OME coil and 5100 Questions maybe AAL
Discussion in 'Suspension' started by txduckhunter, Jan 19, 2012.
  1. Jan 19, 2012 at 6:39 AM
    txduckhunter
    txduckhunter [OP] Well-Known Member
    centex
    08 Tacoma DC LB SR5 4x4
    2.5" lift, ARE Shell, Ducks Unlimited Rubber Floor Mats. ROGUE badges,
    Hey all, I'm wanting to get the OME 885s and run The bilsteins at .85 to bring up the front.
    I have an 08 DC LB 4x4 and it just has a 3 leaf pack in the back.
    I prefer my trucks to be level or slightly front high and what I'm wondering is if I should just leave the rear stock to make me front high or if I could put on the 1.5" toytec aal that is designed for Tacos with the TSB leaf in order to keep it level.
    Not sure if this is doable or not, just wondering of anybody has done it or thinks it will work.
  2. Jan 19, 2012 at 6:46 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    I wouldn't run the 5100's at .85 with the 885 coils unless they're used and have sagged. They're a tall coil, let them do the lifting, no preloading required. They'll get you to around 2.5" of lift with the 5100's set at 0, if you want to go higher, look into the smaller top plate spacers (1/2" driver side and 1/4" passenger side).
    With that up front and the stock leaf pack in the rear, you'll be pretty nose high. If you don't have a TSB rear, don't get the TSB AAL, get the AAL that's meant for your leaf pack. There's no benefit to using the TSB AAL vs. the non-TSB AAL.
  3. Jan 19, 2012 at 7:16 AM
    Large
    Large Red
    I think you should leave the bils @ 0, and get the TSB done, sounds exactly like you want it.
  4. Jan 19, 2012 at 7:16 AM
    Large
    Large Red
    With the 885s though, can't edit on my phone.
  5. Jan 19, 2012 at 7:35 AM
    txduckhunter
    centex
    My truck is an 08 that I just purchased with 65k.
    I was under the impression that you had to buy new and be under warranty to get the TSB done?
  6. Jan 19, 2012 at 7:42 AM
    Pugga
    Massachusetts
    F-150 Mod
    It's covered in the 3 yr 36k mile warranty.
  7. Jan 19, 2012 at 7:50 AM
    txduckhunter
    centex
    Thats what I thought. Anybody know how nose high I will be riding with this set up?
    I would like to get an AAL but not 2".
  8. Jan 19, 2012 at 7:54 AM
    Pugga
    Massachusetts
    F-150 Mod
    Measure between the center of your hub to the fender as it sits now. The OME coils on 5100's set at 0 will give you about 2.5" of lift up front. Add that to your current measurement and then it's personal preference as to how much higher you want the rear to sit relative to the front.
  9. Jan 19, 2012 at 12:09 PM
    alexander323bc
    alexander323bc Well-Known Member
    Eric
    Buffalo New York
    4cyl access cab
    Pugga did you have the TSB done? I still getting some interference from the dealership.
  10. Jan 19, 2012 at 12:14 PM
    Pugga
    Massachusetts
    F-150 Mod
    I did get the TSB but it was back in 2008.
    Since then I've replaced the suspension again on my own dime because even the TSB leaf packs couldn't keep up. I ended up buying a new/used TSB pack from another member and putting in the Icon 1.5" 3-leaf progressive AAL and couldn't be happier with the results :)
  11. Jan 19, 2012 at 12:24 PM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    Pugga whats your lift height in the front? your back is 1.5?
  12. Jan 19, 2012 at 12:30 PM
    Pugga
    Massachusetts
    F-150 Mod
    Up front I've got 5100's set at 0 with Eibachs so lift is about 1.6". For the rear I'm 2" over TSB height when unloaded. I used the Icon AAL but they tell you to remove the overload leaf (for better flex). I left mine in because I still haul and tow frequently so I ended up gaining an extra 1/2". Unloaded I'd be barracuda style but I did it that way because I have a shell, plywood platform and tools with me all the time to squat it down a bit.
  13. Jan 19, 2012 at 12:33 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I have OME 885's up front with the top plate spacer and 5100's set at 0". In the rear I have 2" AAL's. I sit perfectly level right now. Mine is a SB though.
  14. Jan 29, 2012 at 7:53 AM
    ComaChic
    ComaChic Well-Known Member
    New York...not the city!
    06 DCLB TRD Sport V6
    OME 885's w/ Top spacer kit, OME Nitro 90000 Sport and N182, LR UCA's, 2" AAL non TSB, Window tint, K&N Intake, Lights
    What size tire do you have exactly. 4.5" bs I'm assuming? Minor trim needed? Exact setup I want to use. What spacer do you have just the one 1/4 driver side one or the 3/4 ones like TOYTEC has
    Thanks
