ome coils
Discussion in 'Suspension' started by rab89, Sep 28, 2010.
  1. Sep 28, 2010 at 8:59 PM
    rab89
    rab89 [OP] Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    I'm sourcing some 882's for my 01, but the guy im dealing with said they have changed their part #'s a bit, and not offer a stock/light load spring 0-110 lbs
    and a heavy load coil from 110-220lbs
    Would the heavy load spring be the same as an 882 in your opinion?
  2. Sep 28, 2010 at 9:06 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    hold up what are you lookin for height wise? i put 883s on my d cab with billies i think 881s are suited more towards ext cabs although at about 2.5 inches i believe 882s were for alot of weight up front iirc
  3. Sep 28, 2010 at 9:11 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    well i have billies at 2.5 with stock coils, but they have sagged a lot, from what i hear 881's will sag quite a bit after time, and need to be compressed to lift much, where as the 882's wont sag much because my front end isn't heavy enough. people that have them on the ext cab seem to like them.
  4. Sep 28, 2010 at 9:21 PM
    malander
    max
    01 limited trd 4x4
    i havent seen anyone with the 882s on an extended cab but im pretty sure i saw them on a d cab and the guy said they were a little on the rough side, im pretty sure toytec lists them as the 150+ lbs type coil for heavy bumpers. im pretty sure that ome has figured the whole settling thing out but all springs are gonna settle. id just find someone with them and i guess you have. you could also look into eibachs theyll match up to your billies nicely. somewhere around here when i was looking for my suspension set up i remember that 881s and 882s are the same length but 882s have a much higher spring rate and the 883s have the same spring rate as the 881s but are slightly taller (maybe a .5 inch?) hope that helps, btw love the truck man
  5. Sep 28, 2010 at 9:25 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  6. Sep 28, 2010 at 9:26 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    882's, looks nice huh, member "mixaro"
    he said it rides pretty nice, hmmm
  7. Sep 28, 2010 at 9:29 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
  8. Sep 28, 2010 at 9:30 PM
    malander
    max
    01 limited trd 4x4
    x2 looks great no idea it would work but id go for it man
  9. Sep 28, 2010 at 9:31 PM
    malander
    max
    01 limited trd 4x4
    i think your problems more gonna be in the back with the ome springs idk what you got back there but i hate drivin around with my ass on the ground
  10. Sep 28, 2010 at 9:35 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    I had 5100 at 2.5 and 880's on at the same time before, It was kinda stiff. But once it sagged it was pretty decent. Was going to back them down to 1.75 but got C/O instead.
  11. Sep 28, 2010 at 9:37 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    1.5'' AAL from wheelers.
    Right now my front end is almost 2 inches lower than the front, setting the 5100's back to 0 with 882's should put me about even I'd think..
    oh, and whats the story with the 883's?
  12. Sep 28, 2010 at 9:46 PM
    malander
    max
    01 limited trd 4x4
    883s are just what i came across when i searched around, im kinda surprised cuz i could swear some guy had the 882s and had a pretty harsh ride because of the lack of a heavy bumper but idk i must be smoking crack. idk if you want a level look or slight rake, personally i like a 1" rake. i have a 2" pro comp aal on mine and its about .5 lower in the rear. but then again my leaves were slightly frowning, just no money for a leaf pack.
  13. Sep 28, 2010 at 9:49 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    whats the lift/ weight rating for the 883's?
  14. Sep 28, 2010 at 9:53 PM
    malander
    max
    01 limited trd 4x4
    couldnt tell you the weight rating, but i got a full 3 out of mine, they still have time to settle but i dont expect too much. with these new springs you have to be cautious the way you park. i park on a slight hill that goes from the driver side to passenger side so i get even more of the taco lean, this is of course only when the coils are new and naturally settle. however i would go ahead and get a 1/2 spacer for the driver side and be done with it im still 1/4 inch higher on the pass side but whateva it works. ive never seen an 883 on an ext cab but im sure theyre out there.
  15. Sep 28, 2010 at 10:01 PM
    malander
    max
    01 limited trd 4x4
    damn i was wrong lol once again.... im pretty sure i searched up this threadhttp://www.tacomaworld.com/forum/suspension/65573-ome-882-vs-883-a.html
    i think the 882s are 20mm taller than the 881 so about an inch
  16. Sep 28, 2010 at 10:08 PM
    malander
    max
    01 limited trd 4x4
  17. Nov 1, 2010 at 9:32 PM
    Toyota Tacoma
    Toyota Tacoma Well-Known Member
    Brady
    Kelowna, bc
    dbl cab long box
    Suspension: -Bilistien 5100's all around -Add a leaf -Firestone ride rite air bags Performance: -K&N cold air -Borla cat back Stereo: -Pioneer AVH-X2500BT head unit -Kenwood 1400 shallow mount 12'' sub in custom box -Alpine 1100 amp -Alpine 400 4 channel -4 energy component 6.5's Wheels/tires: -17x9 with 4.5 backspacing XD hoss rims with 33'' bfTreadwright gaurd dogs and spidertrax spacers Looks: -Satoshi grille made by myself -Hood, front bumper, grille, roof, tailgate and rear bumper plasti-dipped. -BHLM -eyelids -matted out tailights -Tacoma bed mat Small mods : -Trailer 7 pin replaced and moved into bumper beside licence plate -Removed mud flaps -Repainted frame/lower a-arms, skid and rear diff/housing with por15 -Led bulbs -Interior lights replaced with blue led's -Beep on lock added
    have you bought some yet ? also where did you get them from? im looking for some new springs in kelowna aswell.
  18. Nov 1, 2010 at 9:37 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    I am waiting until I can afford new tires, the 285's prob wouldn't fit so well right now..
    but best deal around is Craig at bajanorth in Kamloops.
    www.bajanorth.ca
    tell him Ross sent you from TW
  19. Nov 1, 2010 at 10:19 PM
    Toyota Tacoma
    Brady
    Kelowna, bc
    dbl cab long box
    Sounds good, Thanks
  20. Nov 1, 2010 at 10:27 PM
    Leadgolem
    Leadgolem Well-Known Member
    Greg
    Littleton, CO
    98 Tacoma SR5 2.7L 4x4 stick
    Herculiner bed liner, White LED instrument lights, Custom painted hood, Homemade leather steering wheel wrap, Avic u310bt gps stereo, 1.5" bushwacker fender flares, 1.25" bilstein lift front, 1" shackle lift rear, rear bilstein 5100 shocks, ridiculous helper spring lift rear, wet okole seat covers, mutilated exhaust, boom mat under hood
