OME lift kit vs. Toytec Ultimate Coilover kit
Discussion in 'Suspension' started by drjohnson36, Jul 28, 2009.
OME vs. Toytec
  1. OME Kit
    984 vote(s)
    59.9%
  2. Toytec Coilovers
    659 vote(s)
    40.1%
  1. Jun 23, 2014 at 10:58 PM
    #741
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    subddddddddddd
  2. Jul 16, 2014 at 6:54 PM
    #742
    stphnman20
    stphnman20 Well-Known Member
    SCV
    2016 T4R
    ditto
  3. Oct 29, 2014 at 1:29 PM
    #743
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Yep
  4. Nov 4, 2014 at 1:32 PM
    #744
    drmcstford
    drmcstford The Sauce Boss
    David
    Glendora, CA
    14 Prerunner TRD OR
    Hey guys So i see a lot of people with questions, I've been researching like crazy for house, trying to soak in as much knowledge as possible! And I think I finally was able to decide I want the OME lift kit with LR UCA However I have some questions that I hope you guys can help me out with! I have a 2014 tacoma off road package and I will be doing about 90% street and about 10% off roading. I would like a full 3" Lift with a smooth ride
    1. The OME lift kit has everything I need correct (besides UCA)?
    2. Do I need a driveline spacer for vibrations?
    3. 1/4 or 1/2 spacer? I want a leveled Lift no rake if possible
    4. Will this be enough to give me clearance for 33" tires ?
    5. Do i still ad a trim packer on the drivers side on top of the spacer for no lean?
    6. Are longer brake lines required?
    7. WTF are TSB leaf springs? Are the dakars worth it for my purposes?
    I'm sorry for so many questions,
    Thanks David !
  5. Nov 5, 2014 at 1:34 PM
    #745
    TNTramair
    TNTramair Well-Known Member
    2015 TRD OR SPORT
  6. Nov 11, 2014 at 2:29 PM
    #746
    cfree5119
    cfree5119 Well-Known Member
    Doe the OME front coilovers offer lift without putting the top spacer on? Thanks.
  7. Nov 11, 2014 at 2:30 PM
    #747
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Yes
  8. Nov 11, 2014 at 2:31 PM
    #748
    cfree5119
    I am expecting about 2.5" with OME 885x (22k) on them. About right with no spacer?
    Also, with rear ome shocks and Icon Progressive AAL (no overload), do you think I will need a carrier drop ?
  9. Nov 11, 2014 at 2:35 PM
    #749
    OZ-T
    Peter North
    British Columbia
    1) depends where you buy it / what's included
    2) probably
    3) depends on what you do for rear lift
    4) depends on tire size / wheel specs
    5) yes but the OME trim packer goes under the coil , not on top
    6) depends how hard you flex it / what you do for rear lift
    7)" TSB springs " are the 3+1 pack , depends if you haul constant heavy loads or tow
  10. Nov 26, 2014 at 8:54 AM
    #750
    Bash79
    Bash79 New Member
    Paul
    Newfoundland
    05 dbl cab 6" pro comp
    Hey guys I live on the east coast of Canada and have a 05 taco double cab with a 6" pro comp suspension lift. My truck is currently caught up in the 173 rust and corrosion campagain. I have met all the criteria to receive a new frame but "toyota Canada" says that because of my aftermarket lift I am not eligible for the safety recall. I have attempted to talk to someone from toyota Canada but no response yet. Has anyone else encountered this problem??? Is this ethical business?
  11. Dec 31, 2014 at 1:43 PM
    #751
    redtacoma88
    redtacoma88 Well-Known Member
    John Austin
    TN
    2012 TRD Off Road
    See Build Page...
    Anyone have a picture of their OME lift with Dakars flexed out? Just wana see how it compares to my current setup!
    Thanks
  12. Jan 9, 2015 at 3:21 PM
    #752
    codyb1
    codyb1 Well-Known Member
    Cody
    Utah
    2015 TRD Sport DCLB
    Toytec Boss Coilovers set at 3" with AAL's,Toytec Boss Rear shocks, LR UCA's, Swaybar Relocate, Diff Drop, 265/70 Nitto Trail Grapplers, 17" KMC wheels, K&N, Limo Tint, 4.7" Shorty Antenna
    Subd good read.. Still can't decide though.
  13. Feb 26, 2015 at 6:39 PM
    #753
    Bennersj
    Bennersj Well-Known Member
    Scott
    Lehigh Valley, PA
    TRD Sport Never Ending Project
    Sub'd
    Was planning on the OME because of the Dakars and everything in one shot, but now debating on the extra money for the Icon stage 1. Is the Icon ride truly that much better to justify. Most of my driving is highways and some chitty Pennsylvania pothole ridden roads with some slight off-road and camping.
