OME Coils
Discussion in 'Suspension' started by Buckaroo1993, Sep 2, 2017.
  1. Sep 2, 2017 at 7:40 AM
    Buckaroo1993
    Buckaroo1993 [OP] Who?? ME??
    Vinny
    Georgia
    2003 3.4L BSP DCSB TRD OFF-ROAD/SR5 4WD
    17x9 HELO HE878 with Hankook RF10 DYNAPRO AT-M LT275/70R17 RCD/Billie's Front and Rear with OME 883's and HS Progressive AAL Resulting in 3"+ Lift LR SPC UCA'S Diff Drop K&N Cold Air Intake LED's Exterior/Interior
    Trying to understand something. The 881 has 375mm spring height and gives 2" of lift and the 883 has the same spring height but gives 2.75" of lift. Why is that? Does it have something to do with the different spring rates?
  2. Sep 2, 2017 at 7:29 PM
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    I believe the 883 has a stiffer spring rate...
    The OME springs are either longer or stiffer from 881-886 each spring gives more and more height..
    You should be able to find spring rates...
    Stock wheels go softer, more off set and or armor go stiffer...
  3. Sep 2, 2017 at 7:41 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
