OME Help
Discussion in 'Suspension' started by Future55, Dec 22, 2010.
  1. Dec 22, 2010 at 10:50 AM
    Future55
    Future55 [OP] Well-Known Member
    Oahu
    2010 4x4 DC TRD Sport
    Weathertech Mats, AFE Stage 2 SI Pro Dry S CAI, TRD Exhaust, Access LE w/ Pop'n lock, 17" XD Revolvers, 285/70/17 Duratracs
    Whats up guys, ive done a lot of research and from what ive gathered a lot of people recommend the OME lift. For those who say the ride is awesome, and all that good stuff..is that with the dakar leaf spings set? I dont offroad that much so im looking at the OME lift with an AAL, but i dont want a worse ride than stock.
    Also, i know the OME kit is 3", and ive read that anything over 3" can mess a lot of things up. Is there anything i should be worried about with the OME? Is it pushing the limit?
    Last question, if i dont care about a 3" lift all around, should i just skip the top plate spacer? Will that affect anything/make my taco look uneven?
    edit: oh yeaaa, do i need to buy longer brake lines with this setup?
    Thanks!
  2. Dec 22, 2010 at 11:04 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Check the link in my sig: bjmoose installs OME.
    the only way to preserve a stock ride is to keep it stock. Pretty much any lift will ride stiffer than stock, and most folks who lift think that's a good thing.
    I personally recommend brake lines with the dakar springs. YMMV.
    I'd start without the top plate spacer. 885 springs raise the truck quite a bit already. You can go back and add a top plate easily if you put in longer top plate bolts while you have the strut disassembled.
    Any lift introduces risk of VSC troubles (about 20% of the time)
    driveline vibrations (about half the time)
    faster CV boot wear
    needing to trim plastic in the wheelwell when you put on larger tires (varies)
    Did you read the stickys at the top of this forum? Lots of good info there.
  3. Dec 22, 2010 at 11:16 AM
    K1992f
    K1992f Well-Known Member
    Kanon
    Dirty Hanover pa ...
    2012 tacoma TRD sport fully loaded
    6" fabteck 20" fuel hostage 33" nitto MTs
    So this post and the pic are same OME toytec complete lift kit they offor $699. ???? I want 3" lift for my truck .. Just don't no much about lifts so I'm learning as I go . I don't have a big wallet so I'm trying to figure what I all need to hey my 3" lift.
  4. Dec 22, 2010 at 11:36 AM
    Future55
    Oahu
    bjmoose, i was actually looking at your ome build thread earlier. :D I know for the most part, all of the potential risks. You recommend the dakars? I would love to do that; however, with the limited offroading i do, i dont necessarily think its worth it, unless the ride wit hthe AAL is terrible or worse than stock...As for the brake lines, you said recommend, does that mean you dont NEED them?
    Ive looked at the stickies and read numerous threads, its just hard to formulate all the research into one. Its always bits and pieces and different opinions, barely any threads come out and say: do this, do that, you need this, this will happen..etc.
    Appreciate the help, keep it coming!!
  5. Dec 22, 2010 at 12:14 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    It will be stiffer than stock with the ome lift. These kits are designed to be driven offroad and carry extra gear and stuff(extra weight). You don't need the dakars. A simple aal will be fine. you could go with the wheelers 3 leaf aal. I hear it's a little softer riding than the toytec 1 leaf aal. both give about 1.5" of lift. If you just go with the 885 coils up front with no top plate spacers you should end up with about 2.5" of lift after it settles. Thats plenty for someone who doesn't go wheeling and wants to run bigger tires and have that aggressive look. You want to stay at 3" or less on a simple coilover lift on a 4x4 because of having a front drivetrain and keeping all your cv's and axles lined up correctly.
  6. Dec 22, 2010 at 12:25 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Wheelers was happy to sell me the OME setup without brake lines. Said it was my choice.
    If I were doing OME springs in front, without Dakar leaf pack, I'd do a 2" Add-A-Leaf in back. *Avoid the Bro Lean.*:eek:
    Also, if you want a "moderate height" lift with less chance of troubles, consider using 884 springs instead of 885. 884s set the ride height a little lower than the 885s do.
    You probably already know that the most practical, cost effective, bulletproof lift setup is 5100s all the way around set at 1.75(NOT 2.5) in the front, with a 1.5" add-a-leaf in back.
