OME front shock.. Weld?!
Discussion in 'Suspension' started by haireez, Jan 16, 2010.
  1. Jan 16, 2010 at 5:39 AM
    haireez
    haireez [OP] Member
    jacksonville, fl
    08 4x4 V6 Taco SR5
    I can't find the answer anywhere and I've done several searches.
    Has anyone installed the OME nitrocharger shocks here!?! The shock came in a box and the spring cup was not attached to the shock body. Im not sure if i have to weld the cup that holds the spring to the shock body? Or do I just seat the cup onto the lip of the shock?
    Thanks in advance!!!!
  2. Jan 16, 2010 at 5:42 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    It slips over the shock, and rests on teh shock body. There is a ring welded to the shock in which it rests on.
  3. Jan 16, 2010 at 6:22 AM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    ^^Listen to Chris. Dude knows what's up.
    No welding is necessary. That cup just slips on. It will be held in place after assembly by the rubber bushings, the top plate, and the top center nut.
  4. Jan 16, 2010 at 7:06 AM
    haireez
    haireez [OP] Member
    jacksonville, fl
    08 4x4 V6 Taco SR5
    Thank you!!!! you guys Rock!!!
