OME lift kit from Toytec questions...please help a noooob
Discussion in 'Suspension' started by osty82, Dec 30, 2012.
  1. Dec 30, 2012 at 2:58 PM
    osty82
    osty82 [OP] Well-Known Member
    NoVa
    09 TacoDBLC
    magnaflow catback
    :eek: OK....so my questions are...
    1. If I use this kit on my 2009 taco DBLC what is the ball park frt lift height i'll get w/o using the spacers on top (use if 3" wanted) cuz I dont want a full 3"....just using the OME shocks/coils????
    2. Can I get away w/ using the 884 springs or do i HAVE to use the 885's???? My idea behind this is to have a smoother ride and prob will never add a winch etc...but may do some occasional true off roading...
    I will be using the 1.5" tsb aal since I already had the dealership do the tsb service around year and a half ago..
    Thanks for any info/help:D
    Adam
  2. Dec 30, 2012 at 2:59 PM
    osty82
    NoVa
    09 TacoDBLC
    magnaflow catback
    oh and I do want some frt to rear rake as well since I do tend to haul a good amount of weight in the bed on a reg basis...
  3. Dec 30, 2012 at 3:06 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I got 2 1/2" of lift with 885's , no top plate spacers on my DCLB 4x4
  4. Dec 30, 2012 at 3:24 PM
    osty82
    NoVa
    09 TacoDBLC
    magnaflow catback
    cool...this sounds like what im aiming for....
    in your opinion....doing the frt's same as yours w/ the tsb aal 1.5" give me some rake???
    also would you recomend using the 884's for cusher ride?
    Ive been killing myself over this for entire weekend and was considering just doing 5100's x4 and the 1.5"aal setting the frt at 1.75" but i dont think that will give me the look i want in frt...
  5. Dec 30, 2012 at 3:25 PM
    osty82
    NoVa
    09 TacoDBLC
    magnaflow catback
    also did u have to do uca's w/ 2.5" or were you good on align w/o out uca's?
    sorry to be a PIA:p
  6. Dec 30, 2012 at 3:27 PM
    OZ-T
    Peter North
    British Columbia
    884's are 10mm shorter than 885's but the spring rate is the same
    Yes , I did LR UCA's
  7. Dec 30, 2012 at 3:32 PM
    osty82
    NoVa
    09 TacoDBLC
    magnaflow catback
    asuming i get 2.5" out of the 885's....do i really need to get UCA's?
    and if the spring rate is same but coil is 10mm less...then that's approx .25" less lift and may be better for angles...am i correct?
  8. Dec 30, 2012 at 3:34 PM
    OZ-T
    Peter North
    British Columbia
    10 mm is about 3/8"
  9. Dec 30, 2012 at 3:53 PM
    osty82
    NoVa
    09 TacoDBLC
    magnaflow catback
    well yea....but there is 25.4mm in an inch...so i used that as my basis to say approx .25"...or if i say .5" it would be 12.7mm...
  10. Dec 30, 2012 at 3:54 PM
    osty82
    NoVa
    09 TacoDBLC
    magnaflow catback
    regardless....my ques. still is would I really need to use UCA's if I use the 884's and no spacer....from what i can see, it doesnt seem like i will but i have no experience in doing a true suspension lift on anything
  11. Dec 30, 2012 at 3:54 PM
    OZ-T
    Peter North
    British Columbia
    Exactly
    10 mm is 3/8"
  12. Dec 30, 2012 at 3:55 PM
    OZ-T
    Peter North
    British Columbia
    No UCA's needed for 884's as you will only get 2" of lift
  13. Dec 30, 2012 at 4:01 PM
    osty82
    NoVa
    09 TacoDBLC
    magnaflow catback
    ok so we on same page for 884's...what if i do 885's? cuz i REALLY love the look of peeps tacos set this way but dont really wanna drop the $ on LR UCA's...
    and for real, im not tryin to be an ass clown about this...just tryin to get my shit straight so I know what to order
  14. Dec 30, 2012 at 4:02 PM
    osty82
    NoVa
    09 TacoDBLC
    magnaflow catback
    do u have a pic of ur taco i can see?
