OME kit level problems
Discussion in '1st Gen. Tacomas (1995-2004)' started by Shabutie, Jul 16, 2014.
  1. Jul 16, 2014 at 6:31 PM
    Shabutie
    Shabutie [OP] Well-Known Member
    Zach
    Fort Stewart
    2002 Toyota Tacoma Limited 4WD 4dr
    Hey all, I had a 3" OME 883 kit with AAL install back in march. I always mildly notice the back was a little lower but now that I put a topper on, it is definitely noticeable. Is there a way to lift the back just a tiny bit more, say 1" just to level it out?
  2. Jul 16, 2014 at 6:37 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Your stock spring were probably shot and the aal wasn't enough to help. Best bet would be a new leaf pack.
  3. Jul 16, 2014 at 6:41 PM
    Shabutie
    Zach
    Fort Stewart
    Figured but will a long while before I can afford one. Thanks
  4. Jul 16, 2014 at 7:39 PM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    you could run some longer shackles if you're not going to replace the leaf packs. You'd need shackles 2" longer to get 1" of lift.
    This isn't ideal and I'd still recommend replacing the leaf packs as a better solution.
