OME lift kit vs. Toytec Ultimate Coilover kit
Discussion in 'Suspension' started by drjohnson36, Jul 28, 2009.
OME vs. Toytec
  1. OME Kit
    984 vote(s)
    59.9%
  2. Toytec Coilovers
    659 vote(s)
    40.1%
  1. Dec 17, 2009 at 6:04 PM
    #101
    4X4 aggie '13
    4X4 aggie '13 Well-Known Member
    College Station, TX
    09 4x4 TRD OR
    3" toytec spacer lift, n-fab steps
    sweet i'm going to wait a bit for the ucas but definitely getting the toytec ulk and me and my dad are going to put it in hopefully this christmas break so i can show it off next semester haha :)
  2. Dec 17, 2009 at 6:21 PM
    #102
    TX TRD Runner
    TX TRD Runner Well-Known Member
    Timothy
    Republic of Texas - Anna
    2007-Double Cab-Long Bed-SR5-TRD-Sport-4x4
    Toytec 3" Spacer Lift Kit w/AAL's - Spidertrax 1.25" Wheel Spacer - Stock 17" TRD Sport Wheels painted Black
    Here is where I am at. I am ready to order my lift kit and tires.
    I am going OME. I want the med coils because I want a nice stiff front end, but don't plan on a bumper.
    I am going with the spacers to get the full 3 inches up front.
    I am still stewing over the AAL or the full new pack of leaf springs.
    I spoke to the guy at Discount Tire today who suggested BF Goodrich All-Terrains 285/70R17's. He swore up and down I would have no problems with rubbing unless I plan on getting my truck airborne...which has happened before, but that is another story.
    Any thoughts or opinions are welcome.
  3. Dec 17, 2009 at 6:34 PM
    #103
    CJH9980
    CJH9980 Well-Known Member
    Clint
    Shreveport, LA/Tucson AZ
    2018 TRD PRO
    Wescott lift Wescott rock sliders Prinsu Cabrack SpartanXcustoms skewp light Demon Hook front recovery point Diamondback SD (just shipped) N2 Designs Remote Start A few meso goodies
    Are u putting the 285s on stock rims?
    Any thoughts or opinions are welcome.[/QUOTE]
  4. Dec 17, 2009 at 6:35 PM
    #104
    TX TRD Runner
    Timothy
    I am. I love my rims.
    Anything to look out for? Any problems?
  5. Dec 17, 2009 at 6:35 PM
    #105
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    They sell them....I dont think they make them..
  6. Dec 17, 2009 at 6:39 PM
    #106
    CJH9980
    Clint
    2018 TRD PRO
    I just finished my lift today,
    5100s all around w/ fronts @0.85
    eibach 1.6" springs
    toytec 1/4" top plate spacers
    2" AAL
    LR UCA
    I went by the tire shop and the guy said I'll probaly still have a little rub with 285s on my stock rims. We're doing a fit test tomorrow, I'll post how it goes
  7. Dec 17, 2009 at 6:41 PM
    #107
    TX TRD Runner
    Timothy
    My main reason for posting is this. I want to go with the OME kit. What I don't want to happen is a bunch of other shit I need that no one tells you about.
    Will I need anything to go with this set up that is not in the kit?
    I hear about wheel spacers, new UPC's, etc.
    Just curious
  8. Dec 17, 2009 at 7:10 PM
    #108
    CJH9980
    Clint
    2018 TRD PRO
    well, I'm by no means an expert, but I was goin for 3" and ended up with just a little over 3 up front. The truck is almost dead level, and after things settle a bit I'm pretty sure it'll be perfect.
    I was on the fence about the UCAs but decided to get them now instead of have a problem later. I did not get the diff drop kit, and thus far have not had any vibes at all, in 2wd or 4wd.
    My VSC is acting crazy so I'm going to have to take it in for calibration.
    My only problem is that the stock trd offroad rims/tires look too small now. Tomorrow I'm doing the fit test with the 285s. If I can keep the stockers I will...if not I'll get some moto 951s
  9. Dec 17, 2009 at 7:59 PM
    #109
    TX TRD Runner
    Timothy
    What is a VSC?
    I am a bit of a noo B :cool:
  10. Dec 17, 2009 at 8:10 PM
    #110
    CJH9980
    Clint
    2018 TRD PRO
    Vehicle Stability Control...the button on the left side of your steering wheel that has the squiggly tire tracks. It manipulates the brakes to keep you from losing control, if I understand it right
  11. Dec 17, 2009 at 8:23 PM
    #111
    TX TRD Runner
    Timothy
    I think your 16's will look fine with the 285's.
