OME Dakar heavy leaf springs what shocks 5100?
Discussion in 'Suspension' started by Jwthefixer, Jul 31, 2018.
What is a good shock for 2.5" rear lift? 5100 bilsteins or OME?
  1. Bilstein
    21 vote(s)
    67.7%
  2. OME
    10 vote(s)
    32.3%
  1. Aug 3, 2018 at 8:15 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    A waterproof marine grease is ideal. Just not petroleum based.
  2. Aug 3, 2018 at 8:16 PM
    Jwthefixer
    Jwthefixer [OP] Member
    2018 tacoma trd off road
    Lift kit, rims & tires, seat covers, led lights in & out, snugtop shell, lightbar, foglights,bed stiffners,rear step, roof rack & rock sliders.
    Thanks. That's what I was thinking.
  3. Aug 3, 2018 at 8:26 PM
    BroID
    BroID Well-Known Member
    The Gem State
    2017 Tacoma TRD off road
    BFG KM2 255/85r16 Bilstein 5100s OME 888, HD Dakar’s, JBA control arms, BAMF Shackle hangers and shackle.
    I used whatever came in the kit from headstrong. Was real liberal in applying it. It lasted one trip out into canyonlands, it snowed, rained, highs lows temp. After that I have very squeaky leafs. There are places to lube the leafs with a needle grease gun fitting that helps with some squeaks. But my squeak that’s the worst are the pins for the leafs towards the front. I ordered Dobinson greasable pins and am hoping this helps. Also do not tighten you leaf springs onto the truck fully until it’s sitting on the ground. So on the jack stands tighten them enough to hold, sit the truck on the ground and then torque to spec the leaf springs to the truck. This will help the bushings not get twisted up and give you problems. I’m referring to leafs to truck. Not leafs to axle. Please correct me if I’m wrong.
  4. Aug 3, 2018 at 8:37 PM
    Jwthefixer
    Good information . Don't want squeaky springs. Thanks
  5. Aug 4, 2018 at 9:35 PM
    Jwthefixer
    Install complete.
    EatSleepTacos likes this.
  6. Aug 4, 2018 at 11:08 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Everything go well?
  7. Aug 5, 2018 at 10:32 AM
    Jwthefixer
    Fit good. Took all day. But worth it. No more saggy ass.
  8. Aug 5, 2018 at 6:51 PM
    Nomad_Pilot
    Nomad_Pilot I need to pewp
    Clay
    Ft Collins
    Yes, I was told it has an internal hydraulic extension damper instead of a rubber one.
  9. Aug 8, 2018 at 4:08 AM
    lynyrd3
    Bill
    East Central Upstate NY
    Energy Suspension grease . My Dakar install is today !
  10. Aug 8, 2018 at 4:12 AM
    lynyrd3
    Bill
    I already have 5125s installed with extended brake lines . I hear the bottom of the 5125 needs a little persuasion getting into the saddle with the Dakar’s installed !
  11. Aug 8, 2018 at 12:31 PM
    Jwthefixer
    You have to grind metal insert and trim bushing on shock.
  12. Aug 9, 2018 at 2:21 AM
    lynyrd3
    Bill
    Shocks were not an issue for the installer . Everything went into place fine !
  13. Jun 16, 2019 at 1:11 PM
    K2R1D3R
    K2R1D3R Well-Known Member
    Mark
    Nor-Cal
    2012 TRD Off Road
    Sooo are extended lines needed for the 5125s?
  14. Oct 9, 2019 at 8:46 PM
    Chucoma
    Chucoma Member
    Chade
    2007 Toyota Tacoma pre runner
    Camburg UCA, grill light bar, Fox 2.5 coil overs, Fox 2.0 rear, spider headlights, method nv 17”
    I have fox 2.0 980 24 670 and they are limited to 21.95 inches extended, do i need new shocks when i get dakar ome leafs or will my shocks work
  15. Oct 10, 2019 at 2:06 AM
    #35
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I’d say yes, that’s pretty darn short
  16. Oct 10, 2019 at 6:15 AM
    #36
    Chucoma
    Chucoma Member
    Chade
    Any recommendations, I have Fox 2.5 ifp upfront
  17. Nov 16, 2019 at 8:24 PM
    #37
    snowhead52
    snowhead52 Well-Known Member
    2016 Grey Tacoma SR5 4x4
    Go Rhino Dominator side steps, OEM black bumper ends and black grill trim, Wet Okole seat covers, Decked drawer system, Snugtop Rebel AVS hood deflector, Baja Rack (Cab), Yakima Snugtop crossbars.
    Just picked up Bilstein 6112 w/OME 888 and Bilstein 5100 extended w/Dakar HD leaf pack. Nothing on the front, 400lb constant load in the back. Anxious to get it installed. Hope it works out ok, I keep reading about nightmarish experiences with lifts, this is my first lift and tacoma.
    Bilstein 6112 w/888: 6/5 notch setting
    I guess worse case scenario:
    Bro lean - get aftermarket bumper or 5/4
    Too much rake - remove 3rd leaf
    Squeaky - live with it
    Vibration - ECGS bushing
    I think I’ve been reading too much TWand getting paranoid.
    Greg.Brakes.Tacos likes this.
  18. Nov 17, 2019 at 6:39 AM
    #38
    arrowhead
    arrowhead Well-Known Member
    I know this is not listed as an option but I went with 12" kings with the BAMF relocation brackets and extended brake lines. I had 24-186728-P - Rear Bilsteins 5100, then I installed the HD-Dakar pack. That set-up turned my shocks into limit straps going over speed bumps. Which was not ideal. What's cool about the 12-inch kings and BAMF kit is if you can find a good cheap welder the whole thing installed is about the same price as the vehicle-specific king shock but with way more travel.
  19. Apr 17, 2020 at 9:58 AM
    #39
    This_taco_obsession
    This_taco_obsession Well-Known Member
    Dan
    Virginia Beach
    HS coils w/5100’s, MD Dakar’s w/B110’s
    :confused: wish they made those kits for the ex-wife....
  20. Jul 10, 2020 at 7:55 AM
    #40
    crackils
    crackils Sith Lord Jar Jar
    Shane
    FL
    2012 TRD DCSB Off-Road - KINGS/5125s AF
    I know this was a while ago, but just want a clear answer if anyone knows. Do the 5160's require the ext. break lines? I thought they had their own extension brackets?
