OME lift kit vs. Toytec Ultimate Coilover kit
Discussion in 'Suspension' started by drjohnson36, Jul 28, 2009.
OME vs. Toytec
  1. OME Kit
    984 vote(s)
    59.9%
  2. Toytec Coilovers
    659 vote(s)
    40.1%
  1. Dec 1, 2009 at 5:36 PM
    #81
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    Might want to read the fine print. What is the "lifetime" of the shock? Is there any stipulations?
    From what one guy told me, shocks need a rebuild/replace every 3 years (I'm guessing this is dependent on your use of them). Can you bomb around like crazy on the Bilsteins and get them replaced free of charge when they need regular maintenance? I'm guessing no.
  2. Dec 1, 2009 at 6:00 PM
    #82
    ikataco
    ikataco Well-Known Member
    06 DC Sport
    Yes, of course there are stipulations, as with most warranties. Any signs of abuse will void warranty for Bilstein & OME shocks. Bent, broken, gouged piston rod.
    I had Billy HDs on my old Toyota 1/2 ton pickup. This was my work truck, hauling & going to job sites. The rear shocks died after 4 years, about 82k miles. I sent them in. Bilstein sent back new HD shocks. The shocks were not abused, just USED.
  3. Dec 4, 2009 at 12:37 AM
    #83
    rcrick263
    rcrick263 Well-Known Member
    Utah
    06 TRD Off Road 6spd
    None
    Why is the toytec ultimate easier to install than the ome?
    The 5100 are adjustable? Would it screw with your alignment every time you adjust them?
  4. Dec 4, 2009 at 2:12 AM
    #84
    ikataco
    06 DC Sport
    Front shocks come fully assembled, shock, spring, & shock mount. With the OME kit, the factory shock mounts must be removed & installed on the OME setup.
    Only the front shocks. Standard 5100 have 4 settings for spring perch height. The Ultimate kit is an adjustable coil over with spanner wrench. Adjustable without removing entire shock assembly from vehicle.
    Generally, Yes.
  5. Dec 4, 2009 at 6:03 PM
    #85
    rcrick263
    Utah
    None
    So installing the toytec ultimate kit would not require a spring compressor, correct?
  6. Dec 4, 2009 at 6:10 PM
    #86
    ikataco
    06 DC Sport
    Yes, correct.
  7. Dec 4, 2009 at 10:45 PM
    #87
    rcrick263
    Utah
    None
    Sweet! Thanks!
    I'm getting the Toytec Ultimate.
  8. Dec 7, 2009 at 4:48 PM
    #88
    taco157
    taco157 Active Member
    Brian
    Nova Scotia, Canada
    06 D-cab White
    2.5" Lift
    Do your 285's rub at all with that kit??
  9. Dec 11, 2009 at 10:39 AM
    #89
    wilsonpj
    wilsonpj Well-Known Member
    Pete
    Charleston, South Carolina
    2006 DC, SB, OR
    OME 3in Lift, LR UCA's, 33in DuraTracs, All-Pro Full Skids, TRD CAI & Cat Back, 16x8 KMC Enduros
    ditto... do they rub? what wheels are those? I assume they have back spacing?
  10. Dec 14, 2009 at 6:33 PM
    #90
    elliott.estes
    elliott.estes Well-Known Member
    sacramento
    07 Black DC TRD Sport
    In Dash Avic-D3 / Blacked out headlights / Satoshi Grille / OME 90000 Front Shocks/ OME n182 Rear Shocks / OME 885 Coils / AAL with TSB's / 10MM lift Enhancer Kit / Light Racing UCA's / BFG AT KO's (285x70x17's) / Procomp 7089 Rims
    Thanks for all this information.. After reading this entire post I am still confused on which one is better. So can i ask this question, i DJ and have to fill my entire bed with DJ Equipment. Does a lot of weight play a role in what type of lift you should get?
