OME has changed their front shocks, anyone know why?
Discussion in 'Suspension' started by 28ØØ3, Dec 5, 2009.
  1. Dec 5, 2009 at 11:33 AM
    28ØØ3
    28ØØ3 [OP] Well-Known Member
    boss
    somewhere endlessly searching for ways to offend B
    08 DCLB SR5 4WD
    VatoZone Especial
    Up til now, OME front shocks for 2005-2010 Tacomas were N140S. Now, many dealers only have a few of these in stock. The new parts are 90000.
    Does anyone know why they changed the shocks? or what's different about these? I am having a hard time finding info on them.
  2. Dec 5, 2009 at 11:40 AM
    AK27
    AK27 Well-Known Member
  3. Dec 5, 2009 at 6:51 PM
    VenomTaco88
    VenomTaco88 Just Got Engaged!
    Mtn Home AFB, ID
    Love my Venom Taco
    K&N cold air intake, Full Double Wall stainless steel Megaflow exhaust, custom nerf bars
    From what ive heard is that they made new ones with a different material that has a longer life and naturally they will cost more but hey last longer for more money y not right
  4. Dec 5, 2009 at 7:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    http://www.man-a-fre.com/pa4/omenitrochargersportshockabsorber.htm
    OME NITROCHARGER SPORT SHOCK ABSORBERS
    Old Man Emu Customized Suspension Systems Have Evolved.
    A twin tube-monotube hybrid design supercharges an all new line of NitroCharger Sport shock
    absorbers with all the valving of a monotube combined with the durability of twin tube.
    ARB 4x4 Accessories has just announced the arrival of a new line of shock absorbers,
    the NitroCharger Sport, to add to their already extensive line of Old Man Emu branded suspension. While most dual-tube shock absorber systems are typically designed with the focus on ride height rather than ride quality, ARB’s classic Old Man Emu (OME) NitroCharger line has always been designed with valving for the load carrying capacity as the core objective and the new OME NitroCharger Sport takes that principle one step further. Most dual and monotube shocks typically feature a two-stage
    valving process, the new OME NitroCharger Sport features a triple-stage valving process rivaled only by a remote canister adjustable shock. We’ve stacked it into the most durable shock body and adjusted it by load capacity for you. So, rather than offering a single adjustable shock,
    the OME engineers have done all of the testing and tuning adjustments for you. You get to choose from a selection of shock absorbers for your application based on your load-carrying configuration, guaranteeing an immediate and ideal ride without any costly fine-tuning required post-installation.
    The monotube style main piston valving improves transition and direction changes while the extra base valving provides more fine-tuning for comfort and control. So, the new OME NitroCharger Sport feels like a monotube without the vulnerability or the high price tag. “And, it’s not all about the shocks,” says Senior Design Engineer, Stuart Fooks, “the springs carry the vehicle’s weight so, the spring and the shock have to be married together in the right combination to achieve the most desirable results. At OME, rather than having a standard selection of springs based on their ride height, every spring is specifically developed to be paired with a corresponding shock
    absorber. Extensive testing on every complete OME suspension system ensures a terrific ride and the safest vehicle handling possible.”
    What’s new in the NitroCharger Sport? A high density polyethylene dirt shield, a 10 disc compression stack, a 10 disc rebound stack, the base cup, a triple lip check valve seal, the slip ring, tight fitting rod guide, 35mm high flow piston, 6 disc cylinder end compression stack and a new oil source.
    How does it work? The new valving system creates dampening through disc deflection rather than aperture restriction. This allows for a much more open, free flowing piston design, reducing heat generation and aeration that leads to fade. While the classic OME NitroCharger has never suffered from early fade, the new valving in the OME NitroCharger Sport is designed to better prevent this from happening, creating a shock absorber with monotube longevity.
    Heat is another factor that frequently comes into question with shock absorbers and the OME engineers have found that the idea that an OME dual wall doesn’t cool as quickly as a single is a myth. Our research suggests that as long as the vehicle is moving and air is passing by the shock absorber, the shock will run about 80-100° F above ambient temperature, which is not nearly hot enough to cause any sort of fade in OME NitroCharger brand products. In order to achieve fade due to heat exhaustion
    in a OME NitroCharger Sport shock absorber, it would have to reach temperatures of over 350° F for a prolonged period of time and even then, its difficult to recognize the negligible loss of performance. Occasional short breaks, like a fuel stop, will bring your shocks back to a reasonable temperature without any ill effects.
