OME leaf noise? question
Discussion in 'Suspension' started by devanb3, Oct 24, 2016.
  1. Oct 24, 2016 at 4:09 PM
    devanb3
    devanb3 [OP] Well-Known Member
    devan
    hampstead
    did a quick search and couldnt find anything on this.
    i have a 2016 that i put the ome leaf pack with ome add a leaf, that i had on my 2013. i get a loud noise when i go over speed bumps or hit a bump in the road in the rear end. everythings tight and aligned propperly i have bilstien 5100s on it and im wondering if they are too short. the 5100 say for 0-3 or 3.5 in of lift and i have 3.5 all around. could that be my issue or is it because they have a higher spring rate or any other ideas?
  2. Oct 24, 2016 at 4:10 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Does it make noise in the front or the rear?
    Driving over a speed bump and hearing it should make it obvious which end is the problem.
  3. Oct 24, 2016 at 4:10 PM
    devanb3
    devan
    hampstead
  4. Oct 24, 2016 at 4:12 PM
    devanb3
    devan
    hampstead
    ive had the lift on for about a year with the problem ive checked bolt tightness about every oil change
  5. Oct 24, 2016 at 4:14 PM
    T4RFTMFW
    Which 5100s are you using in the rear?
  6. Oct 24, 2016 at 4:16 PM
    devanb3
    devan
    hampstead
    im 99% sure its these
  7. Oct 24, 2016 at 4:20 PM
    T4RFTMFW
    I think those are standard length 5100s, so likely your shocks are fully extending over any tiny bump.
    You should have B110 5100s (extended length) for that much lift.
  8. Oct 24, 2016 at 4:21 PM
    devanb3
    devan
    hampstead
    these?
  9. Oct 24, 2016 at 4:21 PM
    T4RFTMFW
    Yup.
    That's my best guess.
  10. Oct 24, 2016 at 4:27 PM
    devanb3
    devan
    hampstead
    thanks for the help and quick response
