OME Heavy Leaf Pack with Stock Suspension
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Feloniousc91, Sep 20, 2022.
  1. Sep 20, 2022 at 8:51 AM
    Feloniousc91
    Feloniousc91 [OP] Member
    2020 TRD OF 4x4
    Hello,
    I am buying the OME Dakar Heavy leaf pack for my 2020 Tacoma, as I carry a lot of weight in the bed at all times. My question is how long can I run the Leaf pack if at all with the stock suspension? I do plan on getting the Eibach Stage 1 kit within a month or two. I am sure there is some information on this somewhere, but at the moment I do not have time to research. Just running 265/75/16 Wildpeaks with a Camper shell. Thanks so much for the feedback!
  2. Sep 20, 2022 at 8:54 AM
    TexasTacoma713
    TexasTacoma713 Well-Known Member
    PNW
    2024 OR
    You can’t. The OEM shocks aren’t long enough. You’ll probably fully extend the shock over any bump. Luckily rear shocks are cheap, just get some bilstein 5160s
  3. Sep 20, 2022 at 8:56 AM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    I got over 4 inches of lift unloaded in my 2nd gen with the heavys. Even with a bed full of mulch and rocks they only sagged about an inch. The dakars are for loads and still provide 3 inch lift. At least in my case it did. My 5100s acted like limit straps. It sucked.
  4. Sep 20, 2022 at 9:01 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    You want a heavy pack just for a camper shell? That pack is for like 600+ lbs.
  5. Sep 20, 2022 at 9:10 AM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    Couple things; you don't want to run HD Dakars with stock rear shocks. You can buy rear shocks for cheap - just save a little bit more, then install. You also don't want to be lifted 2-3" in the rear with no front lift, at least I don't think you do. If you're only considering the Dakars because you don't like sagging when you have weight, but also don't care about lift, you can check into airbags for the rear.
  6. Sep 20, 2022 at 9:23 AM
    TexasTacoma713
    PNW
    2024 OR
    Also, heavy is for super heavy loads. I run the mediums with a high clearance rear (no swing out). And even when I do load it heavy (like a yard of gravel, which is 2000lbs), it will sag a bit but not much. Recommend getting the medium and if you want more add the leaf
  7. Sep 20, 2022 at 9:24 AM
    Feloniousc91
    2020 TRD OF 4x4
    I carry other things for work inside of it and run a racks with items on it as well.
  8. Sep 20, 2022 at 9:25 AM
    Feloniousc91
    2020 TRD OF 4x4
    Okay I'll just wait to get the suspension. Thanks
  9. Sep 20, 2022 at 9:52 AM
    Feloniousc91
    2020 TRD OF 4x4
    Got it. I'll wait to install new suspension. Thanks
  10. Sep 20, 2022 at 12:00 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Note that your posts are slightly confusing because they imply that leaf springs are not part of the suspension which is not true. By suspension are you referring to coil-overs for your front suspension or perhaps to shock absorbers?
    Off Topic Guy likes this.
  11. Sep 20, 2022 at 12:37 PM
    Dubiousveracity
    Dubiousveracity Well-Known Member
    2018 TRDOR DCSB MT
    none
    I'm running a 300lb "ripcord wedge". I found the stock suspension to be pretty inadequate when dealing with anything but the smoothest roads (on the bump stops way too easily). I added icon progressive helpers. Lift put it at about empty stock height while loaded for camping and the ride is significantly better even hucking it at the Alaska highway. Might be an interim option for you.
