OME Dakar vs. All Pro vs. Deaver vs. Alcan
Discussion in 'Suspension' started by TXTaco13, Jul 30, 2015.
Which leaf pack offers the best all around performance?
  1. OME Dakar
    111 vote(s)
    43.2%
  2. Deaver
    94 vote(s)
    36.6%
  3. All Pro
    34 vote(s)
    13.2%
  4. Alcan
    18 vote(s)
    7.0%
  1. Feb 10, 2018 at 11:14 PM
    #61
    YotaLife
    YotaLife Well-Known Member
    Cory
    Seattle
    11 DCLB Sport
    King 2.5 w 700lb coils, bamf rear mount and sliders, alcan rear springs, 12 inch king smoothies, allpro front bumper, allpro uca, 34x10.50 bfg at ko2, total chaos gussets
    Ya, spring under... The springs mount on the underside of the axle instead of on top. The shape of tacoma frame just doesnt allow for very much up travel without a lot of lift. Which is fine for soft springs (like i have) and slow speeds because theres a ton of droop. But any high speed or medium speed bumps or whoops and your banging the bumpstop on the frame the whole time.
    DMZ makes a pretty cool kit Id go with if I ever redo the rear
    http://dmzfab.com/product/05-tacoma-spring-under-conversion-kit-standard-bed/
  2. Feb 16, 2018 at 11:40 AM
    #62
    TacoMesa
    TacoMesa Active Member
    2017 Metallic Grey Tacoma TRD Off Road
    Looking into a leaf pack for my DCLB OR. Have an A.R.E shell and have built out a sleeping platform in the back out of 3/4 inch ply thats making the rear sag a bit. Seems like a lot of people like the OME HD Dakars. I'll be having weight in the bed 100% of the time with my sleeping/storage setup and am wondering what you guys recommend. Total noob when it comes to suspension mods. I'd like to try and keep the feel stock, but would also like a couple inches of lift to eventually get some bigger tires and have a little more clearance when off roading. Thoughts?
  3. Apr 23, 2018 at 12:22 PM
    #63
    ZrowGz
    ZrowGz I'm a n00b.
    SLC, UT
    97 4x4 LT/Cantilever
    I'm looking into redoing the rear. Well, the whole truck with a frame swap from my 97 to a 98 DC frame. I'm getting ADS suspension all around and am debating extended or long travel up front. These rear ends can't get more than about 10" of travel without bigger mods, so I'm just looking to get a standard aftermarket leaf pack.
    I'll have around 400 extra pounds in/on the bed at all times and will increase that for trips with at least another 200-300 pounds of gear.
    Dakar seems like a nice bet since it's affordable and sturdy.
    Deaver seems like it's better match the performance suspension but it'll be like 10 thin leafs thick to hold weight like that.
    Looked breifly at the expedition pack but it isn't super intriguing since I haven't found as many great things said about it.
    Will I be pleased with the Dakar or should I "spring" for the deaver?
    Arctic Taco and TinMan2209 like this.
  4. May 15, 2019 at 1:11 PM
    #64
    rag9836
    rag9836 Well-Known Member
    Robert
    Riverside, CA
    14 Pre Runner SR5 TRD
    Bilstein 6112 & 5160's, SPC UCAs, TRD Pro grill, Cali Raised ditch lights, Pro Runner Cab Roof Rack, Demello Stealth Rock Sliders, SS brakes lines, Power Stop brake kit
    If I am running no additional weight.,, Deaver or Dakar? 6112’s and 5160’s in rear.
    Piffcentral likes this.
  5. Jun 3, 2020 at 12:21 PM
    #65
    Piffcentral
    Piffcentral Well-Known Member
    Garner, NC
    2014 TRD Sport DCLB
    I'm in the same situation, trying to make the same decision.
  6. Jun 3, 2020 at 12:23 PM
    #66
    rag9836
    Robert
    Riverside, CA
    I went with a spacer in the rear....least impact on ride quality.
    Rides great. 6112's and 5160's.
  7. Jun 3, 2020 at 12:26 PM
    #67
    Piffcentral
    Garner, NC
    2014 TRD Sport DCLB
    thats what I have now actually...factory leafs with spacers but occassionally I haul a dirt bike on a tow hitch carrier, and even my camping gear weighs 2-300 lb. Wondering if I should pull the trigger on the dakars, I;m kinda leaning that way but then struggling to decide between medium and heavy versions
    austinblock likes this.
