OME Complete Dakar worth it?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DannyD57, Apr 23, 2014.
  1. Apr 23, 2014 at 10:12 AM
    DannyD57
    DannyD57 [OP] Member
    DannyD
    Palm Beach/Birmingham
    13' DoubleCab TRD Off-Road 4x4
    3" Lift. N-Fab Step Bars Black Rhino Sidewinder. 285/75/18 Toyo Open Country A/T 2. BakFlip G2 Bedcover
    New to Tacomaworld and trying yo do my homework on a 3inch Lift
    From looking around on here I can tell the OME 3inch is the crowd favorite.
    but my question is, Are the OME Complete Dakar leafs worth $400+ than the Toytec 2inch add-a-leafs? If so, why?
    open to all suggestions, Thanks!
  2. Apr 23, 2014 at 10:21 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Yes
  3. Apr 23, 2014 at 11:20 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I did AAL first and regretted it. Should've done Dakars from the start. Lesson learned, but hopefully I can prevent others from making the same mistake as me.
  4. Apr 23, 2014 at 11:25 AM
    OZ-T
    Peter North
    British Columbia
    I'm going to quantify my answer by saying that if the OP hauls , tows or carrys constant weight , Dakars are a great choice
    If he just wants lift and will usually have an empty bed and never tow or haul , I would suggest a progessive 3 leaf AAL
  5. Apr 23, 2014 at 11:28 AM
    carcharias
    carcharias Giggiddy what what
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Kings all-around w/ 700lb coils, Dakar leaf pack, TC uca's, DO single hoop bumper, BAMF bolt-on sliders w/ kickouts, Rigid 20" e-series spot/flood, aFe pro-dry, BFG KM2 255/85/16, silver TRD FJ wheels, WARN M8000-s, Access LE, Grillcraft, BAMF lightbar, BAMF rear dif skid, BAMF LCA skids, window tint, Wet Okoles, WeatherTech floorliners, Silverstar lights, led dome lights, Redline Tuning hood struts, center console lock mod, mag-lite mod, extra d-rings, re-routed exhaust, ATO skids, ATO Hi-Lift mounts, pipe tailgate lock, seatbelt alarm delete, wheel/spare locks, Viper 5901, LoJack... WISHLIST: a golden canary that poops platinum
    I love my Dakars. Here's my issue: I have newly discovered axle wrap, and the Dakars don't do a thing to counteract it as some suggest other leaf springs would do.
  6. Apr 23, 2014 at 11:57 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    I went with Icon stage 4 but with the Dakar rear leafs. If I could just get the Dakars here, I could get it all installed. Back-order is a bad word.
  7. Apr 23, 2014 at 12:10 PM
    carcharias
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    All tightened to 70lbs per another thread here. My passenger side bolts were loose, while driver's were fine. Tightening still did nothing for the wrap. :(
    Again, still love the Dakars, though. My only point being, don't purchase these if you're also trying to cure axle wrap.
  8. Apr 23, 2014 at 12:11 PM
    PnoyBOS5
    PnoyBOS5 Well-Known Member
    kevin
    CA
    2013 PRERUNNER
    Maxtrac 4'' Spindes -Bilsteins 5100 @ 1.75" - All Pro Expo Leaf Pack - Extended Rear Shocks - PC 5001 wheels - 285/70/17 Goodyear Duratracs - Debadged -Red emblem - AFE Pro Dry-S Filter
    Yes OME .. get a full pack or you'll regret.
  9. Apr 23, 2014 at 12:17 PM
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    yes, i have them. much better over stock
  10. Apr 23, 2014 at 12:31 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    The Dakars do not come with the rear bushings. Order them separate. Reusing the stock ones is an option, but it's a poor option.
    If your truck has ever seen salt, order new spring eye bolts. The spring bushing sleeves love to seize to the bolts, and usually need to be cut off. A sawzall with a quality metal cutting blade will get it done. Have at least 4 blades on hand.
