OME EL096R/EL095R DCLB advice
Discussion in 'Suspension' started by Globemaster, Jun 23, 2018.
  1. Jun 23, 2018 at 2:43 PM
    Globemaster
    Globemaster [OP] Well-Known Member
    17 DCLB TRD OR
    OVTUNE 91 1.04 255/85/16 ST MAXX FOX 2.5 ext travel ICON billet UCAs OME EL095R
    First let me say Ive read the entire thread from headstrong on the new OME leaf packs.
    Now for the question,
    Does anyone have experience with both the ELO95R and EL096R on an empty truck?
    I am running a mostly empty DCLB with plans for a shell and drawers. I plan to order the EL096R leafs and either throw em on as is or pull a leaf until I add the weight.
    Is the EL096R tolerable empty? or is the EL095R so smooth empty that its worth it to do the work twice?
    Thanks!
    MattCowsmasher likes this.
  2. Jun 25, 2018 at 9:20 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    I have the hd leak pack an run around unloaded for DD ride is not bad a little stiff but better than stock leafs with aal I had prior. Get the HD it’s 30 more compared if you bought the aal later it’s 50-70 more.
  3. Jun 25, 2018 at 9:21 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    HD is not bad with an empty bed. Just buy it and save the hassle of adding leaves later.
    Globemaster[OP] likes this.
  4. Jun 25, 2018 at 9:29 AM
    Globemaster
    17 DCLB TRD OR
    Thanks for the advice guys.
    Follow up question, are you all using the yellow OME bushings or the cheaper ones that wheeler/headstrong sells?
  5. Dec 3, 2018 at 4:58 PM
    Sapnjack
    Sapnjack Well-Known Member
    Daniel
    Phoenix AZ
    2016 TRD-OffRoad
    Bilstein 6112/5160 Dakar EL096R Leaf Springs KO2 265/75/16 Tires OCF Rock Sliders Cali-Raised Hidden Lightbar Diamonback Cover HD KB VooDoo Premium Rack CVT Tent ARB Awning
    How much lift you guys getting with an empty bed?
  6. Dec 3, 2018 at 5:11 PM
    skig0d
    skig0d Member
    I have the HD pack plus the extra leaf. I have a steel bed rack and rtt normally. When removed, it is stiff but still just fine. I probably get 4+ inches due to the extra leaf (use extended rear brakelines).
