OME Dakars vs All- Pro Expedition Leafs
Discussion in 'Suspension' started by RubberTank, Aug 29, 2012.
  1. Aug 29, 2012 at 11:13 PM
    RubberTank
    RubberTank [OP] Well-Known Member
    Thousand oaks, CA
    So long story short, with my extended warranty and obvious need of new leaf springs I was not able to get the leaf TSB done... well Toyota said they would do it for 2000$... :eek:
    So anyways Im jut going the aftermarket route, so I've narrowed it down the to OME Dakars or the All Pro Expeditions, I have 5100's with eibachs set at 0 in front. I'm not too concerned about the rear lift height, I also have the stock length 5100's, so my questions is. 1) Which leafs do you prefer? 2) would I have to get new rear shocks for both leaf packs or just the all pros cause they are 3"?
  2. Aug 29, 2012 at 11:20 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    You will get 2 1/2 - 3" from the Daks , more from the Expos
    I'm happy with my Dakars , can't comment on the Expos as I have no experience with them
  3. Aug 30, 2012 at 8:38 AM
    eric3187
    eric3187 Well-Known Member
    i believe the expos will yeild 3" lift when loaded with 3-400 pounds, and 4" if unloaded.
  4. Aug 30, 2012 at 8:51 AM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    Don't the Dakars have a notorious squeek?
  5. Aug 30, 2012 at 11:13 AM
    OZ-T
    Peter North
    British Columbia
    all leaf packs are prone to squeaks over time
  6. Aug 30, 2012 at 12:10 PM
    TRD6Speed
    TRD6Speed senior member
    Bill
    East Hartford, CT
    08 TRD Sport Access Cab
    885x with 5100s and top plate spacer for full 3", RCD extended 5100s in rear, dakars, flip kit, LR UCAs, tint, shorty antenna, in channel rain guards,BHLM, blacked out emblem, OEM side steps, weathertechs, debadged, rear diff breather
    Im debating myself on this right now....not buying very soon but not sure which pack I want to go with. I think if you want rake or dont mind it then the expos would give you more of it.
    IMO if you are on eibachs and 5100s I would get the dakars. Your ass will be very high i think and look weird if you go with the expos. I have 5100s and 885s plus im gonna get a 1/4" spacer for the passesnger and 1/2" for the driver so I'll be pushing 3" up front as opposed to your 1.6ish? correct me if Im wrong.
    Thats why I am considering the expos to keep a factory rake look as opposed to a more level look with dakars. I just dont know if I want a more level look or more rake.
  7. Aug 30, 2012 at 12:23 PM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    I have 885s & Dakars & got 3" front & rear with a shell so I maintianed stock rake.
  8. Aug 30, 2012 at 12:40 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You will need new shocks with either leaf pack and both would likely make your truck look funny because of the short lift up front and the tall lift in the rear. Wheeler's sells a 2" replacement leaf pack that might be more friendly to your stock height shocks although I don't know much about them besides they're made by Deaver. Alcan can make you a set of springs to any specification you want (lift height, capacity, etc). It's a bit more than an aftermarket replacement but you could retain your stock shocks and get a better leaf pack also.
    Depending on how much you tow or haul, you might not necessarily need a replacement leaf pack. I'm running 5100's at 0 and Eibachs up front and the Icon progressive AAL in the rear and the overload in place (with a TSB leaf pack). It's been a nice setup so far, no complaints at all and I've got factory rake with my shell and tools in the bed. With you not having the TSB leaf pack, you'd likely have factory rake with an empty bed. I'm running this setup with stock length 5100's.
  9. Aug 30, 2012 at 12:43 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    my stock leafs have squeeked since day 1 :pout:
  10. Aug 30, 2012 at 12:47 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    my expos don't make a sound! but I've never heard a bad thing about the dakars, both are a good leaf pack
  11. Aug 30, 2012 at 8:30 PM
    OZ-T
    Peter North
    British Columbia
    You live in the desert
  12. Aug 30, 2012 at 8:34 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    my expos are somewhat squeaky, but it doesnt bug me
    I like how much weight I can throw in the bed now
  13. Aug 30, 2012 at 9:06 PM
    PLC721
    Patrick
    Chandler, Az
    :thumbsup:
