OME/ICON Lift Price Quote
Discussion in 'Suspension' started by JRod4928, Aug 24, 2012.
  1. Aug 24, 2012 at 4:43 AM
    JRod4928
    JRod4928 [OP] Well-Known Member
    Pittsburgh
    '12 Tacoma SR5
    Extang Trifecta Tonneau WeatherTech Floor Liners Pop & Lock Tailgate Lock Antenna X Black Mesh Grillcraft with Tacoma Badge (Upper) and Cross (Lower) 18" BMF Wheels / Cooper 31.5" Tires 2" Leveling Kit
    I just got a price quote on the following items from DSM. What do you think? good price?
    885 Coils x 2
    90000 Front Shocks x 2 (OME Nitrochargers)
    ICON 5-1100 (ICON 3 Leaf Progressive)
    N182 x 2 Rear Shocks (OME Nitrochargers)
    FK29 x 1 Fit Kit (Carrier Brg Drop)
    $890 shipped (free shipping)
    Seems good to me with the research I've done.:cool:
  2. Aug 24, 2012 at 5:00 AM
    greenrustic
    greenrustic Well-Known Member
    NY
    2012 DCLB 4x4 TRD SPORT
    Access LTD Tonneau Cover, Weather Tech Digital Fit Mats, Weather Tech Rain Guards, 35% Tint up Front, AFE Dry Power Intake Filter, Debadged, GrilleCraft, OME 884x, OME 9000 NitroChargers, Icon 3 Leaf Progressive AAL
    Your forgetting the trim packer. Another $10.00.
    I spent $833.00 for essentially the same set up (including the trim packer) but with 884 coils at the same price as 885's. So your in the ballpark.
  3. Aug 24, 2012 at 5:32 AM
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2010 TRD Sport DC LB 4x4
    Work in progress, but installed so far; 265/70/17 Duratracs, Spidertrax, OME885X coils with OME lean spacer, OME N140S and N182 shocks, Wheeler's 1.5" 3 Leaf Progressive AAL (kept the overload), LR UCAs. TP14 spacers
    if you aren't cash strapped, you might consider some aftermarket UCAs too. my truck wouldn't align for shit (low caster) after putting on 885s.
  4. Aug 24, 2012 at 5:42 AM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    was that with the top plate spacer for 3" or are you at 2.5"? or did you only install the trim-pack for taco lean?
    I'm getting a lot of mixed-comments regarding UCAs. sounds like its hit or miss.
  5. Aug 24, 2012 at 5:43 AM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    Pretty good - where'd you get your stuff? I contacted DSM directly, so that price should be with the TW discount for whatever that's worth.
  6. Aug 24, 2012 at 5:55 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    3" you def need UCA at 2" some at 2.5" got away w/o new UCA.
  7. Aug 24, 2012 at 6:03 AM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    Right.
    I'm painfully aware of the 2.5" gray line. I'm preparing myself mentally (and financially) for the possibility of needing UCAs.
    If i need UCAs, at that point I'll just install the top plate spacer and get another 1/2" of lift.
    'Lifetime alignments' is a wonderful thing :D
  8. Aug 24, 2012 at 6:13 AM
    JonnyBb
    Arkansas
    That was with a trim packer, but without top plate spacers. I had my truck aligned right after I installed my lift and they never gave me a printout, but they said the numbers were "perfect". It drove like hell (loose steering, wander at highway speeds, and bumpsteer), and Elwood on TW suggested that I get it checked by another shop because he thought my numbers were bogus. Turns out I had <1* caster on both sides. Best this new shop could get was 1.2*. So, I tried that and it still drove like crap. Bought LR UCAs, put those on and have never regretted it. I put on ToyTec's TP14 spacers for a little extra height when i was putting the UCAs on.
    Botton line, it might be hit or miss. My advice is that you be ready to buy UCAs if you don't like the way it handles....EVEN IF THE ALIGNMENT NUMBERS ARE "PERFECT". A lifted truck with the setup you are looking at should drive and ride as well as it did stock (mine does now).
  9. Aug 24, 2012 at 6:17 AM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    Good advice, man - Thanks. Don't want it to wander like I'm drunk.
    Maybe its worth it, even if you do get alignment and it drives well, it doesn't mean it will stay within spec forever. And because you are changing the geometry, you may still be wearing out the ball joints on stock UCAs even though alignment is within spec.
    Looks like I'm up to $1300....
    I hate Tacoma World
  10. Aug 24, 2012 at 8:43 AM
    JonnyBb
    Arkansas
    Sorry man. Honestly, you can give it a shot without the UCAs first. I put my UCAs on a couple months after the lift and found them to be much easier to do than the original lift install.
