OME Heavy Duty Leafs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gman4092, Sep 22, 2024.
  1. Sep 22, 2024 at 5:34 PM
    Gman4092
    Gman4092 [OP] Member
    Garrett
    2021 Tacoma TRD Offroad
    2021 TRD OR, Leer topper, Decked, in the back; ole girl is sagging bad. Factory suspension cannot keep up with the load in the rear, so the truck is squatted currently (1/2” drop front to rear wheel wells)
    Looking at my options to beef up the rear suspension, and considering just doing a lift all around while I'm at it.
    My big question:
    Will the OME Heavy Duty Leafs lift the truck 2” from its current height or 2” from its factory height. Assuming the latter, due to the extra constant load being factored in as thats the purpose of the springs. Wanted to see if y'all had any experience with this situation or what your setups/recommendations were
    Thanks
  2. Sep 22, 2024 at 5:35 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Other options include Dobinsons and Archive Garage.
  3. Sep 23, 2024 at 2:06 PM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    Dobinsons leafs over ome all day. My medium duty leafs were pretty much flat after a year with just a topper well within the recommended range.
    Is yours a short or long box? Check the dobinsons site and you will see the change in suggested loads per leaf pack change be it a aclb/dcsb vs a dclb.
    The suggested 2" is it will support x amount of weight and provide 2" of lift. When my 112's are un loaded is more like 3.5" of lift
  4. Sep 23, 2024 at 2:10 PM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    as much as i thought the over rating on my OME springs I've the medium which should be enough for my topper they are already saggier then id like. but for the deal i got on them I'm
    not going to really complain at this point! if OME id "weight up"
  5. Sep 23, 2024 at 2:38 PM
    Gman4092
    Garrett
    By far the most helpful reply I’ve gotten when asking about leafs/lifting with camper, thank you.
    What struts did you install with that? Forgive my ignorance on this stuff pretty new to the suspension game
  6. Sep 23, 2024 at 2:40 PM
    JasonLee
    15 TRD OffRoad
    I swear I have a 5” lift with my 112 heavy springs even with an about 400lbs (camper, bike rack, swing out, fridge, toolbox, goal zero, maxtrax).
  7. Sep 23, 2024 at 2:43 PM
    Gman4092
    Garrett
    Probably going to go with the 111’s, 2” is plenty high for me and trying to avoid having to put UCA’s in the front if I can help it
  8. Sep 23, 2024 at 9:23 PM
    Veet-88
    Sb or LB it makes a big difference
  9. Sep 24, 2024 at 12:34 AM
    Mater96
    Mater96 Well-Known Member
    AZ
    2019 Tacoma Offroad 4x4
    Amber DRL retrofit Fox 2.0 coilovers and reservoir shocks
    I have medium load ome springs, they are loud and stiffer than hell even with a few hundred lbs in the bed. If i could go back i woulda tried any brand other than ome.
  10. Sep 24, 2024 at 12:36 AM
    Mater96
    AZ
    Also with my 2" lift from the springs i got a real bad vibration so i used shims to fix that, but now i was lifted like 3" so keep that in mind when setting it all up if you have to do the same thing.
  11. Sep 24, 2024 at 5:52 AM
    Inyo_man
    Inyo_man Don't piss down my back and tell me it's raining.
    U.S.A.
    2023 Tacoma TRD, off-road, access cab
    Purchased heavy duty OME leafs years ago for my kid's Toyota pickup for loading it down with gear. When I bought it back, I removed two of the leafs from each side following the OME instructions to get a "medium" rate spring. Worked a treat.
    Cheers
  12. Sep 24, 2024 at 6:28 AM
    JasonLee
    15 TRD OffRoad
    DCSB.
  13. Sep 24, 2024 at 6:35 AM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    HD’s should be a good match with your set up. Sounds like the lift will be around 2 inches
  14. Sep 24, 2024 at 10:03 AM
    Gman4092
    Garrett
    Thanks for the help guys. Think im going to give the Dobinson Leafs a try, and throw some 5100’s w/ coils in the front at 1.5-2” so my rake isn’t too exaggerated. Then 275/70-R17 grips to fill out those wheel wells. Will post update once its all done with before and after pics
    :cheers:
  15. Sep 24, 2024 at 11:13 AM
    JasonLee
    15 TRD OffRoad
    FYI - if you are thinking about getting the greasable bolts, they didn’t fit in my frame up front unless I would have drilled out the frame, which I was not going to do.
    The greasable bolts fit into the shackle side no issue.
    This was on my 2015 2nd gen, but I received an unacceptable answer from Dobinson’s Australia engineering team to just drill out my frame since the threaded portion of their bolts was bigger than the unthreaded shank which would fit.
  16. Sep 24, 2024 at 11:25 AM
    OmniBot
    OmniBot Active Member
    Karl
    2020 VooDoo Blue Tacoma DCSB TRD OR.
    None (YET!)
    Not trying to hijack... but how many people mix and match... say Dobinson's springs with OME MT64's? Interested how a system designed to work with its own brand of springs ( like OME) would work with with another spring or if their would be any drawbacks... I mean in theory in my head the answer is no.. but I am not a suspension engineer :)
  17. Sep 24, 2024 at 1:41 PM
    BigCountry762x39
    TL
    PNW, Oregon!
    I've Bilstein's up front with the HD springs, the back are OME medium springs, with fox 2.0 external res shocks... my trucks a bit of a kit bash.
