OME Lift Kit vs. Bilstein 6112/5160
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AnthonyGen, Dec 30, 2016.
  1. Dec 30, 2016 at 2:31 PM
    AnthonyGen
    AnthonyGen [OP] Well-Known Member
    I am ready to order a "mild" lift kit for my '16 Tacoma TRD Sport DCSB 4x4. I won't be doing any off-roading and hoping to install 275/70/17 BFG KO2's. I'm hoping for a softer ride vs stuff.
    I'm looking at ordering a complete OME kit with 888 coils and the softer valving shocks with Dakar leaf pack.
    or
    Bilstein 6112/5160 performance shocks with a Deaver AAL.
    I don't want to install new UCA's and from reading on here it doesn't sound like the diff drop is going to be necessary.
    I've read numerous lift pages on here but didn't see anything comparing these two options.
    Looking for 2-2.5 inches of lift and soft ride. Thanks for any input.
    auskip07 and DavidMietzner like this.
  2. Dec 30, 2016 at 2:41 PM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist
    Rocky Mountains
    Toyota's are awesome
    Hey Anthony,
    If you want to give us a call here at Toytec we can get you a kit that works best for your needs. Either kit will be good, the biggest difference is that the 6112 is going to be a 2.5 inch diameter shock body whereas the OME is 2.0. Both will give you about the same amount of lift. New UCA's are not necessary but i do usually recommend them for 2.5 inches of lift for the best alignment and tracking on the road. Diff drop again is not required but we all use them here and it helps more than it hurts in my opinion.
    Let us know if we can put something together for you or answer any questions.
    -Justin
  3. Dec 30, 2016 at 4:21 PM
    pra4sno
    pra4sno Well-Known Member
    Fort Collins, Colorado
    2017 DCSB OR MT. Previously 2013 DCSB SR5
    ^ Toytec makes good stuff. My Toytec Boss had exceptional on road characteristics and performed very well off road.
    Toytec Lifts and DavidMietzner like this.
  4. Dec 30, 2016 at 4:26 PM
    Sean73T
    Sean73T Well-Known Member
    Sean
    SoCal
    17 Pro
    6112 is not soft, but I do love mine from the performance aspect. If you're looking for soft just go 5100's all the way around.
    71tattooguy and DavidMietzner like this.
  5. Dec 30, 2016 at 6:17 PM
    AnthonyGen
    Thanks for the replies. So 5100s all the way around will be an upgrade from the stock shocks and provide a plush ride?Should I use stock coils or get an OME 887 spring installed and set them on the 0 clip?
    DavidMietzner likes this.
  6. Dec 30, 2016 at 7:15 PM
    DavidMietzner
    DavidMietzner Well-Known Member
    David
    I'd give @ToyTec Lifts a call and see what they can work out for you! The BOSS setup is very nice and valved specific for the weight of your Tacoma.
    The 6112's are a little more on the firmer side and the OME setup is valved and sprung a little firmer...
  7. Dec 30, 2016 at 7:18 PM
    Akroedge540
    Akroedge540 Well-Known Member
    I have 5100's all around on my 3rd gen, while I've got a lot of weight added, the ride is about the same as my stock TRD OffRoad bilsteins. I got my full kit from headstrong OffRoad and Marie really broke it down for me and got the setup I was looking for:
    Brokinarrow likes this.
  8. Dec 30, 2016 at 7:23 PM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    I can't say enough about the Boss Kit from Toytec. Wasn't sure if you had considered it yet. It rides like a dream.
    pra4sno and DavidMietzner like this.
  9. Dec 31, 2016 at 9:26 AM
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    5100s on my sport felt similar to the stock ride. I wouldn't refer to them as soft. I would consider the OME with the valving that is specifically set up to be softer. I will most likely go that route when I have some more cash. That's just my opinion tho.
  10. Dec 31, 2016 at 9:29 AM
    brich999
    brich999 Well-Known Member
    Bryan
    16 Tacoma TRD Sport AC
    all tore up already
    those saying 6112 are not soft, what are you comparing to? compared to oem sport suspension, the thing rides like a Cadillac.
  11. Dec 31, 2016 at 10:34 AM
    AnthonyGen
    I looking for a more plush ride over stock.
  12. Dec 31, 2016 at 2:51 PM
    AnthonyGen
    So, I've come up with 3 options that I'm considering.
    1. Bilstein 5100's with OME Coils, Deaver AAL, and strut assembly for $685.
    2. Bilstein 5100's with OME 887 Coils, Dakar Full Leaf Pack, and strut assembly for $950.
    3. Complete OME Kit with the 90021 shocks, 888 Coils, Dakar Leaf Pack, Strut Assembly, and DS spacer for $1,225.
    Is the Dakar Leaf Pack worth $300 more than the Deaver AAL? Is the lift in the rear about the same?
    Would I be better off going with option 1 since I won't be off roading and only doing this for a better ride and fitting 275 tires? The difference in option 1 and 3 would pay for my TRD wheels.
    If only money were no option...
  13. Dec 31, 2016 at 4:19 PM
    Blktre
    Blktre Well-Known Member
    Land of Oz....
    16 Super White DCLB TRDOR: The White Goat
    Following because I think we have around the same budget and use. Im curious what OME coils in option 1 you would consider. Im also a little torn in keeping some rake vs leveling for towing and hauling. Its possible going level and using the Dakar Leaf Pack would still work keeping the truck level even when pulling a load.
  14. Mar 29, 2017 at 7:12 PM
    Breezeby
    Breezeby Member
    Joe
    17 White SR5 DCSB 4X4
    Well I wonder what happened and what lift was purchased?
  15. Jun 4, 2018 at 1:20 PM
    StormTrooper4X4
    StormTrooper4X4 JMARTZ4x4
    Jonathan
    2017 White Trd-Off Road DCSB 4x4
    Yeah, what happened and what was purchased?
    :popcorn:
  16. Apr 10, 2020 at 9:46 AM
    wildcataz
    wildcataz Member
    2019 TRD OR
    Me too... Very curious... I have the same dilema but I'm between OME, Bilstein 6112, and Elka level 1. All for relatively the same amount of price and height.
  17. Apr 10, 2020 at 3:02 PM
    brich999
    Bryan
    all tore up already
    Love thread revivals. @wildcataz this wont be much help, thread is 3.5 years old. But 3.5 years later I still like the bilstein 6112/5160 setup on my truck
    wildcataz, Yann and 71tattooguy like this.
  18. Feb 24, 2021 at 10:50 AM
    microsnook
    microsnook Well-Known Member
    '20 TRD OR MGM MT
    UGH I cant decide between this set up either.
    Im considering the OME and 6112. Do they 6112 need to be rebuilt? How often? 80k? Guess it depends on use....
  19. Feb 24, 2021 at 11:00 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    6112s are digressive, digressive doesnt ride like a Cadillac..
    Every 10,000 to 50,000 miles depending on use.
  20. Feb 24, 2021 at 12:39 PM
    brich999
    Bryan
    all tore up already
    Have about 50k on mine, still pass the bounce test though rears have been weeping for about a year. I think the first to go will be the rear reservoir lines rotting because new england but I think they will hold out a couple more years. If I get 7 years and 80k out of them, they will have done their job and get swapped for whatever the new hotness is (8xxx bypass anyone?)
    microsnook likes this.
