 years old now. Completely irrelevant as King and fox have redesigns.
    EDIT: that article even says King don’t come with remote reservoir mounts which we know is false.
    It’s alsp wrong about the Viton and Buna seals.
    Again no facts. Weighed, measured, and found wanting.
    EDIT: Viton is a race seal but it’s not the benchmark not standard. They are more common to leak at low pressures and aren’t recommended for most applications.
  9. Jul 10, 2018 at 11:56 AM
    christyle
    christyle 107
    Chino Hills, CA
    2014 Raptor
  10. Jul 10, 2018 at 12:16 PM
    sd1uh8as
    sd1uh8as Well-Known Member
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    Just like any other hobby, we get people defending their purchase. It's nothing personal guys.
  11. Jul 10, 2018 at 12:20 PM
    JoeCOVA
    Joe
    Colorado Springs
    What matters most, is that we are all happy with our purchases.
    No ragerts.
    Most people don’t need racing seals, delta joints, uniballs, but if it makes them happy then by all means.
    christyle likes this.
  12. Jul 10, 2018 at 12:49 PM
    Bigfoot
    Bigfoot Well-Known Member
    Derek
    Sammamish, WA
    2017 DC-LB-OR
    OME BP-51 w/ Med-Duty Dakar leaf pack SCS Ray10s in matte black/gunmetal BFG KO2s in 34x10.5.17
    I'm running the BP-51 kit and love it. I did have the shop adjust the collar since a standard spring compressor won't fit (driver's side adjusted for taco lean..10mm and 12mm, I believe), but once the ride height was adjusted I'm able to dial in rebound and compression depending on the load I'm carrying (camping gear/RRT) or the road/trail/driving conditions (pavement, washboards, trails).
    I won't say it's "top of the line," but I'm not jumping dunes or crawling up rock walls either. I was looking for something above a Bilstein 5100 and not quite as spendy as Kings that would provide a soft cushy ride as close to stock as possible. Apparently the BP-51s also have better corrosion resistance? I can't speak to that just yet.
    I was personally between Fox 2.5s, Icons and the OME BP-51. Ultimately, it came down to customer service and based on what I've read here and the conversations I've had, OME will take care of you. I wanna say the entire kit + dakars + UCAs was around $3k from @HeadStrong Off-Road.
    Just my 2 cents. Happy to answer any questions you have.
  13. Jul 10, 2018 at 1:37 PM
    sd1uh8as
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    How is ride compared to a stock DCLB OR?
    Im personally leaning towards Fox but did consider BP-51s if I am going OME.
    SouthtownTaco likes this.
  14. Jul 10, 2018 at 1:39 PM
    Bigfoot
    Derek
    Sammamish, WA
    2017 DC-LB-OR
    In comparison to stock the ride is a "little" stiffer on pavement, but reaaaaaaaal cushy OR
  15. Jul 10, 2018 at 1:40 PM
    #35
    sd1uh8as
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    More cushy OR? Hmm..
  16. Jul 10, 2018 at 1:48 PM
    #36
    JoeCOVA
    Joe
    Colorado Springs
    This is the point I was trying to make to the OP. Kings are not as expensive at people think.
  17. Jul 10, 2018 at 1:50 PM
    #37
    Bigfoot
    Derek
    Sammamish, WA
    2017 DC-LB-OR
    And you're right. I'm trying to recall and the exact numbers are escaping me. I think the entire king setup with UCAs was going to be like $5-$600 more. Ultimately, I took the advice of a local shop on a kit that plays well with PNW conditions.
  18. Jul 10, 2018 at 2:01 PM
    #38
    JoeCOVA
    Joe
    Colorado Springs
    See this is curious. I’m not sure if you read my post above but I got my king setup for about $500 less than OME with UCA
  19. Jul 10, 2018 at 3:07 PM
    #39
    Bigfoot
    Derek
    Sammamish, WA
    2017 DC-LB-OR
    Yep. I read your post. Where were you seeing it for less? This is what I was able to dig up real quick:
    Headstrong Offroad
    OME BP-51 (front and rears with compression and rebound adjustment, dakar leaf pack, U bolt kit, UCAs)
    $3105.00
    Wheeler's
    Kings (front and rears with compression adjustment, dakar leaf pack, U bolt kit, UCAs)
    $4069.00
    Wheeler's
    Kings (front and rears without compression adjustment, dakar leaf pack, U bolt kit, UCAs)
    $3464.00
    bski22 likes this.
  20. Jul 10, 2018 at 3:23 PM
    #40
    JoeCOVA
    Joe
    Colorado Springs
    That’s why I mentioned “minimum manufacturer advertised price.” Venders can’t advertise cheaper however they can sell cheaper if you contact them.
    You won’t find SPC advertised less than $450 but I paid way less than that.
