OME lift options
Discussion in 'Suspension' started by Sprink21, Feb 5, 2011.
  1. Feb 5, 2011 at 10:15 AM
    Sprink21
    Sprink21 [OP] Well-Known Member
    Jon
    Vancouver, WA
    2010 dbl cab 4x4
    K&N Intake, AirAid Throttle Body Spacer, Banks CatBack Exhaust
    Im goning to buy the OME lift from ToyTech in a couple of weeks and wanted to get some input on the options that I can add to the kit. I can't afford both the rear leaf pack and uca's right now and was woundering what one you think is most important. thanks
  2. Feb 5, 2011 at 11:51 AM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    UCA are not necessary to get a perfect alignment. The kit comes with diff drop, cb drop and trim spacer. You will need top plate spacer and 885 coils to get full 3" lift for Double Cab. If you develop vibes, take off the diff drop and see if that helps. You will also need 2" AAl in the rear. Check out wheelers off-road, they have great prices as well as Toytec. If you had to choose, go with the AAL and UCA, or just do the Dakar Leaf Pack and ditch the UCA.
  3. Feb 5, 2011 at 12:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    There is not enough Caster in the front geometry to allow for 2+ * of caster after lifting 3". You need aftermarket UCA's to get the alinment back in check. Also, the 885's are giving 3" lift without the top plate spacer.
    OP, DO NOT install the diff drop. It does virtually nothing to change the angle of the front CV's.
  4. Feb 5, 2011 at 12:19 PM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    If you plan on mostly onroad driving (of course you are you got a 2010) Light raceing UCAs are the way to go ZERO maintance....That's what I plan on doing along with 885 coils, and a Toytec TSB AAL, OH and don't forget extended brake lines.
  5. Feb 5, 2011 at 12:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Extended brake lines arent nessessary.
  6. Feb 5, 2011 at 12:32 PM
    kinetik873
    kinetik873 Well-Known Member
    Josh
    Springfield, Va.
    '08 TRD
    OME 3" lift, ARB bumper,DTRL, CB radio in console, 5lb fire extinguisher in bed. SockMonkey decals, Allpro rear bumper, UWS 42" bed box, Wet Okoles all around, snorkel, Pioneer Av3200, ..yadda yadda yadda
    Are you planning on putting on an aftermarket bumper? If so, then get the 886 coils.
  7. Feb 5, 2011 at 1:24 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    Op listen to Chris4x4....the smartest guy here. He knows alot more than almost everyone here.
  8. Feb 5, 2011 at 2:07 PM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    +1 on Chris4x4's knowledge of the Tacoma. Second to none IMO.
  9. Feb 5, 2011 at 2:11 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    x3
    I'm running the OME 885s (NO TOP PLATES) and Billy 5100s and I have a little over 3" up front. OP Get the UCAs
  10. Feb 5, 2011 at 2:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You got almost 3.5" lift right out of the box. Im still hoping they settle a little bit ;)
  11. Feb 5, 2011 at 6:03 PM
    virgilus11
    virgilus11 Well-Known Member
    kearny, nj
    09 sr5
    TRD supercharger,EMU 884 springs, 90000 shocks, air bags rear and TSB with EMU shocks, grillcraft mesh, Relentless front bumper,Armology rear bumper, byxenon hid's retro ,undercover lid with bike rack on top, Kenwood dnx9140,TRD cover seats
    Do you plan to add a heavy bumper and a winch ??? if not ???
    I just replace the Icon's with a set of 884 EMU and I still clear the 285 Revo's with a Relentless bumper.
    Are you planing to do some serious off road ?? If not are you looking just to fit some bigger tires ??? then 884 are not a bad choice and definitely more comfortable then the Icon's. But the will not take a winch.
    Few questions that you have to answer before you decide what is right for you.
  12. Feb 5, 2011 at 6:08 PM
    ColtsTRD
    Scott
    AZ
  13. Feb 5, 2011 at 6:11 PM
    Sprink669
    Sprink669 Well-Known Member
    I have the 886 coils and the rear Dakar leaf pack. Save your $$$ and for the time being use the factory UCA's. I do have a ARB bumper and winch. By the way are u a sprinkler fitter?
  14. Feb 5, 2011 at 6:20 PM
    ColtsTRD
    Scott
    AZ
    Well if he can't get his truck aligned he's gonna mess his tires up and it'll handle like shit...
  15. Feb 5, 2011 at 6:27 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    But he'll save $400
  16. Feb 5, 2011 at 6:29 PM
    ColtsTRD
    Scott
    AZ
    I hope your kidding OZ
  17. Feb 5, 2011 at 6:29 PM
    ColtsTRD
    Scott
    AZ
    actually your right...fuck it :woot:
  18. Feb 5, 2011 at 6:32 PM
    OZ-T
    Peter North
    British Columbia
    Of course
  19. Feb 5, 2011 at 6:33 PM
    ColtsTRD
    Scott
    AZ
    :D
    I just hate to see people make the same mistakes I did by trying to cut corners and save a buck...If I would've just done it right the 1st time I coulda saved myself some major headaches :eek:
    But what do we know right??
  20. Feb 5, 2011 at 6:39 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    Ha ha. Check out light racing uca
