OME lift help
Discussion in '1st Gen. Tacomas (1995-2004)' started by 757yotas, Nov 30, 2016.
  1. Nov 30, 2016 at 8:37 AM
    757yotas
    757yotas [OP] Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    After doing hours of research i still can not make up my mind. I understand that 880/881 coils were made for 1st gens. 882s people use but ive seen mixed opinions about them. Same spring rate but some say 882s ride stiff? I have a 2004 tacoma double cab V6 prerunner. Want 3" lift but i cant deal with a stiff ride anymore (has spacers now and i feel every bump on the road). Im stuck between 881s and 882s. They will be going on 5100 shocks set at the bottom notch and the truck has no weight on the front other than some KC lights. Ive looked at over 140 pages on the ome 1st gen setup forum post.
  2. Nov 30, 2016 at 9:12 AM
    STEVEO13016
    STEVEO13016 Well-Known Member
    STEVEO
    2000 Tacoma Prerunner V6 2WD
    5100 Billy's set at 0" with 881 coils
    I have a 2000 Tacoma prerunner V6 2WD Extended cab and I have the 881 paired with billys set at 0". My ride is super stiff.... I am not sure how the ride will be for a double cab....
  3. Nov 30, 2016 at 9:14 AM
    49erfan
    49erfan Well-Known Member
    Kevin
    Dallas
    04 DC Prerunner Lunar Mist
    i dont believe the 881/882/883 will give 3", i have your same truck and wheelers recommended the 883. Give them a call and they will point you in the right direction
  4. Nov 30, 2016 at 9:24 AM
    757yotas
    Virginia
    2007 TRD Sport
    I just talked to lowrange offroad, they recommend 881s with no weight on the front. If they are to low i guess ill be ordering 882s soon aswell lol or might just so a top plate spacer 1-4 or 1/2"
  5. Nov 30, 2016 at 9:41 AM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    How much lift did you get?
  6. Dec 1, 2016 at 4:36 AM
    jjsul
    jjsul Well-Known Member
    James
    New Hampshire
    95.5 OME
    I got 2" from my 881's on my 95 4x4 extra cab
