OME front coils
Discussion in 'Toytec Lifts' started by s2kvtak, Mar 1, 2010.
  1. Mar 1, 2010 at 7:06 PM
    s2kvtak
    s2kvtak [OP] Well-Known Member
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    Grillecraft grill w/ TRD badge, Bilstein 5100s on all 4 corners set at 2.5" and Toytec AAL in the rear. 285/75-17 Interco TRXUS M/T
    i am starting to think about getting some OME coild up front on my 2004. my stock ones have sagged some (have adj. 5100s and im not getting my full 2.5") and i plan on eventually getting a HD front bumper and a winch and they wouldnt handle the extra weight. which coils should i get? do they all add lift and are they all capable with the billsteins?
  2. Mar 1, 2010 at 7:09 PM
    mixaro
    mixaro Well-Known Member
    maine
    02 tacoma ext cab, 2011 trail edition 4 runner, 2013 tx baja dcsb
    02 ext cab cat-back exhaust, k&n replacement filter, 5100 billy's, hellcreek 1.5" rear spring packs, 882 OME coils, Toytec 2" AAl, stainless brake lines, Light Racing UCA, 1" diff drop, BPV bracket, 4" deck plate mod, 886 fog light backup light mod, tom woods one piece drive shaft, spider trax 1.25 spacer.
    i'd go with the ome 882, thats what i have and i put them on my 5100's on the zero setting
  3. Mar 2, 2010 at 7:39 AM
    s2kvtak
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    will that still clearance my 285s?
  4. Mar 2, 2010 at 7:42 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  5. Mar 2, 2010 at 10:31 AM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    The spring rate on this coil can handle the extra weight of a bumper, winch, even a double battery.
    Many people have this coil on the 5100's.
    Just a thought.
  6. Mar 2, 2010 at 11:49 AM
    s2kvtak
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    with the AAL you guys offer does that still make the truck sit level?
  7. Mar 2, 2010 at 12:02 PM
    Toytec Lifts
    Rocky Mountains
    I'm not 100% sure, but I would think you would have a pretty level vehicle.
  8. Mar 5, 2010 at 6:21 PM
    mixaro
    maine
    mine sits level with the 882 coils on my 5100's set at zero with the 2" aal but i already had 1.5" lift springs in the rear
  9. Mar 27, 2010 at 8:24 AM
    JESSMAN
    JESSMAN Well-Known Member
    Jesse
    Reno Nv
    08 tacoma
    ARB BUMPER WARN M 8000 LIGHT FORCE LIGHTS Bill 5100 DOWNY FRONT LIFT RANCHO OLD MAN E REAR and JERRY CAN IN THE BED
    I have ARB front bumper with a Warn M8000! Old Man Emu springs Downy coil over and Bills 5100's no sag, works great!! you will need to get a swaybar relocate bracket if you get bigger tires like p265 r16 70 like i did! if you stay with stock tires P245 your swaybar will not rub on your coil springs. i had p245's and the swaybar did not rub till i put on the bigger tires p265's. So i just ordered the relocate bracket from Toy Tec!!!
