OME lift kit vs. Toytec Ultimate Coilover kit
Discussion in 'Suspension' started by drjohnson36, Jul 28, 2009.
OME vs. Toytec
  1. OME Kit
    984 vote(s)
    59.9%
  2. Toytec Coilovers
    659 vote(s)
    40.1%
  1. Feb 24, 2012 at 4:30 PM
    #521
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    My mileage is the same as my 265/70/17 MT's . I've never run 285's
  2. Feb 24, 2012 at 4:34 PM
    #522
    udy2554
    udy2554 NORTHERN RED-NECK
    Naples, NY
    '06 Tacoma TRD Sport
    Toytec ULK, Light Racing UCA's, OME Dakar rear leaves, ARB Bumper with XRC8 winch, Good Year Duratracs 285/70/17's on 17x9" Level 8 Strike 6's. Leer cap in the winter. Pioneer Double Din with BT, iPod, etc. Boston Acoustic components in all 4 doors with a Sony amp, powered 8" sub. Ultra gauge, Tom Tom...
  3. Feb 27, 2012 at 12:04 PM
    #523
    Sjoffroad
    Sjoffroad Well-Known Member
    Bay area
    blk offroad pre runner
    I want to buy the ome lift kit. How do I get the discount code!?!
  4. Feb 27, 2012 at 12:40 PM
    #524
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    ^:thumbsup:
  5. Feb 27, 2012 at 1:18 PM
    #525
    Sjoffroad
    Bay area
    Thanks
  6. Mar 7, 2012 at 7:58 PM
    #526
    jdk52
    jdk52 Bro do you even 'Merica?
    Utah
    11 SR5
    3 inch OME lift kit, rear diff breather mod, cb install, sliders, brute force fab front end.
    Man..the search option is great. I had a group of die hard jeep and dodge owners swear I needed the ultimate lift kit. Then a voice of reason mentioned the OME setup on toytec. This helped me make up my mind.
  7. Mar 11, 2012 at 7:14 PM
    #527
    Gabe911
    Gabe911 Well-Known Member
    FLORIDA
    10 PreRunner MGM
    Debadged, Rear TSB, Blue LED dome and Bright White Map Lights, Hard Top Tonneau Cover, OME885 coils (no top plate spacers)OME shocks and struts, 1.5" AAL for TSB Rear,285/70/17 Trail Grapplers, 17x9 XD Addicts with 4.5 bs, Black 4" exhaust tip, Bed pocket lights, rear diff breather Mod
    I absolutely love my OME kit...highly recommend it...I was on the fence for a while and changed my mind a couple of times...this kit is easy to install and I even got 2.7" up front without top plate spacers. The ride is still close to factory and my alignment was easy to get to spec on factory UCA's
  8. Mar 11, 2012 at 7:44 PM
    #528
    OZ-T
    Peter North
    British Columbia
    What are your alignment numbers ?
  9. Mar 12, 2012 at 7:34 AM
    #529
    Gabe911
    FLORIDA
    10 PreRunner MGM
    Let me see if I can find them..will post in my build thread
  10. Mar 20, 2012 at 10:45 PM
    #530
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Finally got my OME lift on! 0 Regrets so far.
  11. Mar 21, 2012 at 11:37 AM
    #531
    4Wheelin4Banger
    Randy
    Congrats.
    I finally got around to taking the sway bar off. I wasn't sure about taking it off completely since I have a 280 mile/week commute, but I knew it would be better off road. I took it off for a trail run on Sunday and it worked great, more flex & smoother ride. On road it leans a little more in the turns but it's a truck and I drive it like one (not a sports car), mine is staying off and I would recommend removal to others. Try it you'll like it.
  12. Mar 21, 2012 at 1:00 PM
    #532
    memario1214
    Colton
    Missoula, MT
    Haha I scared. We thought about yanking it off of mine when we were putting the susp on, but decided against it... for now
  13. Mar 22, 2012 at 8:20 AM
    #533
    PDXTacoma
    PDXTacoma Active Member
    Portland
    2012 Tacoma
    To start, I have a 2012 tacoma access cab trd off-road. I am interested in lifting 2-3" and know very little about the process (other than the mass amounts of information I have read so far). I have a sungtop canopy on the back and plan on towing an 18ft aluminum jetboat (~3500lbs).
