OME complete kits
Discussion in 'Suspension' started by nabcracker, Feb 15, 2011.
  1. Feb 15, 2011 at 6:07 AM
    nabcracker
    nabcracker [OP] Member
    Houston TX
    2015 tacoma DCSB OR
    I am looking at an OME complete kit
    http://store.arbusa.com/2-Inch-05tacoma-Stock-Kit-P21031.aspx
    I am not going to do the added spacer for a full three inches. A couple questions, when I price this kit at 4wheelparts, they list a drive shaft spacer. What is this and is it a needed part for a 2 inch lift?
    My biggest question is should I get the heavy duty or light duty shocks? I pull a 7x12 enclosed trailer 1-5 times a year but i may pull it cross country a couple of those times. Should I get the heavy duty shocks or stay light duty. FWIW i dont do any major off roading, but may get into it a little more.
    I did a lot of searching, but could not find much on the heavy duty shock option.
    When I talked to Toytec, they recommended the ULK with added Dakars leafs
  2. Feb 15, 2011 at 8:21 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    The " driveshaft drop" is a CB drop , or carrier bearing drop , this is intended to correct the angle of the driveshaft after you alter the geometry by installing the lift.
    The heavy duty coils are the 886 , they are intended to be used if you add an aftermarket steel bumper ( +/- 100 lbs ) and a winch . If you do not intend on adding that much weight to the front , you will be fine with the 885 springs .
    I am about to install the very same lift ( 885's and Dakars )
  3. Feb 15, 2011 at 8:38 AM
    THExBUSxDRIVER
    THExBUSxDRIVER Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
    About to order mine too just looking for more info. I might go 886 for a bumper in the future so I'll put up with the stiffness
  4. Feb 15, 2011 at 8:42 AM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    Pics of your truck with bumper on man......when ya get a chance
  5. Feb 15, 2011 at 10:10 AM
    nabcracker
    Houston TX
    2015 tacoma DCSB OR
    Thanks OZ. I had planned on the 885s, I think the 4wheel parts site had me confused stating heavy duty gas shocks instead of coils.
