OME LIFT KIT w/ LIGHT RACING UCA ALIGNMENT SPECS
Discussion in 'Suspension' started by plee33, Mar 4, 2011.
  1. Mar 4, 2011 at 12:07 PM
    plee33
    plee33 [OP] Well-Known Member
    Peter
    Sacramento, CA.
    SWB TRD Sport Long Bed 4x4
    SnugTop SuperSport Shell, BedRug, OME Heavy Duty Lift Kit, Weathertech Liners, more to come....
    I just got my OME lift kit on the other day. Slapped on a pair of Light Racing UCAs also. Got my alignment done at Sears today. How are my alignment specs? Where should my specs be since the geometry of the truck has been altered with the lift kit? Attached photos of my alignment specs.
  2. Mar 4, 2011 at 12:14 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Subbed
  3. Mar 4, 2011 at 12:20 PM
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    If I understand it correctly, they where just adjusting the "before" numbers to between the "specific" numbers to correct the alignment. The "actual" numbers you have right now are all between the "specific" numbers so it should be good.
  4. Mar 4, 2011 at 12:25 PM
    plee33
    Peter
    Sacramento, CA.
    From what chris4x4 said alignment specs should be,
    camber: 0
    toe: 0
    caster: 2.4-3.1
    With my light racings on, shouldn't I be closer to 2.4 on caster or do I have to make a "special" request?
  5. Mar 4, 2011 at 12:27 PM
    Drunknsloth
    Retribution
    South West
    I would guess that it has to be requested, but don't quote me on that
  6. Mar 6, 2011 at 1:42 PM
    revhappyleon
    revhappyleon Well-Known Member
    Manny
    Tampa near macdill
    07 Prerunner V6 6-speed(custom dual exhaust)
    dual exhaust, foglight anytime, satoshi, chlm, aux backup lights and electric fan conversion
    your fine where you are from the numbers it shouldn't pull so unless the steering wheel is off center or it wanders on the freeway it's near perfect
  7. Mar 6, 2011 at 1:51 PM
    Sprink669
    Sprink669 Well-Known Member
    I have the same set up as you. I told the tech that I had adj. joints and I got my truck back and I have 2.2* left and 1.8* right front CAMBER settings. Caster and Toe are at 0*. My steering wheel was slightly cocked and they fixed that but I have been following this post http://www.tacomaworld.com/forum/su...r-lr-uca-install-will-more-castor-help-2.html
    I do have some bump steer but not all of the time. I am going to go back and tell the tech (who never touched the adj. joints) that he needs to do it over again. I am going to have them set at 3.0* of Caster.
  8. Mar 6, 2011 at 2:03 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    Subbed
  9. Mar 6, 2011 at 2:04 PM
    raswank
    raswank Well-Known Member
    Rick
    Auburn,Ma
    2010 Tacoma Double Cab 4x4 6 speed
    Grillcraft, Rear leaf TSB, 5100's at .85, with Eibachs, 265/70/17 BF Goodrich AT/S Tires, Hella 500's behind Grill, Kenwood KDC X995 H/U all Boston Acoustic speakers, JL Audio subs, Kenwood XR5 S amp, ATX Chrome 17x8 wheels
    So I get my Eibachs, 5100's, 1/4 inch Drivers spacer, and Light Racing UCA's put in Tuesday. What should I tell the guy to get my alignment to? He did my front 5100's already, and the alignment was awesome. Never wandered, nothing. I could let go of the steering wheel and it would go straight. So let me what specs Chris 4X4 and I will make sure it is done. Thanks for all your time.
