OME lift kit, anything else I might need?
Discussion in 'Suspension' started by Imageoguy, Nov 23, 2012.
  1. Nov 23, 2012 at 12:26 PM
    Imageoguy
    Imageoguy [OP] Well-Known Member
    Gatineau, Qc, Canada
    2012 DCLB SR5
    Full OME suspension (885 front springs, Dakar leaf pack + OME shocks) + D29XL extra leaf + 3 deg. shim + RideRite airbags
    Hi, I just ordered a complete OME kit for my 2012 DCab 4x4 consisting of:
    2X 885 front springs
    2X 9000 Shocks
    2X CS047R Leaf spring pack
    2X N182 Shocks
    4X OMEU53A Ubolts
    1X fit kit FK29
    Anything else I should consider for this lift kit? I heard lots of people also buy LR UCA's, are they worth it?
    I'm also planning on going 265/75/16 on tires. I'll probably build a sled deck in which case I might add an airbag system. I'll see how the Dakkars perform first with having about 1100 lbs in the bed...
  2. Nov 23, 2012 at 12:30 PM
    xgalvanxgx
    xgalvanxgx seymour butts
    Gerardo
    OC (Lake Forest) California
    TRD Off-Road BlackSandPearl 07 PreRunner
    DTF Race Kit with 2.5 x 10 Kings, DMZ SUA rear with 16" triple bypass Kings, King bumpstops front and rear, 17" KMC RG1 powdered in Matte Bronze with black ring with 37" BFG KO2s, front and rear DTF bumpers, front Fiberwerx glass and Mcneil trophy bedsides, K&N 77 Series Intake, Magnaflow, Pioneer touchscreen, Rockford Fosgate 10" sub with box and amp. Dyanamat walls, Andres' devil horn emblem, 50" D4 curved LED bar, rear chase light rack (brake, ambers, white lights) Engine brace, deleted inner wheel wells for max up travel. Cab roll rage built into bedcage.
    33's and an OME trim packer ;)
  3. Nov 23, 2012 at 12:30 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Get centre pin collars for the Dakars
    Get the OME 5mm trim packer to combat driver's side lean
    You may want to consider the d29xl OME AAL if you plan on hauling 1100lbs in the bed
    Get the LR UCA's
  4. Nov 23, 2012 at 12:31 PM
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '23 DCSB 4x4 SR5
    Yes, new UCA's would be recommended since you will get almost 3" in lift on the front. LR is a good UCA go to with. The rear..one thing i thought of adding would be extended break lines since your replacing the leaf pack instead of just adding AAL.(not sure if needed tho)
  5. Nov 24, 2012 at 7:32 PM
    Imageoguy
    2012 DCLB SR5
    Thanks guys, will get the LR UCA's and center pin collars, what thickness do you recommend? I presume the collars are just preventive if I ever need to add shims?
  6. Nov 24, 2012 at 7:33 PM
    OZ-T
    Peter North
    British Columbia
    They are generally about 5/16" tall , and yes , they are in case you need to add axle shims later
  7. Nov 24, 2012 at 7:33 PM
    OZ-T
    Peter North
    British Columbia
    And don't forget the 5mm trim packer
  8. Nov 24, 2012 at 7:39 PM
    Imageoguy
    2012 DCLB SR5
    Yup, will do!
  9. Nov 25, 2012 at 10:05 AM
    Tacodog
    Tacodog Well-Known Member
    Ron
    Renton, Wa.
    ‘19 TRD offroad DCSB Cement
    Icon stage 1, Icon upper control arms, 17” Fuel wheels,Ridge Grapplers, TRD exhaust, leather interior.
    Who did you order from?
  10. Nov 25, 2012 at 11:57 AM
    OZ-T
    Peter North
    British Columbia
    What ?
  11. Nov 25, 2012 at 6:56 PM
    Imageoguy
    2012 DCLB SR5
    ARB in Montreal (info@ouipack.com) Got the items I listed on top for $ 1080.00 + Tx. I went to pick them up at their warehouse so I didn't have to pay for shipping. I'll probably order the UCA's from FAT Bob's, they seem to have the best price.
  12. Nov 25, 2012 at 7:35 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
  13. Nov 25, 2012 at 8:45 PM
    Imageoguy
    2012 DCLB SR5
  14. Nov 30, 2012 at 11:10 AM
    timmyedge
    timmyedge Well-Known Member
    Timmy
    Layton, UT
    TRD OR DCSB
    Magnaflow cat back exhaust with down pipe, Volant CAI, BHLM w/new bulbs, 3000K replacement fog lights,Debadged/Painted/Re-badged to say TACO/ New JVC Dbl Din Nav in dash/ Fosgate 400W amp/ Fosgate 10" sub/Tacotunes box/ Order OME complete lift w/Daker springs and LR UCA's/Ordered SCS Stealth 6 Matte Gun Metal -265/70R17 Goodyear Duratracks, BAMF behind gril light bar, Custom Trial Ridge Sliders , bed mat, weathertechs, Wet Okles, All Pro Front IFS skid Plate, Plasti Dir rear bumper Future MODS-Skids IFS/Fuel tank, transfer, rear dif
  15. Nov 30, 2012 at 11:24 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
  16. Aug 7, 2014 at 6:38 PM
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    i want to do aal on my dakars as well…. i cut the center bolt to be able to fit the stock bump stop….. do you know the part # or specs for the center bolt i need?
  17. Aug 7, 2014 at 6:42 PM
    medic2230
    Murph
    Bama! Roll Tide
    Why didn't you just drill the bump stop out?
  18. Aug 7, 2014 at 6:45 PM
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    the grinder was closer :anonymous:
  19. Aug 7, 2014 at 6:49 PM
    medic2230
    Murph
    Bama! Roll Tide
  20. Aug 7, 2014 at 7:12 PM
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