    The bolts are not usually in stock at the dealer. Get them in advance.
  11. Apr 23, 2014 at 12:34 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Keep in mind, with the lift, your driveshaft will be near the end of its optimum travel, and will vibrate at 60ish MPH. A driveshaft spacer will fix it, if you don't wheel. There are shops out there who will properly modify your current driveshaft, to compensate for this.
  12. Apr 23, 2014 at 12:41 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    Another yes.
    I tried the 2" AAL, a 1 1/2" AAL, finally the 3 leaf AAL, did not like any for my truck which had lots of armor and bumpers and gear stored in the bed all the time (heavy)
    Broke down and got the OME Dakars and the world is sunshine and roses now.
    Save your time and effort and get the good stuff right off the bat.
  13. Apr 23, 2014 at 12:42 PM
    SoCal Hillbilly
    SoCal Hillbilly Well-Known Member
    Eric
    San Diego
    2013 DCSB
    Ive got the same issue. Im looking at getting their AAL to try and fix it.
    To the OP I recommend doing the same, save yourself the trouble of doing it later. Not to mention it will increase your payload capacity.
  14. Apr 23, 2014 at 12:44 PM
    OZ-T
    Peter North
    British Columbia
  15. Apr 23, 2014 at 12:59 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    All pro expo's :stirthepot:
  16. Apr 23, 2014 at 1:50 PM
    carcharias
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Please post up or PM me how it works once installed. I thought about that, and there's also cheap helper springs from auto stores, but I'm leaning towards the ATO traction bar over the Bud Built one.
    To the other posts, I have not encountered vibes yet, either.
  17. Apr 23, 2014 at 2:38 PM
    TacoBrah
    TacoBrah Well-Known Member
    Sean
    Icon stage 1, 255/85/16 KM2
    Go to 80lbs.
  18. Apr 23, 2014 at 3:20 PM
    DannyD57
    DannyD
    Thanks for all the input, I really appreciate it.
    I dont haul much, or carry much weight in the bed hardly ever.
    Just want to add aggression to the truck and wan to keep a smooth ride.
    Would a 3 leaf mini pac be a better option than the AAL?
  19. Apr 23, 2014 at 3:33 PM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    The dakars are great. Mine hold up a plate bumper, full size spare, gas tank skid, bed rack for spare, a soft top bed cover. Even with a full load of camping gear and bikes there is almost no sag. I have had 1,000 punds of gravel in the bed with very little sag.
    Here is a photo offroading with the bed loaded for a weekend of camping. There is gas and water, camping gear, bikes on the back. three people in the cab, sliders, skids, rear plate bumper. I had no problems offroading and flexing that weekend.
    Flexing a loaded truck at the top of a mountain
    C2CE4371-FA7A-4D53-A4A2-EA6289FDFDA3-487_aa6f728249cb40c3bc5eef76c0c69e0b335c03c3.jpg
    7BE9A327-9752-4F39-A237-20D4B47EDE0E-487_d19409b1d0c9df02b82f91552f38f1fa4da8246c.jpg
  20. Apr 23, 2014 at 3:35 PM
    samsung
    samsung Well-Known Member
    George
    Sugar Land, Texas
    2011 PreRunner doublecab TRD Offroad
    undercover lid/Ipod integration kit/Pop n lock/bed rug, fumoto drain valve, full piping Wet Okole covers, Blacked out badges, Lamin-X fog light cover yellow, window tint, ARB deluxe bumper with fog light kit,DSM UCA'S,3 support shrockworks sliders,complete OME lift with 886X coil and dakar leaf spring with 3 degree axle shims and center pin lenghtener,warn VR10000 winch,amsteele blue synthetic rope, daystar winch isolator, daystar delrin rollers, IPF 900xs Extreme Driving H9 Kit 900XSD (900XSD),Horn on fire with shot Penning,
    dakkars work really well but they do squeak like hell. if you don't mine the noise it's the way to go.
