OME HD leaf removal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Estes’ tacoma, Jun 13, 2019.
  1. Jun 13, 2019 at 2:32 PM
    Estes’ tacoma
    Estes’ tacoma [OP] Member
    Guy
    Denver Co
    09 Tacoma TRD
    hey y’all!
    I’m looking for any insight with removing the HD leafs on my 09 Tacoma to help balance it out. I was looking at a post that was pretty detailed on the “how to” but now can’t find it for the life of me. Any idea where I can find it, or better yet, anyone have any insight?
  2. Jun 13, 2019 at 2:38 PM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    If you are just replacing the leafs and putting on different ones, this is a YouTube video of how to install them on a 2nd gen....so just do it in reverse order.
    https://youtu.be/31ORzqSCKHQ
  3. Jun 13, 2019 at 2:40 PM
    Estes’ tacoma
    Guy
    Denver Co
    09 Tacoma TRD
    Thanks for the link! I’m not replacing them, just looking to remove the HD leaf because I don’t really have a use for it to be in.
  4. Jun 13, 2019 at 2:42 PM
    crashngiggles
    Jared
    Here is one on how to install an Add-a-leaf which you can also use to take apart your dakars and remove the HD leaf from them.
    https://youtu.be/2DqQvMLrVi0
    Estes’ tacoma[OP] likes this.
  5. Jun 13, 2019 at 2:43 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    It’s not rocket science, but its not a beginner project. A second pair of hands is not necessary, but would be helpful.
  6. Jun 13, 2019 at 3:00 PM
    Estes’ tacoma
    Guy
    Denver Co
    09 Tacoma TRD
    Would you say it’s not a beginner project because of the multi step process of it all, or is there something I might be overlooking?
  7. Jun 13, 2019 at 3:07 PM
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    It's super simple. Pull the leafs out, which is the u-bolts and the two shackle bolts. Lay them on the ground, clamp them. Take the center pin out. Slowly release clamps, remove leaf. Tighten clamps, replace center pin. Torque to spec.
    Grease stupid bushings, reassemble. I've always found it easier to put the front bolt in before the rear bolt. Sometimes the center pin is stupid and you have to to do some weird shit with jacks to get it to go back in the hole. Replace u-bolts, torque to spec.
    Edit:Also the stupid parking brake bracket bolt.
  8. Jun 13, 2019 at 3:12 PM
    rnish
    Tacoma 2nd gen
    How complete is your tool kit? Do you have a torque wrench? Have a set of deep metric sockets? The spring(s) are under tension, respect is advised.
  9. Jun 13, 2019 at 3:21 PM
    Estes’ tacoma
    Guy
    Denver Co
    09 Tacoma TRD
    That seems about like how I thought it’d go, so glad to see I wasn’t missing much! Only thing I’m struggling with is deciphering which leaf is the HD one I should pull. While I was searching I saw two different leafs identified as the HD...
  10. Jun 13, 2019 at 3:23 PM
    PCTaco
    Adam
    New Columbia, PA
    Working on it
    I think it's the second after the main leaf.
  11. Jun 13, 2019 at 3:23 PM
    Estes’ tacoma
    Guy
    Denver Co
    09 Tacoma TRD
    I have some deep well sockets, but no torch wrench. I am planning on borrowing (hopefully) one of my buddies torch wrench though.
  12. Jun 13, 2019 at 3:25 PM
    Estes’ tacoma
    Guy
    Denver Co
    09 Tacoma TRD
    Thanks! I’ll keep doing some research on it, but you’re the second source that said the 2nd so that’s a good sign!
  13. Jun 14, 2019 at 2:44 AM
    BankrupTaco
    BankrupTaco Well-Known Member
    2021 Tundra SR5 4x4
    I emailed ARB to confirm which leaf to remove. my truck sits super high in the rear lol