    Would the ultimate toytec lift or the OME suspension lift be better for hauling a boat? What problems might I experience? Will one setup sag more than the other under-load and once un-attached? Will towing a boat with a lift affect alignment?
    If you were to set each kit up (it looks like there are options on the toytec website for each setup) what would you get? 885 for the OME because of canopy and towing? 884 because it is an access cab?
    Aside from hunting, fishing and camping, this is my daily driver, and I don't want the lift to overly affect it. It looks like toytec is simple enough to install, but OME requires some work. What should I expect to pay for a shop to completely install the OME setup with UCA's? Is it worth paying $100 to have OME's assembled?
    I plan on getting UCA's from total chaos or toytec to avoid future problems.
    One more question. If I were to get new wheels and tires such as the procom 7089's with 265/70R17's, would you install both the lift and wheels at the same time and immediately get things aligned?
    Thanks in advance for the help. PM's are always welcome.
  14. Mar 22, 2012 at 11:24 AM
    #534
    4Wheelin4Banger
    Randy
    Give it a try on a weekend, take it out and test drive it. If you don't like it you can put it back on before you go back to work.
  15. Mar 22, 2012 at 11:54 AM
    #535
    udy2554
    Naples, NY
    As far as towing goes, I would be more concerned about the rear lift. Mine is an '06, and my rear springs (no TSB) with an AAL buckled under a half a face cord of firewood. I went with the OME rear Dakar springs, now a face cord to a face and a half is very managable. I also run a cap all winter.
    Ergo...I would think about going with a whole leaf pack instead of just an AAL. I am VERY happy with the Dakars. There is an AAL offered by OME to add to their springs if that doesn't do it for you.
    As far as the front goes, I went with the ToyTec coilovers due to the adjustability. It came in handy when I added my ARB bumper with a winch.
    Good luck with your choice.:D
    Cost I can't help you with, the shop that installed my lift traded labor with me.
    I went with Light Racing UCA's because they have the booted ball joints and I do alot of salt and snow.
  16. Mar 23, 2012 at 2:44 PM
    #536
    PDXTacoma
    Portland
    2012 Tacoma
    Would you recommend 884's or 885's?
  17. Mar 23, 2012 at 10:59 PM
    #537
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    884 for Regular cab. 885 for Access and Double cab or a regular cab with aftermarket bumper and winch. 886 for access cab or double cab with aftermarket bumper and winch
  18. Jun 14, 2012 at 4:24 PM
    #538
    OneWheelDrive
    OneWheelDrive Well-Known Member
    Peter
    San Diego/Encinitas
    2012 DBL Cab LB TRD Sport
    Just took delivery on my 2012 Double Cab Long Bed 4x4 TRD Sport, looking to pull the trigger on an Ultimate Kit. Can I get the discount code?
  19. Jun 14, 2012 at 6:47 PM
    #539
    OZ-T
    Peter North
    British Columbia
  20. Jun 15, 2012 at 2:50 PM
    #540
    TRDBeast
    TRDBeast Boogie Man Kryptonite
    Wayne
    Coconut Creek, FL
    08 Tacoma Crew Cab TRD
    Brute Force front armor with 30" rigid and dual 4" quad rigid fogs OME suspension 3" lift with Dakar leaf pack and ToyTec body lift for total 4.25 LR UCA's 9000 sport Nitro Charger shocks 885X Coils AFE Pro Dry CAI 18" Rockstars Alpine DDIN systemw/Nav, Bluetooth and DVD 2 12's Infinity Kappa's in doors and Alpine 6.5 X 9 in front and back and 2 Alpine Zeus amps rear 2 Rockford Fosgate amps front NFab running boards Dyno tuned FXRs w/ 3" Projectors and Halos retrofit w/ Apollo shrouds and 5000k HID 55W Debadged Wet Okole skins HomerTaco Satoshi grill Elusive Elements light support with 2 Hella 500ff's behind grill Powder coated tool box TRD gear shift Andres Devil Horns TREX eyelids Body Armor rear bumper 15% Tint "ZOMBIE" light switches Custom gun concealer in dash One-piece aluminum drive shaft LED interior light swap
    sub'd
    head still swimming....
