OME leaf springs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nevema93, Oct 4, 2019.
  1. Oct 4, 2019 at 1:26 PM
    Nevema93
    Nevema93 [OP] New Member
    Nestor
    '15 Taco Sr5 4x4
    Hello,
    I'm new to this forum and also just bought a used 2015 tacoma sr5 4x4
    I'm going to modify the truck piece by piece myself, I'm using the truck for work and some off roading on the weekends for camping
    Starting with the rear since for some reason someone put a 1 inch block lift in the front if I installed just the ome leaf springs, what else needs to be replaced? Do I need longer brake hoses, etc?
  2. Oct 4, 2019 at 1:31 PM
    roadking1
    roadking1 Well-Known Member
    n.j.
    2023 Solar Octane TrdPro 6-speed manual
    Several posts and threads related to this.Head Strong Off Road would be my first contact
  3. Oct 4, 2019 at 1:31 PM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    Welcome to TW and congrats on the ‘15 truck.
    I have Dakar OME rear leaf springs and did replace my brake lines with +2” longer ones. I haven’t ever tested full flex, and don’t really plan to, but didn’t want to chance having a brake line stretch and tear.
  4. Oct 4, 2019 at 1:56 PM
    Dimestore55
    Dimestore55 Well-Known Member
    William
    Richmond, VA
    2016 TRD OR 4x4 DCSB
    They recommend extended length shocks with those leaf packs. I got the Bilstein 5160's. I did not have to get extended brake lines but you may want to reconsider that decision if you off road and flex a lot.
  5. Oct 4, 2019 at 2:34 PM
    Nevema93
    Nestor
    '15 Taco Sr5 4x4
    Thank you much
    Hardscrabble likes this.