    Thanks for info on the VSC.
    I think I am going to leave out the differential relocation kit. I can always get it later if there is a problem.
    The UCA's are out of my budget to do now, but may consider them later.
    I am just going with the OME and tires for now. I think I am going to upgrade and get the full leaf pack from OME. I know it is alot, but I think it would be a nice upgrade.
    CJH9980, when you say almost level...is the front up or the back up higher than the other?
  12. Dec 17, 2009 at 8:49 PM
    #112
    CJH9980
    Clint
    2018 TRD PRO
    definitely stay within your budget, you can always add UCAs later if you need them, and you may get lucky and not need them.
    Mine is slightly higher up front. You can't tell by looking at it. It's about 1/8 of an inch when measuring @ the wheel wells
  13. Dec 18, 2009 at 8:25 AM
    #113
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    From my readings, the difference between an AAL and full replacement is that the AAL adds a bit more bed capacity than stock, the full replacement adds a bit more articulation and adds more bed capacity than AAL. However, you must be careful in that some setups will actually degrade bed capacity. If it's more important to have capacity than it is to have lift, then go airbags or consider a larger truck.
    Regarding 285's, it is almost certain that there is trimming involved (fairly easy job), and you would need aftermarket rims or will need wheel spacers to avoid rubbing the UCA.
    When I'm headed out for tires, I'm looking at a 265 since I don't want to deal with the hassle, and they may prove better for what I want to do with them.
    BTW, VSC didn't debut until '09. ;)
  14. Dec 18, 2009 at 8:35 AM
    #114
    TX TRD Runner
    Timothy
    Thanks, Mike.
    The guy at discount tire is going to try out both the 275's and 285's to see what will work best. If I have to get the spacers, I think I will because I am partial to the look of 285's. The other thing with the 285's I like is, you effectively get a 4" lift with the amount of sidewall plus the 3 from OME kit.
    I am looking at doing the OME full upgrade. I trust it will give me a very dependable bed load as well as a firm tail end. I am also very adamant about NOT having a sagging rear end...not today...not in five years from now. I drive the truck like I stole both on and off road.
    Thanks for the info about the VSC...mine is an '07 so I guess I won't have to worry about that.
  15. Dec 18, 2009 at 8:42 AM
    #115
    wilsonpj
    wilsonpj Well-Known Member
    Pete
    Charleston, South Carolina
    2006 DC, SB, OR
    OME 3in Lift, LR UCA's, 33in DuraTracs, All-Pro Full Skids, TRD CAI & Cat Back, 16x8 KMC Enduros
    You could still get 285's or as I like to call them 33 in tires and keep the stock width at 10.5 inches...
    I don't see why you would need new wheels with back spacing or spacers if all you are changing is the height of the tire and not the width....?
  16. Dec 18, 2009 at 8:46 AM
    #116
    TX TRD Runner
    Timothy
    Yeah...no way in hell I am buying new wheels. I love my stock 17's. :cool:
    Once I get lifted and get down to discount tire, I am sure it will all work out.
    I will start my own build thread too to show the progress.
    The only thing I dread is the drive from Anna to McKinney after the 3 inch lift with those little, worn down, Dunlop 265's (only a ten minute drive though). :D
  17. Dec 18, 2009 at 9:13 AM
    #117
    Chickenmunga
    Keizer, Oregon
    I thought a 33x10.5 was most common for 15" rims?
  18. Dec 18, 2009 at 9:18 AM
    #118
    wilsonpj
    Pete
    2006 DC, SB, OR
    It could be, everyone says on here that you need spacers or new wheels with back spacing if you lift it and get new uca's.
    I assuming that is when you are running a 11.5 in or 12.5 in tire.
    I have not heard about anyone with 3 in lift, new ucas, running stock wheels and 33x10.50 tires.
  19. Dec 18, 2009 at 9:33 AM
    #119
    Chickenmunga
    Keizer, Oregon
    Correct, the tire everyone keeps trying to fit is a 285/75/16 or 285/70/17, which is basically 33x11.5
    I don't think UCA plays into clearance issues.
  20. Dec 18, 2009 at 9:52 AM
    #120
    TX TRD Runner
    Timothy
    I am going with the OME 3" lift and plan on 285/70/17R's. After talking to my mechanic and the manager at Discount Tire, I do not anticipate any problems.
    From what I have gathered, people experience problems when they increase width of tires, do not reach expected lift to clear tires, or experience rubbing during extreme 4x4ing.
