OME Camber issue/resolution?
Discussion in 'Suspension' started by tacodavid, Jul 15, 2012.
  1. Jul 15, 2012 at 2:19 PM
    tacodavid
    tacodavid [OP] New Member
    David
    2012 SR5 TRD OffRoad
    I will start this off by stating I am by no means mechanically inclined. I purchased a used 2010 Tacoma TRD Offroad and have been happy with it and simply wanted more height. I got a Toyota dealership installed OME 3 inch suspension lift done last week.
    I'm already regretting getting this done as the rides much poorer than it was before and when taking even minor bumps in the road it feels like its slamming into the dash (if that makes sense). As well the front wheels are angled in towards the bottom (camber?) I've had it back to the dealership once already, spent three hours there and was told everything is fine, and that the camber is at its maximum adjustment and that its normal that the wheels will wear on the outside.
    I've got another appointment with them tomorrow.....is this really the way it is? I see plenty of Tacomas around here with lifts and their tires are straight.
    Thanks for any help
  2. Jul 15, 2012 at 2:22 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Your adjustment for camber and caster may be limited if you are running the stock UCA's
  3. Jul 15, 2012 at 2:23 PM
    tacodavid
    David
    Thanks....and how would I fix that?
  4. Jul 15, 2012 at 2:34 PM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    Check this out. There are several companies that make UCAs.
  5. Jul 15, 2012 at 2:52 PM
    OZ-T
    Peter North
    British Columbia
    As posted above , there are lots of options
    I got the Light Racing UCA's for my own truck as I liked the adjustability as well as the booted ball joint for my winter driving conditions
  6. Mar 8, 2014 at 7:57 PM
    davem311
    davem311 Active Member
    Dave
    Richmond, TX
    2010 4x4. El Taco Blanco.
    3" Pro Comp Lift. Toyo At2 285/70r18. Pro Comp Alloy Rims. TRD Intake. Fogs Anytime Mod. Oil Catch Can. SnugTop Rebel Shell. Weather TEC floor mats. Mirror Mod. Garmin Etrex Hardwire.
    good questions, i just had 3" pro comp installed and same thing with camber. Haven't taken it back to shop yet, will on Monday. Wanted to see if anyone else had same issues.
