OME Lift Kit Question: Height Discrepancy?
Discussion in 'Suspension' started by 28ØØ3, Mar 20, 2009.
  1. Mar 20, 2009 at 11:33 AM
    #41
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Okay here's my specs:
    Tires are 32.5"s
    Truck height:
    FDS= 39"
    RDS= 39 3/4"
    FPS= 39 1/4"
    RPS= 40 1/8"
    I have about a half of tank of gas.
  2. Mar 20, 2009 at 12:25 PM
    #42
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    I know mine i just installed gave me right at 3". I think thats after settling because mine were a little used. I think both front measurements are like 37 1/2". and thats with stock wheels and tires.
  3. Mar 20, 2009 at 3:57 PM
    #43
    S-M-R-T
    S-M-R-T Well-Known Member
    If you measure from the centre of the hub up to the fender rather then from the ground then you take out all discrepancy due to tire size, wear, pressure, etc. It is a more accurate method of measuring lift and it saves the brain work to compare different trucks.
  4. Mar 20, 2009 at 4:04 PM
    #44
    Brunes
    Brunes abides.
    Rotorhead
    Around
    While you are technically correct- I'm quite sure Chris asked for what he wanted. Either measurement can be used to work out the lift heights if you keep all those other factors more or less constant. Which most people will.
  5. Mar 20, 2009 at 4:07 PM
    #45
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Im just looking for some general lift numbers. Even if its measured from the center of the hub, people can miss the center a bit, and throw the accuracy off. But, Like I said, Im just looking for some basic numbers.
  6. Mar 20, 2009 at 4:07 PM
    #46
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  7. Mar 23, 2009 at 7:16 PM
    #47
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Like I mentioned before. My 885's gave me right at 3" after they settled in.
