OME can be 3”?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by chriskcsa808, Jun 8, 2019.
  1. Jun 8, 2019 at 5:47 PM
    chriskcsa808
    chriskcsa808 [OP] Instagram: 4v6sandtrooper
    Christian
    2016 Quicksand Tacoma TRD
    Anyone here has OME suspension kit installed at 3” front? Just want to ask how do you reach 3” front, it said it can only goes to 2” front? What part should I add to make it 3”? Sorry I’m newbie. I’m thinking to have a lift for first time.
    Hobbs likes this.
  2. Jun 8, 2019 at 6:11 PM
    ANTupLIFE
    ANTupLIFE Well-Known Member
    Anthony
    Chester, VA
    '16 TRD Sport 4x4 DCLB SW
    @HeadStrong Off-Road
  3. Jun 8, 2019 at 6:47 PM
    dc7rr1
    dc7rr1 Well-Known Member
    Danny
    SoCal - Montrose
    ‘18 DC TRD OR 4X4
    I got the 888 and it’s just about 3”
    chriskcsa808[OP] likes this.
  4. Jun 8, 2019 at 6:48 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Which OME kit are you referring to?
    @chriskcsa808
  5. Jun 8, 2019 at 6:51 PM
    chriskcsa808
    Christian
    So the 888 has more lift than 887,886?
  6. Jun 8, 2019 at 6:51 PM
    chriskcsa808
    Christian
    Hobbs[QUOTED] likes this.
  7. Jun 8, 2019 at 7:02 PM
    LostHusker
    LostHusker Just one day at a time
    Mark
    South, TX
    2021 F150, 2015 T4R
    No, 888 is a taller spring then both the 887 and 886, but the 886 is what is needed to maintain lift when you are wanting bumper and winch if you chose this route. The 888 will not support much weight without loosing some height.
    Hobbs likes this.
  8. Jun 8, 2019 at 7:06 PM
    Hobbs
    Yep…
  9. Jun 8, 2019 at 7:11 PM
    sd1uh8as
    sd1uh8as Well-Known Member
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    There's a lot of resources for this already... No need to start another thread
  10. Jun 8, 2019 at 7:22 PM
    chriskcsa808
    Christian
    I cant find the thread about this
  11. Jun 8, 2019 at 7:22 PM
    sd1uh8as
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    Literally look at the post right before mine..wtf
    Hobbs likes this.
  12. Jun 8, 2019 at 7:41 PM
    chriskcsa808
    Christian
    Got mad when someone need help, show respect sir.
    71tattooguy likes this.
  13. Jun 8, 2019 at 7:55 PM
    sd1uh8as
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    I'm not mad at all. If you have an actual question that is not already answered, feel free to ask any of us again.
  14. Jun 8, 2019 at 8:33 PM
    chriskcsa808
    Christian
    Which spring would you recommend if I add steel bumper (115 lbs). But I still want the front at 2.5”+ lift
  15. Jun 8, 2019 at 10:54 PM
    Taconator_
    Taconator_ IG: ohv_tacotruck
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    Kinda answered already.. just saying:notsure:
  16. Jun 9, 2019 at 1:30 AM
    Azza
    Azza ㅤㅤㅤㅤㅤㅤㅤㅤㅤ
    The 886 I got supposedly gave 3 inches. I put the ARB Summit bumper on so I don’t know where it sits now
  17. Jun 9, 2019 at 4:03 AM
    LostHusker
    Mark
    South, TX
    2021 F150, 2015 T4R
    If you are going to put a bumper on you will want the 886 spring.
    So and example, I still have the 888 on my truck, I have added front skid, mid plate skid and rock sliders. This alone made the 888 sag and I was having rubbing issues again with the tires, so for the meantime I added 1/2" puck to bring some of the height back up. Once the bumper arrives I will install the 886 spring as I also have a winch that will be mounted in there, so the front of the truck will be heavy.
    If you go with anything else your going to loose the height in which you are trying to maintain.
  18. Jun 9, 2019 at 4:24 AM
    ahkouchi
    ahkouchi Well-Known Member
    Andrew
    Big Island Hawaii
    2016 Magnetic Gray Metallic Tacoma
    Front Elka 2.5 non resi with 650lb spring Rear Serviceable 5160's with AAL 265/75/r16 BFG KO2
    this thread
