OME dakar cs047r for 2005+
Discussion in 'Deals & Coupons' started by robbytaco, Jun 25, 2014.
  1. Feb 25, 2017 at 4:54 PM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    Thank you so much Tony!
    Lord Helmet and Danactive like this.
  2. Apr 30, 2017 at 11:35 PM
    sig916
    sig916 Well-Known Member
    Do you still offer them at this price? I'm ready to buy them if so. pm me..
  3. May 3, 2017 at 10:12 PM
    kuzo559
    kuzo559 Well-Known Member
    peter
    California
    2006 tacoma trd off road
    None
    So are they still offer this price too am interested
  4. May 3, 2017 at 10:17 PM
    sig916
    Dude never respond... I even pm'd him.
  5. May 3, 2017 at 10:18 PM
    kuzo559
    peter
    California
    None
    Sucks I was very interested thanks
  6. May 3, 2017 at 10:26 PM
    sig916
    My bad I thought this was the other thread. Yes he did respond, Price different though!
  7. May 23, 2017 at 5:34 AM
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    How do you figure? The website says to remove the 3rd leaf (IIRC) to reduce the payload of the dakar by 15% and maintain factory payload. By that logic, wouldn't the Dakars increase payload by 15%? If you install the overload leaf, it gives you an additional 15%.
  8. May 23, 2017 at 6:40 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    No it doesn't.
    Payload is decreased when the leaf is removed, not sure how you figure this. You said it decreases 15% and then maintains factory? In the same sentence.
    Payload isn't increased. Payload has like 10% to do with leaf springs. The axles, the frame.. all have larger parts in determining payload capacity and neither of those are affected by a leaf spring setup.
    Payload can't be increased by adding airbags or stronger leaf springs.
  9. May 23, 2017 at 8:21 AM
    CowboyTaco
    North Georgia
    11 TRD Sport
    I figured that would need to be explained. Let's assume that the Dakar leaf pack increases payload by 15%. By removing the 3rd leaf and reducing the payload capacity of the Dakar pack by 15%, it would then leave you at the same payload capacity as the factory leaf pack.
    Unfortunately, I can't find the links where I found that information when I did the research before deciding to go with the Dakars...that was 2 years ago. I can say from experience that a bed full of dirt used to make my bed look like it was dragging the ground. I don't have that issue anymore.
    Wheelers does mention 15mm on their site, but I know that I've seen 15% in multiple places. I'm almost positive that the arbusa.com website is where I saw that, but I can't find it on there now.
    How do you figure? If you increase the amount of weight that you can put in the bed, you increase the payload capacity. You are correct that all of the other components come into play, but you've undoubtedly heard the expression "a chain is only as strong as its weakest link." In this case, the leaf pack is the weak link. Without the necessary spring rate, you will bottom out your suspension. You will end up riding on the bumpstops and possibly blowing the shock. By adding the aftermarket leaf pack, air bags, whatever else is out there for that purpose, you increase the amount of weight that you can carry in the bed. The axle and frame are capable of handling quite a bit more weight than a measly 1,500lbs like the trucks payload states.
  10. May 23, 2017 at 9:36 AM
    T4RFTMFW
    Not bothering to read any of that.
    Believe whatever you want.
    whatstcp and Lord Helmet like this.
  11. May 25, 2017 at 9:40 AM
    CowboyTaco
    North Georgia
    11 TRD Sport
    I will, and I believe that you don't know what you're talking about.
  12. May 25, 2017 at 6:30 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    3rd Gen Tundra WCP TRD OR I-Force Max
    :popcorn:
    Bubbles likes this.
  13. May 26, 2017 at 9:38 AM
    T4RFTMFW
    You can change how your truck responds to payload - less sag, more control under load, etc.
    You cannot add payload capacity by adding suspension parts. You can add payload capacity by reducing overall vehicle weight - to an extent.
    Payload capacity is a legally defined number and not based on what leaf packs you run, but is based on the vehicle itself.
    whatstcp likes this.
  14. Feb 18, 2020 at 10:19 PM
    Mickey SGV
    Mickey SGV ThinBlueLine
    Greater Los Angeles area, California
    2015 trd sport 4x4
    mid-travel for now....
