OME lift installed. Rear is 2.5" higher than front.
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacovic, Sep 26, 2011.
  1. Sep 26, 2011 at 1:48 AM
    tacovic
    tacovic [OP] Well-Known Member
    MN/WI
    00 4x4 TRD
    stock for now
    A friend of mines tacoma is getting bought back by toyota and I ended up buying his OME lift that was installed on his truck. We have nearly identical trucks, mine is a 00 trd and his is a 99 trd, both 4x4. We ended up just pulling the rear diff out of his truck and swapping diffs, leafs and all. The leafs are toyota factory leafs with 30k miles on them and an aal. Now when it was on his truck he was sitting pretty level although he did have 33s. Now I ended up with a big rake on my truck. I do use my truck for work and haul a 3000 pound trailer every week so i do want the rear higher than the front, but not 2.5 inches higher. It looks pretty goofy to me. I would ideally like the back to be 1-1.5" higher than the front. What can I do to achieve this? I measured from the ground to the fender and the front is at 36.25" and the rear is at 38.75" roughly.
  2. Sep 26, 2011 at 2:03 AM
    Taco4Fish
    Taco4Fish Well-Known Member
    j
    take out the aal and see how it looks now
  3. Sep 26, 2011 at 2:07 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Take the AAL off.
  4. Sep 26, 2011 at 4:23 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    My rear was pretty high at first wtih an AAL but settled quite a bit. Specially with towing a trailer, expect at least an inch settle.
  5. Sep 26, 2011 at 4:33 AM
    tacovic
    MN/WI
    00 4x4 TRD
    stock for now
    Even though the leafs were used for about 30k miles on another truck?
  6. Sep 26, 2011 at 6:05 AM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
  7. Sep 26, 2011 at 7:17 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    details on the lift. Im assuming you both had lockers?
  8. Sep 26, 2011 at 11:19 AM
    tacovic
    MN/WI
    00 4x4 TRD
    stock for now
    yes. both trd 4x4. Its the OME nitrochargers with 881s in front and nitrochargers in the rear with stock leafs and an aal
  9. Sep 26, 2011 at 6:39 PM
    CHPTR11
    CHPTR11 Team Impulse Red
    Dan
    Pacific NW
    2004 TRD Tacoma
    OME, Hankook, ARB, SCS
    That front fender height seems really low to me. I'm running the same set up on the front and my fenders are @ 37.75". I do have 267/75's, but that only accounts for an additional 0.5", so you're still sitting a full inch lower in the front.
    Hmmm, I guess I would just pull the AAL man.