  8. Jun 3, 2020 at 12:40 PM
    #68
    rag9836
    Robert
    Riverside, CA
    You'll get a stiffer ride when you are not hauling anything...unless it's bad with spacers I would leave as is.
  9. Jun 3, 2020 at 12:49 PM
    #69
    Piffcentral
    Garner, NC
    2014 TRD Sport DCLB
    Noted, thanks
  10. Jun 3, 2020 at 5:38 PM
    #70
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
  11. Jun 3, 2020 at 5:57 PM
    #71
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    If your dead set on dakar, go with the HD for that amount of weight.
    Piffcentral[QUOTED] likes this.
  12. Jun 8, 2020 at 6:26 AM
    #72
    Piffcentral
    Garner, NC
    2014 TRD Sport DCLB
    What if I'm not set on Dakar though? What would you recommend
  13. Jun 8, 2020 at 7:47 AM
    #73
    Littles
    Bryan
    Elizabeth, CO
    3 tons of fun
    I think there are better options...any of the other three.
    I only have experience with the old dakar and dakar HD before I went to a custom alcan pack but I am extremely heavy now. Dakar is in my mind the budget lift option if you're not planning on running more than 600lbs and arent expecting more than 2 years out of them. I just don't think they last and have heard enough anecdotal stories about sagging leaves in the past year that I am convinced their quality has taken a shit.
    If you were my friend, I would try to talk you out of them.
  14. Jun 10, 2020 at 8:18 AM
    #74
    Arctic Taco
    Arctic Taco Firefly, Serenity Ed. -Arctic Taco, a slow build
    Denali Park, Alaska
    98 Tacoma Xtra Cab DLX, 85 Toyota LWB 4x4
    dents and missing bits, built in the Gravel garage, hillbilly trained mechanic…
    The Dakar HD Exp w/AAL set up is a decent pack, they ride nice once they settle in, and have decent flex.
    I generally haul about the same weight and have for 4-5 yrs now, they will slowly flatten out as it seems to be hard to marry flex and lift without one or the other suffering. That said, as I also have 883 coils up front my truck stays basically level until I hook up a trailer and have weight on board as well.
    I am planning to order a Vagabond Drifter next fall, and will be adding an Icon progressive AAL -going to go with some longer u bolts and try keeping the overloads to see how that works for rake and towing this next summer. Figure to keep that setup for awhile after the drifter installation and rear swing out bumper to see how everything looks and feels, then if necessary I will likely go custom AlCan or get a custom set made at a spring shop in Anchorage.
    Of course the rake will improve when I get a winch, but that’s another next year addition.
    Long story short, it seems like the Deaver pack might be a good one if you are looking at flex,and ma6be still give you the lift you are looking for. My 49 CJ2A had about 8 skinny leaves in the front and 9 in the rear pack when I was done With it and it flexed like crazy, gained a little lift but not much and I wasn’t interested in lifting it anyway, just wanted to get out in the woods, worked great for that. Skinny leaves aren’t a bad thing, just seem to be bette4 for flexing, to get lift you just get more leaves or stiffer ones and lose some flex.
    Good luck.
  15. Jun 10, 2020 at 8:35 AM
    #75
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    Question. I have the heavy pack on my truck. With shell and Rtt plus fridge my rear sat down a little more than I wanted. I was just going to throw the aal in there but I’m finding different numbers but non say which pack they go to. Anyone know if the d29xl is for second gen or first ?
  16. Jun 10, 2020 at 9:39 AM
    #76
    Littles
    Bryan
    Elizabeth, CO
    3 tons of fun
    IIRC the d29xl is the AAL for the older cr047 leaf pack for the 2nd gen. Not sure if it fits the newer design.
  17. Jun 10, 2020 at 11:17 AM
    #77
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    I’ve got the el096R so should be the older one right
  18. Jun 10, 2020 at 12:55 PM
    #78
    Littles
    Bryan
    Elizabeth, CO
    3 tons of fun
    Newlife[QUOTED] likes this.
  19. Jun 10, 2020 at 2:38 PM
    #79
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    Littles[QUOTED] likes this.
  20. Jun 10, 2020 at 2:52 PM
    #80
    ISU800m
    ISU800m "Worst case Ontario"
    Kyle
    Plymouth, MA
    2018 Silver TRD OR
    Will Eibach Pros work with the dakars?