    Durability was a primary consideration during the development of the OME NitroCharger Sport line. Monotube shocks, built with racing and lighter weights in mind have the benefit of being about 1.5oz lighter than a dual tube, however, they also maintain the vulnerability of a single-walled shock body. If a monotube shock body becomes dented by a rock or some other obstacle, the shock will be rendered inoperable. In contrast, a twin tube can be completely dented and still operate perfectly. ARB has elected to build the new OME NitroCharger Sport with a dual walled shock body for that resilience. The dual walled shock body is particularly beneficial on a vehicle, like a Toyota, where the rear shock
    absorber sits in front of the axle and is the first part of the under-carriage likely to be hit. ARB wanted to ensure that their shocks would deliver the longevity that their customers have become accustomed to so they selected this feature to create the most rugged design possible.
    So, how does it handle? Compared with the OME classic NitroCharger, the NitroCharger Sport is slightly firmer and no longer has the soft wallow, providing better control at low speeds making it more stable in the corners. At high speeds, the shock will still allow you to feel the subtleties in the terrain for reactive handling, while offering better traction and stability. It handles in a Euro-Sport style with excellent cornering and extremely reactive handling. The OME NitroCharger Sport also has a larger loading window than the OME classic so it offers complete control over a larger range of weight capacities. Where An OME classic NitroCharger will control vehicle load increases up to 500lbs, the
    OME NitroCharger Sport controls loads in the range between 0 and 1000lbs offering greater stability and handling even when the vehicle is fully loaded.
    Overall, OME Engineers have created the most finely tuned suspension system for your vehicle by suppressing aeration and heat, while maximizing durability, handling and driver safety.
  5. Dec 5, 2009 at 7:06 PM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    20 Gladiator Rubicon
    Steersmarts Draglink, Tie rod, Track Bar
    Is that what will come in OME kits from Toytec now?
  6. Dec 5, 2009 at 7:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im guessing so. I havent seen any dossumentation indicating the N140s shocks are going to be kept in the line. The new ones are being called a "Replacement".
  7. Dec 5, 2009 at 7:58 PM
    28ØØ3
    boss
    08 DCLB SR5 4WD
    VatoZone Especial
    are they still low pressure?
  8. Dec 5, 2009 at 7:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes. Seems they ride more firm than the N140s shocks however.
  9. Dec 5, 2009 at 8:10 PM
    28ØØ3
    boss
    08 DCLB SR5 4WD
    VatoZone Especial
    dammit, i wanted the OMEs for the softness. i guess they are still softer than other aftermarket "lifted" shocks
  10. Dec 8, 2009 at 11:41 PM
    AlexForbesR6
    AlexForbesR6 My R6 Eats Me
    Alex
    Houston, TX
    07 4x4 6-Spd
    hmmm...are they also going to be upgrading the rear shocks?
    on that site you posted chris they only had a replacement for the n141
    not the n182(i think that is ours)
    also where(apart from that site) can you get these new shocks?
  11. Dec 9, 2009 at 5:27 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Check with wheelers and see if they are carying them....Maybe Toytec...
  12. Dec 9, 2009 at 5:32 AM
    Jigzor
    Pennsylvania
    I ordered my OME kit from Toytec Monday. When I looked at the invoice it listed the front shocks as the new part number (90000).
  13. Dec 15, 2009 at 6:15 PM
    28ØØ3
    boss
    08 DCLB SR5 4WD
    VatoZone Especial
    tell us how they ride when you get them installed
  14. Dec 16, 2009 at 9:56 AM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist
    Rocky Mountains
    Toyota's are awesome
    Correct!!
  15. Dec 16, 2009 at 9:59 AM
    Jigzor
    Pennsylvania
    I will, I don't think I'll have time to do it for another week or so. Strained a few ligaments in my ankle. Crutches are a b**ch.
  16. Dec 16, 2009 at 10:03 AM
    28ØØ3
    boss
    08 DCLB SR5 4WD
    VatoZone Especial
    misuse of comma fail! and the 2nd sentence has no subject
  17. Dec 16, 2009 at 10:05 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Hmm. I love my N140s on the front of my truck, hopefully these new shocks live up to the reputation of the older style. :cool:
  18. Dec 16, 2009 at 10:14 AM
    Toytec Lifts
    Rocky Mountains
    From what I've read, people are loving them.
  19. Dec 16, 2009 at 10:16 AM
    Jigzor
    Pennsylvania
    It's a fragment I understand, but GTFO! :D
  20. Dec 16, 2009 at 10:20 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Burned.