    And 90% of my driving is city/street and 10% off road.
  11. Dec 14, 2009 at 7:25 PM
    #91
    98lowflyingtacoma
    98lowflyingtacoma Well-Known Member
    Phoenix
    1998 Tacoma Prerunner
    the thing i like about the OME is that they field test the hell out of them... they seem to be the closest thing to stock with minimal adjustments and a much higher perforamnce.
  12. Dec 15, 2009 at 10:59 AM
    #92
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist
    Rocky Mountains
    Toyota's are awesome
    Upgrading springs and shocks is always a better choice over spacers.
    No, your rear load capacity does not play a role in which kit you get since we recommend only the AAL for the rear lifting option with the Tacoma's.
    I would go with a spacer to try out lifting your truck, I've got a 3 inch spacer on my of my forum.
    See what you think. If you don't like, you can upgrade..
  13. Dec 15, 2009 at 1:04 PM
    #93
    Drock42
    Drock42 Well-Known Member
    Derek
    Albuquerque, NM
    09 TRD Sport 4x4
    Toytec Coilovers, LR UCAs, OME Dakar leafpacks w/5100s, 18" 951s, 285/60 TGs (6ply), Grillcraft MX upper & lower, Wet Okole seat covers, Rec-rac bike racks
    I soaked up as much info on this topic as I could before making a decision. What it came down to, for me, was the adjustablity of the Toytec coilovers. I had heard that the OME ride was better (smoother), but I still felt being able to dial the height to exactly where I wanted it was more important. Though I did opt for the OME Dakars for the rear. So I guess I just split it down the middle. Best of both worlds. :D
    How do I feel now that it's on the truck? I couldn't be happier. The ride is great and I feel the truck drives better than it did when stock. Between these two setups I don't think there is a bad choice. If price is your consideration: go OME. If you want some room to adjust for stance or tire size: Toytec's the way to go. Other than that it's just a coke vs. pepsi kind of thing.
    The guys at the shop that installed mine said they'd seen alot of OME lifts for our trucks. This was a first for the Toytecs and they said they were impressed. Regardless, I am really happy with my decision and feel all the damn time I spent researching paid off. Yes, I drove my fiancee crazy, but she's loving it too. :cool:
  14. Dec 17, 2009 at 10:55 AM
    #94
    4X4 aggie '13
    4X4 aggie '13 Well-Known Member
    College Station, TX
    09 4x4 TRD OR
    3" toytec spacer lift, n-fab steps
    im going to go with Toytec. Should i get their UCAs too? or will i be ok?
    This post helped a lot thank yall
  15. Dec 17, 2009 at 10:58 AM
    #95
    Brunes
    Brunes abides.
    Rotorhead
    Around
    DOn't think Toytec has UCAs- but if you plan on cranking the Toytec coilovers up to 2.5 or greater...You should think long and hard about getting some sort of UCA.
    LR has been getting alot of good results recently for cheaper than TC's....I love my TCs...It's all a matter of opinion.
  16. Dec 17, 2009 at 11:00 AM
    #96
    4X4 aggie '13
    College Station, TX
    09 4x4 TRD OR
    ok I read up some more about UCAs and I feel I should get them thank yall for all the help!
  17. Dec 17, 2009 at 12:36 PM
    #97
    Drock42
    Derek
    Albuquerque, NM
    09 TRD Sport 4x4
    X2
    I went with the Light Racing UCAs and am very happy with them.
  18. Dec 17, 2009 at 4:12 PM
    #98
    Toytec Lifts
    Rocky Mountains
  19. Dec 17, 2009 at 4:14 PM
    #99
    Toytec Lifts
    Rocky Mountains
    The tacomas can go either way. But if your real picky or you just insist on having everything exactly perfect for alignment, you should get them.
    They are a nice addition.
  20. Dec 17, 2009 at 5:53 PM
    #100
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Didn't realize Toytec = LR....My bad!!
