OME lift install time
Discussion in '3rd Gen. Tacomas (2016-2023)' started by easye515, Apr 23, 2018.
  1. Apr 23, 2018 at 11:59 AM
    strktly_bodysurf
    strktly_bodysurf Well-Known Member
    worst case, heat it?
  2. Apr 23, 2018 at 12:26 PM
    SpeySquatch
    2016 TRD OR DCSB
    Not that you have too, but you will want the UCA's for offroading (better shock movement and turning radius, I bought the light-racing UCA's) and DEFINITELY do a sway bar drop spacer because the coils are wider and you will rub the sway bar when turning. This is my rig with the OME Medium kit. Break in took like 2000 miles to soften those damn springs. DO NOT space your carrier bearing, just add 3 degree shims, trust me on this...I spent TONS of time messing with this and taking it to multiple shops, save yourself time and effort. I am running the full dakar leaf pack with overload. Bed sags .75" with 1000lbs in the back. Thing friggin rocks with the OVTune as well...tons of power. Averaging 18-20mpg's with 265/75 r16 Falken AT3 tires.
    PJnc284 likes this.
  3. Apr 23, 2018 at 1:23 PM
    upTOPOverland_Drew
    upTOPOverland_Drew upTOP Overland Technical Design and Application
    Drew
    Littleton, CO
    2017 TRD OR DCSB SUPER WHITE
    All the things...click the link in sig
    888s? what kind of weight do you have up front? total lift achieved?
    truck looks great!
  4. Apr 23, 2018 at 1:25 PM
    easye515
    easye515 [OP] Well-Known Member
    2016 Tacoma TRD Offroad 6 speed manual.
    any tricks to getting the centering pin of the leaf spring lined up? mine is shifted too far forwad.
    I am doing one side at a time, so right now I just have one wheel off would it make a difference to have both wheels off?
  5. Apr 23, 2018 at 1:27 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Like getting the centering pin in the axle? Just gotta safely man handle that axle around.
  6. Apr 23, 2018 at 1:28 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    And yes, having both tires off with the axle on jack stands will make it easier to move it around and get things lined up.
  7. Apr 23, 2018 at 1:28 PM
    easye515
    roger that .
  8. Apr 23, 2018 at 1:29 PM
    strktly_bodysurf
    Yup, like he said, just gotta man handle it. Did you clamp your leaf pack together prior to unbolting?
  9. Apr 23, 2018 at 1:30 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I think he's doing a full leaf pack swap, so no need to disassemble the leafs
  10. Apr 23, 2018 at 1:35 PM
    strktly_bodysurf
    Oh yup, you are correct. Much easier, I believe.
    EatSleepTacos[QUOTED] likes this.
  11. Apr 23, 2018 at 1:36 PM
    easye515
    got it. thanks guys!
    EatSleepTacos likes this.
  12. Apr 23, 2018 at 1:52 PM
    SpeySquatch
    2016 TRD OR DCSB
    Bumper and winch is about 150lbs. Sliders weigh about 100lbs.
    Total gains is 2" in front and 3" in back. The overload leafs add a little xtra height
    It is the medium kit, not sure what spring
    http://www.lowrangeoffroad.com/toyo...ift-kit-medium-load-2-ometac16mksb-11399.html
    This complete kit includes:
    • 2888 - Old Man Emu Coil Spring
    • 90021 - Front Old Man Emu Nitrocharger Sport Struts
    • EL095R - Rear Old Man Emu Leaf Springs
    • 60091 - Rear Old Man Emu Nitrocharger Sport Shocks
    • OMEU53A - Old Man Emu Leaf Spring U-Bolts
    • FK29 - Old Man Emu Rear Drive Shaft Spacer Kit
    • OMESB108 - Old Man Emu Leaf Spring Bushing Kit
    • OME95PF5 - Old Man Emu Front
    • 217195 - Old Man Emu Hat
    • 216522 - Old Man Emu Decal
  13. Apr 23, 2018 at 2:12 PM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    NICE. and then you added shims I assume? did these ship free?
  14. Apr 23, 2018 at 3:13 PM
    strktly_bodysurf
    Been 2 hours. How's the install going?
  15. Apr 23, 2018 at 3:44 PM
    #35
    SpeySquatch
    2016 TRD OR DCSB
    Yes, i added shims. I had 2.5 degree, but 3 degree puts your driveline working angles darn near perfect. You want no more than .5 degree in difference of working angle to avoid vibes. The suspension did ship free. Sometimes I wish I went with the Fox front shocks to get an extra 1/2" up front, but that can come later, or I will just put Bilstein 5100's and use my same coils (cheaper)
  16. Apr 23, 2018 at 3:47 PM
    #36
    lanceputnam
    lanceputnam Well-Known Member
    Ratchet strap around the axle to the hitch in the rear or something solid up front.
  17. Apr 23, 2018 at 6:24 PM
    #37
    easye515
    hahaha. I just got the rear end done.....glad I didn't have to start at 4pm. Now I am debating if I should power through the front.
  18. Apr 23, 2018 at 9:00 PM
    #38
    medic2230
    Murph
    Bama! Roll Tide
    The rest is easy without UCA's.
  19. Apr 23, 2018 at 10:24 PM
    #39
    Scotty Dosent Know
    Scotty Dosent Know Well-Known Member
    2017 Tacoma DCSB
    Same thing here, its down right embarrassing driving through a parking lot it squeaks so bad. Literally dropped it off at the dealer today to have them fix the issues (they installed the lift) OP I would do what ever is in the link to prevent the squeaking!
  20. Apr 24, 2018 at 6:22 AM
    #40
    easye515
    OK. first front shock is on, but how do you torque that inbord nut at the top! I can't fit my wrench back there