    EDIT. The main reason to go with OME shocks vs. a bilstein setup is if you're carrying a loaded truck over prolonged bumpy/washboarded roads. And if you were doing that, you'd want the Dakar leaf pack. The OME springs have a higher spring rate to carry a heavier load, and beefier shock absorbers to fight heat buildup/failure over a prolonged period of time. I guess what I'm saying is that the if you don't really need the Dakar leaf pack, you could probably save some coin by doing a bilstein 5100 lift instead of an OME lift.
  7. Dec 22, 2010 at 12:39 PM
    Future55
    Oahu
    Thanks! Can you link me to the wheelers 3 leaf aal? Also, if i order for toytec lifts, i have to choose an AAL, so id end up paying for two?
    So you opted out of the brake lines but did you buy some yourself? Im still confused as to whether or not you need new, longer brake lines.
    Again, about the AALs, do you happen to know how big the toytec AAL is?
    Yea, i know all about the 5100s. I figured i would just spend the extra dough to get a solid setup. I know cost-wise, the 5100s would be the best bet, but ive heard too many good things about OME to pass on it. Ive also heard the ride is better with OMEs than the 5100s.
    Some new/needed questions: :D
    -Do i need new longer brake lines?
    -What AAL should i go with/where do i get it?
    -Should i get the rear TSB before i do the lift? (i know i wouldnt if i was going with the dakars)
    Thanks fellas, i apologize for the tidal wave of questions..:eek:
  8. Dec 22, 2010 at 1:01 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    No you don't need new brake lines. Just don't whine later if the factory ones eventually wear out. "Some guy on the internet named BJMoose said I didn't need them!" :eek: Pay your money, take your chances. No whining. :cool:
    Whoever sells your shocks and kit will have Add-A-Leafs. They're available in 1.5 and 2" sizes. Talk to a human being not a web form to get one or the other.
    AAL adds capacity in and of itself. How much stuff you gonna carry back there? Empty bed? No do TSB. 500 to 1000+lbs ? Do the TSB first.
  9. Dec 22, 2010 at 1:09 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    - no
    - i'd just get the one from toytec
    - if they'll let you go for it
  10. Dec 22, 2010 at 1:13 PM
    TacoSupreem
    Hayden
    Kentucky
    www.wheelersoffroad.com you can buy the ome setup from them. I bought mine from them and Dan is a super nice guy and will help you with all your questions. You don't need the longer brake lines with just an aal. The tsb really doesn't do much but make the rear a little stiffer and sit a little higher. i never saw a need for it and it don't sound like you will need it.
  11. Dec 22, 2010 at 1:20 PM
    Future55
    Oahu
    Thanks for the help guys. TacoSupreem, the only thing about wheelers is they dont have the package that i want. Theirs comes with the dakars. Maybe if i priced everything out from there seperately it would add up to be a better deal than toytec, ill probably do that in a little bit.
    So i dont need longer brake lines, but bjmoose, is there something about the lift that wears them down faster? Or are you just saying i will need them "eventually"? Its not like new ones could hurt anyways.
  12. Dec 22, 2010 at 1:27 PM
    TacoSupreem
    Hayden
    Kentucky
    Just call Dan A.K.A. Yota Dan at wheelers and tell him what you want and he will make a package for you and give you advise on what all you will need.
  13. Dec 22, 2010 at 1:28 PM
    CopDoctor
    08 335i
    keep in mind you get a discount from toytec for being a member
  14. Dec 23, 2010 at 8:41 AM
    Future55
    Oahu
    Does anyone know what size the AAL Toytec provides for the rear tsb? 1 leaf at 1.5"?
  15. Dec 23, 2010 at 8:46 AM
    Brunes
    Brunes abides.
    Rotorhead
    The rubber lines will stretch some...but if you start taking it off road alot...You may surpass their ability to stretch...and at that point you are making a mess with brake fluid and in some real danger.
    If you are not going to be offroad- You don't need them...but if you are or you might be- It's worth it to knock them out while the whole suspension is torn apart instead of having to go back and do it again....
  16. Dec 23, 2010 at 10:33 AM
    CopDoctor
    08 335i
    don't get yourself confused. the tsb is through toyota, they change the leaf pack out with a newer one that has 4 leafs instead of 3.
    the AAL from toytec is a 1.5" AAL, but in the rear you get double the lift. 1.5 x 2 = full 3" lift.
  17. Dec 23, 2010 at 12:27 PM
    Future55
    Oahu
    Sorry i should have been more clear, i meant the AAL that toytec gives you when you select the rear option: "Toytec AAL for TSB springs"
    So i understand that the TSB most people refer to is the new leaf pack, but what is the TSB for the springs? Same one or no?
