OME Lift- Honestly- Alignment needed after install?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lanceputnam, Apr 16, 2018.
  1. Apr 16, 2018 at 5:41 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    After the lift they may be steeper, so toe and caster changes.
  2. Apr 16, 2018 at 5:43 PM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Swap to rugged trails, no alignment needed. Hell nails and other road debris bend and run away at the sight of them. Cant wear them out.
  3. Apr 16, 2018 at 5:43 PM
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    I had mine aligned three times to get the caster where I wanted it, and so it carved optimally. I don’t know what other people do.
  4. Apr 16, 2018 at 5:44 PM
    i_cappi
    i_cappi Well Known Membhair
    Canton, Oh
    2011 TX TuRD Pyrite DCSB
    I know that, some were implying they do to install the lift. Why?
  5. Apr 16, 2018 at 5:45 PM
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    Too much beer?
    i_cappi[QUOTED] likes this.
  6. Apr 16, 2018 at 5:48 PM
    GDT
    GDT Well-Known Member
    '09 Tacoma 4x4 access base 2.7l 5spd
    I needed an oil change, so I took my truck to the jiffy lube, and the tech came out and said, "hey, we didn't change your oil", and i was like "okay thanks".
    Honestly- what is the point of this thread?
  7. Apr 16, 2018 at 5:48 PM
    aleriance
    aleriance Well-Known Member
    Jorge
    Naples, FL
    2017 TRD Off-Road 4x4
    CMC 285/70/17
    How was what he said off topic? Sounds to me like you're asking a question and then reacting like a douchebag when someone gives you an answer you don't want to hear.
    No, you don't NEED an alignment after lifting. You also don't NEED to have your wheels balanced when you get new tires. :thumbsup:
    Marking the cams will do little to nothing for you; there is so much more that goes into it. Your caster needs to be adjusted, as well as your toe, and camber.
    jeremy5000 likes this.
  8. Apr 16, 2018 at 5:50 PM
    PuyallupJon
    PuyallupJon 2020 AG Pro
    Jon
    Puyallup, WA
    2020 Tacoma
    In his rush to slam you with a zinger he used the wrong word.
    Should say alignment.
  9. Apr 16, 2018 at 5:51 PM
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    I’m consulting my expert, back after a walk.
    SocalTaco15 and hiPSI like this.
  10. Apr 16, 2018 at 6:04 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    There is no debate on whether you have to have it re aligned after a lift. It is fact, not opinion, that you will not be aligned correctly after changing geometry during lift.
    e6400ultra and GDT like this.
  11. Apr 16, 2018 at 7:40 PM
    Clearwater Bill
    Billy
    Largo Florida
    Any suspension changes that alter the static ht of the vehicle, up or down, changes the alignment from what it was before you started.
    Only way tech comes out and says we didn't have to do anything is
    1) you were out of whack before, and the changes corrected that. In that case, never buy a lottery ticket again; you just sucked up all your luck.
    2) the tech is a lazy goober. It happens.
    3) the alignment equipment hasn't been calibrated in a couple years. Like your old table saw that gives you 'close enough' cuts. So you're still not aligned.
    So the real question isn't should it be aligned. That's a simple yes.
    The real question is if the shop you use is any good?
    GDT and scottsglock29 like this.
  12. Apr 16, 2018 at 7:47 PM
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
    Never align a vehicle after a lift.
    whiskeytacos and GDT like this.
  13. Apr 17, 2018 at 6:13 AM
    STexaslovestacos
    STexaslovestacos Well-Known Member
    Sam
    2017 MT TRD OR
    I don't believe in alignments, alignments are a government conspiracy like chemtrails and a round planet
    if eyeballing it was good enough for Fred Flinstone then it's good enough for me
    after all, taking apart the entire suspension is certainly not going to affect anything
    whiskeytacos and Cudgel like this.
  14. Apr 17, 2018 at 6:15 AM
    SocalTaco15
    SocalTaco15 Well-Known Member
    Glen
    Socal, Orange County
    Love aussies. Best dogs around, bar none.
    Cudgel[QUOTED] likes this.
  15. Apr 17, 2018 at 6:17 AM
    #35
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    My first, won't be my last for sure...she believes a 4 wheel alignment post lift is required as well so she doesn't feel the shimmy...
  16. Apr 17, 2018 at 6:27 AM
    #36
    SocalTaco15
    Glen
    We are on our third and yeah, get an alignment.
  17. Apr 17, 2018 at 8:22 AM
    #37
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    He meant $70 alignment
  18. Apr 17, 2018 at 8:28 AM
    #38
    VoodooBlueATL
    VoodooBlueATL Well-Known Member
    2007 FJ Cruiser
    Definitely get an alignment if you don't want to buy new tires in the very near future.
  19. Apr 17, 2018 at 8:43 AM
    #39
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Just to reinforce: An alignment after a front end lift on an IFS vehicle is not an option. It's essential. 100% immediately required. Like after installation you drive gingerly straight to the nearest shop, back/residential roads only, preferably no more than a couple miles away, while keeping it under 25. No "i'll do it tomorrow", no beer runs first, no hitting the Taco Bell drive through on the way. It's part of the job and you're not finished until you do it.
    People have shredded their tires down to the belts within a couple hundred miles of driving out of alignment. It's like asking if you need to torque your lug nuts after changing a tire or if two-finger tight with a 3/8 ratchet is good enough because you don't want to walk all the way back to the garage to get a proper breaker bar.
  20. Apr 17, 2018 at 8:51 AM
    #40
    strktly_bodysurf
    strktly_bodysurf Well-Known Member
    I would lean more towards it being 100% required...that is if you value things lasting a while and driving a safe, comfortable vehicle. So I guess that's just my opinion, and it really comes down to what you think is required or not required.
