OME lift kit vs. Toytec Ultimate Coilover kit
Discussion in 'Suspension' started by drjohnson36, Jul 28, 2009.
OME vs. Toytec
  1. OME Kit
    984 vote(s)
    59.9%
  2. Toytec Coilovers
    659 vote(s)
    40.1%
  1. Dec 28, 2009 at 3:32 PM
    #141
    Drock42
    Drock42 Well-Known Member
    Derek
    Albuquerque, NM
    09 TRD Sport 4x4
    Toytec Coilovers, LR UCAs, OME Dakar leafpacks w/5100s, 18" 951s, 285/60 TGs (6ply), Grillcraft MX upper & lower, Wet Okole seat covers, Rec-rac bike racks
    The spacer with the OME kit is just a minimal one (1/4"). The trim packer is even less (5mm). If I understand it right, the spacers used to lift the truck reduce the amount of suspension travel. Thus reducing ride quality and so on. I'm pretty sure I have that right, but if I don't, someone will be along soon to straighten us out. :D
  2. Jan 3, 2010 at 2:08 PM
    #142
    Jimirich
    Jimirich Well-Known Member
    Hawaii
    08 4x4 Dbl cab shorty O.R. pkg
    DTRL, Debadged, Donkey tethered in the bed that rips 142 db farts so I can piss off the neighbors and rattle the windows on my house when I'm parked in front.
    The operative word in the description of the Toytec kit is ADJUSTABLE.
    I am now at the point where my front end has settled in and I am going to lift the front coilovers a little more to level out the truck. since I did not have the front end installed at the full three inches, I can lift the front end a little more with a spanner wrench. No further disassembly or assembly required.
  3. Jan 3, 2010 at 9:33 PM
    #143
    Tacomamoose
    Tacomamoose Well-Known Member
    Austin
    Fort Collins, CO
    06 trd sport doublecab debadged
    debadged Tinted windows
    ok im in the same boat.. im at stock right now and i do 50-50 street and dirt/gravel want something that i can do some good offroad stuff in help please?
  4. Jan 4, 2010 at 4:55 PM
    #144
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist
    Rocky Mountains
    Toyota's are awesome
    What's your budget?
    PM sent.
  5. Jan 4, 2010 at 5:12 PM
    #145
    2009Taco
    2009Taco Well-Known Member
    Northern Virginia
    2011 Highlander
    i'm with Tacomamoose as well. looking for a decent lift kit that won't require major mods to the Taco besides some trimming for tire rubbing.
    thanks
  6. Jan 4, 2010 at 9:51 PM
    #146
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    I spent a significant amount of time doing research, and I went with a OME setup.
    -I have pictures here and here. Yes, I'm still running stock tires.
    -Cost of material, shipping, and front spring assembly was approximately $850 for my setup.
    -From my research, OME continued to show better build quality and performance. Considering that I wanted something that was more than looks, I had my mind made up.
    -For on-road driving, comfort has either increased or is about the same. If anything, I would say things are more responsive.
    -I don't see a need for adjustments. I haven't done any measuring, but I don't see any 'Taco lean', or it's so insignificant that everyone needs to be bitchslapped. Maybe it's something that happens over time... As far as rake, my truck was born with a slight rake. Most vehicles have a rake. in any case, it's such a slight thing that people really need to consider why they dumped the extra cash on that when they could have bought sliders, stereo mods, or been that much closer to some new rims/tires.
    -Installation was time consuming, but as long as you have basic tools and a good socket set, it seemed straightforward. I would recommend having some help on the front install, trying to fit in the longer shocks takes some prying. Driver's side went in real nice, but passenger side for some reason was a bit more difficult. We disassembled enough pieces to get the LCA to move freely, then I stood on the disc brake, another guy used a pry bar, and a third guy maneuvered the shock in place. Sounds hard, but it's really just using some muscle.
    -Anyone with install worries should invite forum members from their area over to help. We had a guy post up that he needed help, and within a day he had two available garages and nearly 20 volunteers.
  7. Jan 5, 2010 at 8:32 AM
    #147
    Toytec Lifts
    Rocky Mountains
    How large a tire do you want to go?
    And what is your budget for the project?
