OME Install ??
Discussion in '1st Gen. Tacomas (1995-2004)' started by 00TacoRunner, Jul 7, 2019.
  1. Jul 7, 2019 at 12:31 PM
    00TacoRunner
    00TacoRunner [OP] Active Member
    2000 Black Prerunner V6
    I was looking to install a set of OLD MAN EMU NITROCHARGER SPORT REAR SHOCK 60062 for my 2000 prerunner. Do I need any additional set of bushings or hardware? Do the new shocks come at stock height or do they need to be adjusted. I'm not looking to lift it right now just do to $$ but just looking to replace my stocks.
  2. Jul 7, 2019 at 2:27 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Rear shocks don't use springs or need assembly :boink:
    tony2018 and Hobbs like this.
  3. Jul 7, 2019 at 2:32 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    He should.
    @00TacoRunner did you already replace the front shocks?
  4. Jul 7, 2019 at 7:53 PM
    00TacoRunner
    I wish I could but i cant afford it right now.
  5. Jul 7, 2019 at 7:54 PM
    00TacoRunner
    No, I was planning on to later. I need to save up.
  6. Jul 7, 2019 at 7:58 PM
    eon_blue
    Azusa, CA
    The rear shocks just bolt in place of the old ones. There's no adjustment to them. The rear isn't lifted via the shocks it's lifted via the leaf springs usually.
    Should just be able to buy those OME rear shocks and bolt them right in
  7. Jul 7, 2019 at 8:29 PM
    BeLance89
    BeLance89 Well-Known Member
    Brandon
    Huntsville, AL
    2002 White TRD double cab
    You’ll need to install the bushing into the eye of the shock. Grease it up and use a vise or a C-clamp. I prefer a vise... or you can try to man handle it in there.
  8. Jul 7, 2019 at 10:47 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    might be able to re-use your stock bushings, if not just order some, cheap enough and wont break the bank.
    As for shock eye bushing install method, I prefer this, it works lol :thumbsup:
    https://youtu.be/VE6zMmc8Xco
    EDIT: Don't need to spray em with anything, I didn't. Your call.
  9. Jul 8, 2019 at 3:46 AM
    tony2018
    tony2018 Well-Known Member
    Def also recommend replacing all shocks/struts, a better feel.
  10. Jul 8, 2019 at 4:04 PM
    trdproven
    trdproven Well-Known Member
    the 5100s are 2 piece bushing, you just place one on either side and just bolt it down. this is a 1 piece that needs to be pressed in the video.
