OME Lift Kit Specs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vwgtiturbo, Mar 16, 2018.
  1. Mar 16, 2018 at 12:30 PM
    vwgtiturbo
    vwgtiturbo [OP] Well-Known Member
    Ron
    California
    Hi all,
    I recently decided that I'd like to give OME a shot and put one of the 'recommended' kits on my PreRunner. Going through their suspension recommendation tool, you input the year, make, and model to get your results. Now, my confusion (excuse the noob question) comes from the fact that it doesn't ask if the vehicle is a PreRunner/4x4/SR5, so I have to wonder... When the tool states that the lift will be 55mm in the front and 50mm in the back, are those numbers relative to stock SR5 positioning, or...?
    Considering the PreRunner is higher than a standard Taco, I guess I don't want to pick up the kit only to find that the lift numbers referenced relate to the stock SR5 (which means it would sit at the levels it already does, since the PreRunner is higher than the SR5).
    I wouldn't think that their numbers would indicate 55/50mm on a standard Taco, but I don't have enough faith in my thinking to gamble the money it costs to buy the kit.
    Thanks in advance!