  8. Jan 5, 2010 at 8:44 AM
    #148
    2009Taco
    Northern Virginia
    2011 Highlander
    i'd prob be fine w/ 33's or similar size, probably on either 17 or 18's, but if a 16 would be better for whatever reason, i am open to that as well.
    as for budget, i don't really have one, i'd rather get a quality product at a good price than the cheapest one available or the best for XXX amount. i haven't really shopped prices, so i'm not even sure of the true range of prices, so i'd guess i'd need to know that before i gave a price.
    i will say i want a good onroad ride as this is currently my daily driver and i won't be going off-road all that often.
    so hopefully based on all of this you can determine a good setup for me. if i need to clarify anytjhing or you have additional questions, please let me know.
    thanks!
  9. Jan 5, 2010 at 8:52 AM
    #149
    Stillfly199
    Stillfly199 ( . )( . )
    J.D.
    Bro Capital of the word
    2010 FJ Cruiser
    With the 886's do you need the top plate spacer to get the full 3"? I thought I read somewhere you didnt need it with the 886's?
  10. Jan 5, 2010 at 10:27 AM
    #150
    Chickenmunga
    Keizer, Oregon
    A smaller rim size would be better for offroad driving, as this gives you more rubber. Since you are on-road, you don't need to care as much. The main concern is backspace on the rim or purchasing wheel spacers to correct rubbing the UCA, etc., as you move to a wider tire.
    Your 3 categories for the front is basically OME, Bilstien, or (for lack of a better term) high-performance coilover, such as King, Fox, ICON, SAW.... Since you are mainly road use and won't be pushing things really hard, the high performance coilover category is unnecessary. OME or Bilstien are your two categories to focus on (well, there's some other choices in there, but they aren't as common and I didn't get much research - such as Revtek).
    Either choice should perform admirably on-road, but my votes lie with OME. From my readings, I get the impression that the front Bilsteins are trying to cover too many categories on too tight of a budget. They want to compete with lower-priced lifts, but have the adjustment you see on the high-performance coilovers. As a result, they don't perform as well offroad as the competition, and the adjustment pieces are somewhat cheap. However, these issues should not totally deter you - you won't notice a performance issue on-road, and the need to adjust is kind of a 'set it and forget it' sort of deal.
    NOTE that this is merely what I have seen from ~3 months of reading other people's experiences, so I'm not an authority - I urge you to prod at these issues yourself.
    For the rear, you need to focus more on what you are doing with leafs. Are you doing an AAL? Full replacement? Progressives? Airbags?
    -A quality AAL is the common choice. Getting a bad AAL will actually reduce cargo capacity, good ones will either add or have a net effect of no capacity change. Either way will provide lift. For my personal setup, I had the TSB springs installed and purchased my AAL from Wheeler's Offroad, which is supposed to up my bed capacity.
    -A full replacement is a step above the AAL. It adds the capacity, plus gives you better articulation. Articulation is really only important offroad, and depends on how much you really need that extra flex. At this point, if I jack up one side of the rear of the truck, put about a 1.5' tall block under the frame near the rear tire, then remove the jack, my tire will touch the ground. I didn't have more wood sitting around to test any further, but you get the idea.
    -Progressives i haven't done any real research on, but my understanding is it's a step a bit above a regular AAL.
    -airbags are the end-all-be-all of adding bed capacity. I don't know if you can add this to a lift, but if you need to haul elephants in the bed, here's a starting point.
    As mentioned, I don't think you will have a problem either way.
  11. Jan 5, 2010 at 10:34 AM
    #151
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    20 Gladiator Rubicon
    Steersmarts Draglink, Tie rod, Track Bar
    I believe you would be okay, not sure what kind of weight you have added to your truck. If it begins to sag just throw on the spacers.
  12. Jan 5, 2010 at 12:54 PM
    #152
    Stillfly199
    J.D.
    2010 FJ Cruiser
    Eventually might be putting on a ARB and winch, so probably need to go with the top plate spacers, right?
  13. Jan 5, 2010 at 1:27 PM
    #153
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    I wouldn't put the spacer on until you get the ARB and winch. I have all pro front bumper on and with the extra weight I'm still getting more the 2.5" of lift in the front. I'm at 38 5/8 to the bottom of the fender with 265/70/16 tires on. Just wait on the spacers, I kind of wish I didn't get the 886 now because i have about 2-3 inches of down travel before my shocks or UCA's bottom out. Oh and FYI, you can't use the crappy spring compressor form auto-zone on the 886, they will need to be assembled by a mechanic. I paid a shop down the street $50 to do mine.
