OME Dakar Leaf Springs - passenger sitting on overload spring???
Discussion in 'Suspension' started by toycar18, Jun 28, 2010.
  1. Jun 28, 2010 at 3:13 PM
    toycar18
    toycar18 [OP] Well-Known Member
    Colorado
    98 Reg Cab 2.7L
    OME Suspension, BFG 33x10.50 AT, Light Racing Upper Control Arms, Rear ARB Air Locker, LCE Header, Dynomax Super Turbo Muffler, K&N Intake
    I have a 1st Gen Tacoma. Just installed an OME suspension - rides great.
    Anyways, the passenger side leaf spring is sitting on 1st overload spring. The drivers side looks fine. Is this normal? Or a bad leaf spring. I would think it should not be on the 1st overload spring....Anyone? The passenger side is also about 1/2" lower. I also thinks it has too much lean...
    Anyone?
    Also it seemed to be level before I loaded the truck with camping gear (approx 500 lbs). These pics are with the truck unloaded.
    THANKS
  2. Jun 28, 2010 at 3:22 PM
    SaltySteve
    SaltySteve Well-Known Member
    Denver
    2012 4runner
  3. Jun 28, 2010 at 3:49 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Kind of looks like the passenger side overload spring in question was installed in the leaf pack upside down.
    Gen1 leafs are side specific; are they installed correctly?
  4. Jun 28, 2010 at 3:57 PM
    toycar18
    Colorado
    98 Reg Cab 2.7L
    Yes they are installed correctly...leaf A is drivers and leaf B is passenger
    Unless the overload was installed upside by the manufacturer
  5. Jun 28, 2010 at 4:30 PM
    toycar18
    Colorado
    98 Reg Cab 2.7L
    It does look like the 1st overload is arched the wrong direction.... Anyone else have this problem? Or is it defective???
    PASSENGER
    PASSENGER
    DRIVERS...looks normal
  6. Jun 28, 2010 at 5:32 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    I was going to say the same thing. Looks like the passanger spring is installed upside down.
  7. Jun 28, 2010 at 5:38 PM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    No no no, you've got it all wrong! His exhaust has super heated the spring and f*d it up!
  8. Jun 28, 2010 at 5:45 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    looks to me like its installed 180 degrees of what it should be
  9. Jun 28, 2010 at 6:44 PM
    toycar18
    Colorado
    98 Reg Cab 2.7L
    Thanks for your thoughtful insight
  10. Jun 28, 2010 at 6:45 PM
    DWreck
    Derek
    Las Vegas, NV
    No prob! Glad to help!
  11. Jun 28, 2010 at 6:53 PM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    another vote for the upsidedown install of the overload spring...just an assembly error...it does happen!
  12. Jun 28, 2010 at 7:34 PM
    toycar18
    Colorado
    98 Reg Cab 2.7L
    So can the leaf be disassembled and the overload spring flipped? Or does it have to be replaced?
    If it is disassembled and flipped what about the 1/2" lean? The truck was level until I put 500lbs of camping gear in it.
    Would that be enough weight to damage the leaf spring with the overload being installed improperly?
    BTW, the suspension is 1 week old - about 350 miles. The quality of ride is amazing.
  13. Jun 28, 2010 at 7:48 PM
    yosh2000
    CO
    '17 Tundra CM 5.7
    yep, easily flipped, just a center pin holding them together. i purchased a used set of dakars for my 05, took them all apart and cleaned them up, and reassembled...very easy to do.
    will it fix the 1/2" lean...dont know. but i do know you do not want to load up the leaf w/ the overload like that. nothing may happen, but leafs are designed to work together, and that overload being installed like that is definitely working against the rest!
  14. Jun 30, 2010 at 8:19 PM
    toycar18
    Colorado
    98 Reg Cab 2.7L
    Contacted ARB.
    Overload was installed wrong at the factory.
    I don't know if they are going to send me a new leaf or what. I think they expect me to flip it myself but I shouldn't have to pay someone for there mistake. I have a feeling that I'm going to have to fight them on this.
    The ride is great - too bad quality control missed it.
  15. Jun 30, 2010 at 8:32 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    I'd just flip it myself. ARB isn't a small company that relies on word of mouth to stay in business.
    Besides, it's nice to get to know your truck.
  16. Jun 6, 2013 at 10:05 AM
    Justin
    Justin Well-Known Member
    Justin
    Colorado Springs
    2018 4Runner TRD-OR
    285/75/17 on SCS 6's. ADS front & rear w/ adjusters. Relentless front bumper & roof rack. BAMF sliders
    What is the dakar overload leaf?