  14. Mar 19, 2015 at 8:26 PM
    #754
    12thMan
    12thMan Well-Known Member
    Terrence
    Tomball, TX
    13 DC PreRunner 2WD
    Another rookie here.
    Wow! I just finished reading every single post in this monsterous 38 page thread and feel like I have learned so much about lifts, etc. You guys are awesome! Thanks for your insight and willingness to share.
    Of course, as with any Noob, I still have a couple questions. Similar questions to those recently posed by drmcstford. I'll offer a little more info to help narrow things down.
    I have a 2013 DC PreRunner 2WD.
    I am considering the OME 3" lift kit with 885s and dakar in the rear. I will also get the UCAs to make sure the post lift alignment is on point.
    1. Do I need a top plate spacer to get the full 3"? And if so, will the dakar leafs provide enough lift in the rear to level everything?
    2. Do I need a driveline spacer for vibrations with a 2WD?
    3. Putting the Dakars in the rear, would I use 1/4 or 1/2 spacer? I want a leveled Lift no rake if possible
    4. I have 17" rims currently. Can I run 285/70/17 tires without wheel spacers? And will adding wheel spacers cause any other issues with CV joints, alignment, etc.?
    5. The trim packer is a must for no lean?
    6. Having the Dakar in the rear and not carrying loads or bigtime offroad, are longer brake lines required?
    7. Are the dakars worth it for my purposes? Or better yet, will choosing the Dakars over the AAL provide better ride?
    Thanks again for all your time and input. I am so pumped that I found TW and am excited to get my lift and post pics, etc.
  15. Mar 20, 2015 at 7:39 AM
    #755
    redtacoma88
    John Austin
    TN
    2012 TRD Off Road
    See Build Page...
    1. 885s should be right near 3" for a pre runner with no added weight
    2. Just use the CB drop the OME kit comes with. If you still have vibrations look for other options, every truck is different
    3. You could put 1/4" spacers but even then you could be over 3" of lift in the front. I would be more concerned about the performance of the kit than if it is 100% totally absolutely level
    4. If you have the stock 17" Toyota rims you WILL need to run wheel spacers with 285s. Tons of people run wheel spacers with no issues. Just make sure they are properly torqued.
    5. Go ahead and do the trim packer. It does it's job
    6. Nope, I have dakars in the rear and stock break lines, never had an issue
    7. The dakars are great! I think mine ride great on and offroad. If you want to smooth out the ride you can always remove one leaf.. Do it once and do it right, the dakars are way better than an AAL
    Hope that helps man! Lemme know if you have any other questions!
  16. Mar 24, 2015 at 6:01 AM
    #756
    zimm52
    zimm52 Well-Known Member
    sneakin up behind you
    2010 PreRunner TRD Off Road
    nothing yet!
    You might want too look at a spindle lift.
    Search for the Maxtrac thread here on tacomaworld.
  17. Mar 25, 2015 at 7:11 PM
    #757
    mainewoodsballer
    mainewoodsballer YESSAHBUD...heyut
    Ol' Waltah
    Maine
    2015 DCLB TRD Sport (Pyrite Mica)
    Check out my Build to See!
    I had the coil over and it rode like crap.... hows the OME ride?
  18. Sep 13, 2015 at 12:26 PM
    #758
    Detlman
    Detlman New Member
    Brian
    14 prerunner 2wd
    none yet
    Hey, First post...but I've been lurking/reading.
    I have a 14 prerunner v6 4 door 2wd and I want to lift it, I read 90% of this thread and thought I had decided what I want to do but now I don't know which kit to buy.
    What I do know.
    1. I want roughly 3" in front and 2 in rear
    2. ride needs to be as good or better than stock with 3" lift
    3. I am planning to get control arms also to insure alignment is correct.
    4. want to run 285/65/18's or something similar
    truck use
    Well honestly it sits in front of my house 25 or more days a month as I ride a motorcycle to work. But when I do drive it its either to work in the rain, to pull a trailer with street bikes on it or to load up a couple dirt bikes and go to the track. I don't see any off road adventures other than the trail leading to where we would ride3. I may take it for a tiny trail rip from time to time but 98% of this trucks life is on road.
    Has anyone tested the ome and the ultimate back to back? what about the toytec boss? I am more concerned with making the truck ride worse, with the only gain being looking better. I know mileage will get worse with bigger tires.
    Not looking to break that bank but not looking to be a cheapo either.
    I am 100% new to the toyota mod world, I have had many euro cars and american trucks, lifted lowered etc. what do you think will get me there and retain an oem or better ride. ( last truck was ram quad cab, 4x4, 4" lift 36 12.50's etc )
    Thanks in advance!