  14. Jan 5, 2010 at 3:25 PM
    #154
    Stillfly199
    J.D.
    2010 FJ Cruiser
    If I go this route, which I probably will, I am either going to get the 886's, spacer, and bumper all at once, OR I will just get 885's for now and down the road jump up to the 886's when I get the ARB
  15. Jan 5, 2010 at 5:01 PM
    #155
    Masada
    Taylor
    Laveen, AZ
    I can't even imagine putting spacers on mine, I would have 0 down travel. I think the ARB bumper is heavier though so you might be able to get away with it, but let a shop assemble them for sure.
  16. Jan 5, 2010 at 5:33 PM
    #156
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Talk to Mountainwolfpup. he is running the 886's with an ARB and a wnch. I belive he has no spacers.
  17. Jan 5, 2010 at 7:27 PM
    #157
    Stillfly199
    J.D.
    2010 FJ Cruiser
    MOUNTAINWOLFPUP!!!!!!!!! Ok maybe i'll PM him :D Thanks
    Edit: I looked at his post, he isnt running the spacer,, but only has 2" of lift. I already have 285's on so I am probably just going to do the 885's. Hopefully the lift will just be temporary
  18. Jan 7, 2010 at 11:16 AM
    #158
    cdn_bacon
    cdn_bacon Well-Known Member
    Christopher
    Houston
    07 Tacoma Dbl Cab short box 4x4 TRD
    Slim's HID 6000k headlights and fog lights; Redline hood and tailgate struts, TRD CAI
    First I apologize if this post has been beaten to death more times than people can count but if someone can spare a min to answer some noob questions.
    truck is '07 4x4 and i want to put a 3" lift on. I'm pretty sure I'd prefer to go the route of OME kit however is it everythign you need for the lift or are there any extra's? (I just recall on the 2nd page of the post someone posting about spacers and other misc parts bring the total cost up around $900).
    Do you need/recommend UCA's right off the bat or install, drive and see if you need them?
    Do you need to drop your fwd diff? What if you don't do it?
    For me...my driving is 90% street, 10% dirt although i'd like to eventually get into more offroading but i know it probably won't happen with the little free time i have but I don't mind paying for quality ride over ease of assembly. I think i might try putting this on myself although being mechanically inclined I have very little exp with auto's....would you recommend OME to do myself or take to a shop? Is there an online install guide anywhere?
    Help!
  19. Jan 7, 2010 at 11:46 AM
    #159
    Stillfly199
    J.D.
    2010 FJ Cruiser
    Well, you can get away without UCA's, but in order to get your alignment as perfect as possible you would want them. If you get the complete OME 3" kit, it comes with everything you will need. I believe Chris4x4 is saying you do not need the Diff drop. If you have someone that can help you that knows somewhat what they are doing you should be able to do it. The only thing is you will need to rent a spring compressor to assemble the coilovers.
  20. Jan 7, 2010 at 2:11 PM
    #160
    Chickenmunga
    Keizer, Oregon
    Some places sell kits, other sites require you to pick out the pieces. Here's what I bought from Wheeler's to give you an idea of all the components:
    OME N140S Front Shock Set
    OME 885 Coil Set
    OME N182 Shock Set
    OME FK29 Driveline Packer Kit
    2005-Current Tacoma 1.5 Lift Rear Leaf Set ACH22
    DAY BU30000 Stud Kit and 10mm top spacers (this is usually sold together, Wheeler's calls it a 'lift enhancer kit')
    Beyond what I have posted, you may need rims or wheel spacers as you move to larger tires (of course, that's dependent on the tire you choose).
    The worst that is going to happen is that you will cause unnatural wear on the tires.
    This is more a concern for 6" lifts to correct the angle of the CV joint. By lifting, you change that angle, causing more wear and tear. For the 3", the change is minimal and doesn't warrant the need for a front diff drop. It is better to not get the drop at this point because you would otherwise loose clearance and spend money on unnecessary stuff.
    You probably SHOULD get the driveline spacer, though, to reduce chance of vibration in the driveline. It's a $12 part and installs in ~5 minutes.
    The only install difference I see between an OME and a Bilstein is that the Bilstein fronts are preassembled. This becomes a moot point though: I had my local shop do the assembly for $50, which was chump change considering the work needed. Other than that, it's the same process.
    Here's a video on how to install on a Tundra... pretty much same process
    http://www.youtube.com/watch?v=kdh0I_KA7ZY
