OME HD leaf spring with Bilstein 5100 and 887 coil?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DanielCraftsman, Apr 29, 2020.
  1. Apr 29, 2020 at 3:49 PM
    DanielCraftsman
    DanielCraftsman [OP] Member
    Dan
    2016 Tacoma Access Cab TRD off road
    I recently purchased a 2016 Tacoma access cab TRD off road. I will be replacing the stock shackle hangers with BAMF hangers & shackles. I will be hauling a slide in camper (1000lbs.) in the summer time and was thinking of upgrading the leaf springs to OME Dakar Heavy Duty leaf springs (EL096R). I am also planning on putting Bilstein 5100’s on all four corners. What would be the correct coil (OME 887?) to put in the front to make the truck level? Should I get the extended length Bilstein 5100 B100 for the rear or regular length?
