OME EL095R (medium) lift heights?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nd4spdbh, Aug 22, 2018.
  1. Aug 22, 2018 at 7:36 AM
    nd4spdbh
    nd4spdbh [OP] Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    So those that run the EL095R (medium) new dakar pack's what kind of center hub to fender measurements are you seeing on an unloaded truck?
    Thanks!
    ~ND4
    llamasmurf likes this.
  2. Aug 22, 2018 at 7:38 AM
    Comatose
    Comatose You snuff it, we stuff it.
    Miguel
    San Diego, CA
    2008 TRD OR Indy Ink
    Missing Critical Hardware Edition
    I'll measure again when I get home and let you know.
  3. Aug 22, 2018 at 11:31 AM
    nd4spdbh
    SoCal
    Hell yeah thanks man!
  4. Aug 22, 2018 at 11:34 AM
    IwasDacapsterAz
    IwasDacapsterAz Well-Known Member
    Cap
    14 4w4 Taco Access
    Bamf and Bilstien
    After 6 months I'm at @ 24.5 RH and LH , both were ++
  5. Aug 22, 2018 at 11:38 AM
    nd4spdbh
    SoCal
    Awesome! Just to verify thats Center of hub to fender?
    Keep the info coming guys!
  6. Aug 22, 2018 at 11:38 AM
    IwasDacapsterAz
    Cap
    14 4w4 Taco Access
    Bamf and Bilstien
    center to bottom of fender
    nd4spdbh[OP] likes this.
  7. Aug 22, 2018 at 12:36 PM
    nd4spdbh
    SoCal
    Thanks again!
  8. Aug 22, 2018 at 1:09 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Driver side = 23.5"
    Passenger = 23.75"
    ..with a (Leer) fiberglass canopy
    Romaneo, outxider and BassAckwards like this.
  9. Aug 23, 2018 at 9:44 AM
    nd4spdbh
    SoCal
    cool deal. add that to the list. I gotta measure my current setup but im pretty sure im closeish to that. Just looking to go a full leaf pack to get rid of the stock noodle pack that has a single 2in AAL in it but not looking to raise the ass end much more.
  10. Aug 23, 2018 at 10:54 AM
    jross20
    jross20 Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
    Get the heavy. I got the mediuns and after they break in they are not as strong as I wanted... Plus the heavy will really reduce axle wrap more I presume
    lynyrd3, HarrisonHopper and TireFire like this.
  11. Aug 23, 2018 at 11:09 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The best thing about the Dakars is the articulation/ease of droop you get in the back. Going up a washboard road in 2wd, I can feel how the rear tires stay in contact with the road. Less wheel spin..
    I guess the weight of my canopy helps keeps the tires down too, but when I had the stock pack with an icon aal it really hopped over the washboards.
  12. Aug 23, 2018 at 11:14 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    This is good advice. You can also remove one of the overload leaves or the middle leaf (or both, that's what I did) and add leaves back in after the pack settles.
    After about one year I added the middle leaf back in.
    You may also wanna ask people to state if the have a long bed, short bed and what cab size cause it changes weight held up by the rear suspension
  13. Aug 23, 2018 at 1:06 PM
    nd4spdbh
    SoCal
    im a DCSB, and unloaded 99% of the time. Every now and then ill tow a jetski / motorcycle trailer and a bed full of gear. But with the stock pack and AAL it doesnt squat much, dakar mediums are undoubtedly better than the stock + AAL
  14. Feb 17, 2019 at 10:11 PM
    1cleanFG
    1cleanFG DialsGarage
    DialsGarage
    PNW
    2023 Sport 4x4 DCLB
    Toytec Alumaseries Coilovers OME El111R Camburg UCAs Scs sr8 17” 285/70/17 KO2
    I have the 95Rs on my ‘10 dclb sport, I don’t have measurements currently but I will say I got atleast 2-2.5” of Lift, they are a little stiff for my liking for daily driving but when you put a bunch of weight in the back or are towing a boat or trailer, is when these leafs really shine. Absolutely amazing.
  15. Feb 18, 2019 at 2:30 PM
    Armkb
    Armkb Well-Known Member
    Hudson Valley, New York
    09 TRD Sport DCLB
    Bilstein 5100, OME 885X, LR UCA, ARB/EL095R, ES LCA Rack & Sway Bar Bushings, Yellow Wire Mod, ABS Switch, TPMS Mod, Scanguage, Toyota Bed Mat, WeatherTech Floor Liners, Extang Trifecta Cover, Fumoto Drain Valve
    After 5 months unloaded, both springs rated “0”
    Driver side = 24”
    Passenger = 24”
  16. Feb 18, 2019 at 2:40 PM
    IDTaco
    IDTaco Member
    Jeff
    2014 PreRunner DCSB
  17. Feb 18, 2019 at 2:54 PM
    Dimestore55
    Dimestore55 Well-Known Member
    William
    Richmond, VA
    2007 TRD OR Prerunner DCSB
    Not a stupid question at all. I think it's one of those "gray areas" where it would probably be okay with stock length but you should probably get the extended. I recently put these on my truck and got the extended Bilstein 5160's. I did not change the brake lines and the stock ones are fine.
    b_r_o likes this.
  18. Feb 18, 2019 at 4:09 PM
    IDTaco
    IDTaco Member
    Jeff
    2014 PreRunner DCSB
    So lift height is the same for AAL and full Dakar but the longer shocks and brake lines is for the greater 'flex' you get with a full pack?
  19. Feb 18, 2019 at 4:45 PM
    ucdbiendog
    ucdbiendog Well-Known Member
    Reno, NV
    2014 DCSB TRD OR
    Bilstein 6112 + 5160 + Dakar MD, Stubbs HD-SKO sliders, BAMF skids, BAMF front bumper, Relentless Rear
    Dont forget though that there needs to be a spacer installed on the driver side brake line bracket. this spacer is included with the 5160 shock. I also have this setup (Dakar medium) and have 24" driver side and 24.25" passenger side fender to hub. Double cab short bed with a plastic tonneau cover (~30-40 lbs).
  20. Feb 18, 2019 at 5:08 PM
    IDTaco
    IDTaco Member
    Jeff
    2014 PreRunner DCSB
    Thanks for the measurements. Curious what they would be.
    ucdbiendog[QUOTED] likes this.
