OME DAKAR HEAVY DUTY SPRINGS PROBLEM?!?!
Discussion in 'Suspension' started by venisontaco, Jul 8, 2019.
  1. Jul 8, 2019 at 9:41 PM
    venisontaco
    venisontaco [OP] Well-Known Member
    I'm curious what you'll think of this. I just installed Bilstein 6112 in the front on the 3rd clip and OME Dakar heavy duty springs with Bilstein 5100 in the rear. The ride quality seems good, however when I loaded the bed with 650 pounds it had a "W" in the springs. Even 350 pounds there's a slight "W". It maintained height, but my understanding is the springs need an arc to work properly. Correct? I've read in a few threads this is common with ome. What do you guys think? Is it ok or no good?
    I'm getting a Vagabond Drifter 8ish months and after doing a bit of research it's seems those guys run Deaver Stage 3 or Alcan.
    Thanks in advance for your help!
    Running Board Man likes this.
  2. Jul 9, 2019 at 4:51 AM
    JFoffshore
    JFoffshore Well-Known Member
    2011 Toyota tacoma TRD 4x4
    None yet
    My HD springs are about a month old and the same way. They ride great though....
  3. Jul 9, 2019 at 4:57 AM
    doorsidedown
    doorsidedown Well-Known Member
    normal. Might want to remove “HELP!!!” from the thread title. I thought you were broke down somewhere.
    Mully, Running Board Man and tcjacado like this.
  4. Jul 9, 2019 at 10:46 AM
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    Looks to me like those springs are losing or have already lost arc and therefore, lift. How much weight is on in that picture or are they unloaded there? The top five leaves are going to have to flatten out and bend downward before the first helper leaf comes into play. Then they all have to bend down further before the last helper leaf comes on. I didn't see in the specs how much the drifter camper weighs. I would get that number and load on that amount of weight ( sand bags or similar) plus anticipated gear weight and see how it looks. The air bag crowd will be chiming in soon, but you will be overloaded (GVWR wise) I suspect.
  5. Jul 9, 2019 at 12:09 PM
    venisontaco
    @Troyken
    The picture of the springs is with 650 pounds of concrete. The truck pic is with 350 of concrete. The drifter weighs about 320, so with gear I would guess 650+. I'm waiting to hear back from OME... I may consider aal or If I can return and get Deaver Stage 3.
  6. Jul 9, 2019 at 12:45 PM
    Troyken
    NY
    If you add another 600 lbs or so to the expected 650 lbs cargo, you will be approaching GVWR. I have tested my truck using a combination of garbage cans and totes,filled with water, with no occupants in cab,( in the driveway only) to get to 1250 lbs, about my payload max. That put me on the bump stops with stock suspension. You might try that and see how the OME springs support the weight. With driver, passengers and gear you will be very close to GVWR. Maybe Headstrong off road can advise you on the AAL. I thought the HD leaf pack already had the extra add a leaf but I might be wrong on that. If you plan to "overland" with this setup you might bottom out often and eventually break or bend a spring.
  7. Jul 9, 2019 at 1:07 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    I'd be interested in hearing what OME has to say if you can send them that pic of them looking like a W.
    I am running the Deaver Stage 3 and they definitely don't look like that. My Habitat is similar in weight, around 340 lbs. I've also got another 300+ lbs in the bed at all times between my batteries, fridge, chargers, propane, MaxTrax, etc etc...
    PvilleJohn and venisontaco[OP] like this.
  8. Jul 9, 2019 at 1:11 PM
    motodude95
    motodude95 Well-Known Member
    Jim
    2012 MGM TRD Sport DCLB, OME 886s, 33s
    I think that's normal man. My stock leafs look like that with no weight in the truck at all.
  9. Jul 9, 2019 at 1:11 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
  10. Jul 9, 2019 at 1:12 PM
    ResearchMonkee
    ResearchMonkee Techn9cian
    Derrick
    KCMO
    2011 Barcelona Red DCSB Sport
    Your thread title sucks.
    venisontaco[OP] likes this.
  11. Jul 9, 2019 at 1:15 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Normal.
  12. Jul 9, 2019 at 1:52 PM
    venisontaco
    Sorry for "help" in the title. I didn't know it was for actually emergencies.
    doorsidedown and YF_Ryan like this.
  13. Jul 9, 2019 at 1:58 PM
    venisontaco
    @YF_Ryan Thanks for your input! I just want to do it right and make sure they work correctly. I'm waiting for a response from OME on the issue and will let you'll know what they say.
  14. Jul 9, 2019 at 5:28 PM
    doorsidedown
    Mine is the HD pack OP - here’s a quick pic
    That’s completely unloaded. I have the extra Dakar AAL in the garage I’m about to install due to a rear bumper going on soon.
  15. Jul 9, 2019 at 6:18 PM
    Troyken
    NY
    Wow, how old are they? Less than four years I'm guessing? You have extended bump stops so you must be hitting them often with very little load?
  16. Jul 10, 2019 at 5:09 AM
    doorsidedown
    It’s about a year old. Honestly, there’s plenty of lift, 3.5” over stock or so, and looking at the contact point on the frame, I’ve rarely hit the bumps. They ride great, just that W shape has been there since i installed them.
  17. Jul 10, 2019 at 5:27 AM
    Troyken
    NY
    Hmm.... I guess we will have to wait for OME feedback. They sure look weird but maybe that is how they are intended to work. Good luck with them.
    doorsidedown likes this.
  18. Jul 11, 2019 at 1:59 PM
    venisontaco
    Here's what I got from Wheelers Offroad who talked to ARB and here's what I got from ARB direct. They both said it's good.
    Hamer95USA likes this.
  19. Jul 11, 2019 at 2:21 PM
    TVH475
    TVH475 Well-Known Member
    Montrose CO
    Sweet! That's how mine look too!
  20. Nov 1, 2022 at 12:43 PM
    Idmtdew
    Idmtdew Idmtdew
    1995 Tacoma
    ToyTec Ultimate lift with Bilstein Front Coilovers and Shocks. Total Chaos upper control arm. ToyTec 1.5" rear block with add-a-leaf. 17x8.5" Method NV wheels and 285/70R17 Cooper ST Maxx Tires.
    What bump stops are you using with your OME Dakar lift? Also, did you go with the heavy duty pack or what? I have the heavy duty pack and carry a 1200lb Phoenix popup camper on my 2021 long bed. When I have the camper on my springs look like that. Without the camper on, the back is about 2-3" higher than the front. It is definitely noticeable there is no load.
