OME lift for 2nd Gen? Pro's -Con's???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 375taco, May 21, 2010.
  1. May 21, 2010 at 8:50 PM
    375taco
    375taco [OP] controlled pair?
    2010 TRD Sport 4x4 DC SB
    OME lift w/ 1" spacer. Built Right UCA's. Tinted all the way around. De-badged. Trimming up front
    I am debating on getting an OME lift with leaf pack for the rear. I was wondering how it rode, what the ride height is set for. And can you set it at 3" and if so how does it ride? Any info on tire size ride height quality of ride etc....would be much apprechated. Thanks
  2. May 21, 2010 at 8:55 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    you cant adjust the OME lift, only if you have 5100s. But overall the ride is a tiny bit stiffer then stock but it corners better and handles the bumps much better. I got about 2 inches out of my 885s but I believe that it is because I have the supercharger and thats an extra 100 pounds in the engine bay.
  3. May 21, 2010 at 9:02 PM
    375taco
    What size tire can i fit with the OME kit? would you buy new UCA's?
  4. May 21, 2010 at 9:04 PM
    ktmrider
    Junk
    I fit 285s with trimming, and its a good bet to get UCAs but I dont run them
  5. May 21, 2010 at 9:10 PM
    375taco
    hmmmm thanks i apprechate it
  6. May 22, 2010 at 7:35 AM
    EVILSTI
    EVILSTI Well-Known Member
    Ray
    Catskill, NY
    1994 FZJ80 / 2014 Ford Raptor
    94 FZJ80 Land Cruiser Slee 6" lift kit 37" KM2s 17" procomp wheels Snorkel .......................................... SOLD: 06 TRD OFF ROAD OME Suspension lift kit with: Front OME 90000 shocks, 886 coils, top plate spacers, complete OME Dakar leaf spring packs, Front Diff drop kit, Rear N182 shocks, OME trim spacer, OME carrier bearing drop bushings, American Racing Chambers 16X8, Yokohama Geolandar A/T-S 285/75-16s (Winter tires), BFG MT KM2's 285/75-16, satoshi grille mod, TRD CAI, AP front bumper, AP skid plate, Cobra 75 WX ST CB, 2' Firestik antenna, Pioneer Avic-U310BT, Beefed Sliders, LR UCA's, Tinted Headlights, AP Rear bumper, DTLTH, Smittybilt XRC10 comp winch, Yellow top D35, pAP custom Transmission Skid ;-) , NFab spare tire holder, DT Pipe Bomb,
    Ride is much better then stock. 285's with wheels that have a 4.5" Backspace.
  7. May 26, 2010 at 10:35 PM
    jeepmor
    jeepmor Well-Known Member
    I'm an OME fan as I have a custom setup on my 84 CJ7 using their springs and shocks from the 85 4runner rear springs if I recall correctly. The wife had an 85 4runner with the OME suspension and it was very, very impressive on the gravel roads with 33s. Slow wheeling was easy too, but man did that thing handle like washboard was your friend, it just ate it up. Some meth heads stole it, joyrode it, and totalled it. Recovered it 6-8 months later in the spring. Didn't want another project, have the jeep already.
    I'll be adding an OME lift to the 09 Taco after these stock tires wear out. I am greatly looking forward to better ride and load carrying capacity. The stock suspension is really weak once its loaded down. Woefully weak in my opinion.
