OME Dakar Leaf Pack - need advice....
Discussion in 'Suspension' started by ACE_Taco, Apr 27, 2010.
  1. Apr 27, 2010 at 6:11 AM
    ACE_Taco
    ACE_Taco [OP] Long Range Practical Marksman
    NC
    08 DBLCab TRD 4x4
    OME 885x Coils, Dakar Leafs, OME Shocks, TC UCAs, BHLM, Tailgate MOD, WeatherTec Window Deflectors, WeatherTec Floor Mats, Blacked Out chrome bumber, Satoshi Grille, Wet Okole Seat Covers
    I just purchased a Dakar leafpack for the Tacoma DC SB. Right now, I have OME 885s/9000 on the front & TSB packs on the rear. I am almost 3/4" high in the front now that my leafpacks have settled.
    My questions are should I remove a leaf from the Dakars? I do not want to be 1.5" high in the rear. I am looking to be around 3/4" high in the rear after they settle. How much do the Dakars settle?? If I do not remove a leaf now, do I have to completely remove the packs later to just remove a leaf?
    Please ONLY reply if you have owned or installed Dakars.....
    Thanks
  2. Apr 27, 2010 at 6:46 AM
    goride
    goride Well-Known Member
    Josh
    UTAH
    09 trd sport dbl cab lb
    Tinted windows,Upgraded stereo system,satoshi grill with piaa lights behind,dash light color mod to blue,mag light holder,OME dakar leafs,Toytec ultimate lift,LR uca's, BFG AT's 285/70/17 on Pro Comp 7089s,weather techs, leer shell,CBI sliders and rear bumper w/tire gate,soon DTLT w/ wicked flow catback exhaust
    I have the dakars and just added the xtra leaf to make them heavy duty and yes I believe that you do have to take them totally apart, I had to to add a leaf you might be able to leave them on and loosen and lower things and slid the 3rd leaf out.I dont know how much they settle but by removing the 3rd leaf you will loose a little hauling weight and around 1/2 to 5/8 in of lift.If you plan on hauling anything I would leave them in, drive around for a couple of weeks and see if they settle enough. Good luck
  3. Apr 27, 2010 at 6:56 AM
    ACE_Taco
    NC
    08 DBLCab TRD 4x4
    Thanks. Also, do you guys know if the center pins are long enough to accomodate 3* axle shims, if needed?
  4. Apr 27, 2010 at 7:19 AM
    goride
    Josh
    UTAH
    What silverback07 said.
  5. Apr 27, 2010 at 9:31 AM
    ACE_Taco
    NC
    08 DBLCab TRD 4x4
    For U-Bolts, do I need the 7.5" or 8.5"?? I want to be able to use axle shims if needed.
  6. Apr 30, 2010 at 9:27 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
