OME lift plans
Discussion in 'Suspension' started by tac1uscg, Aug 10, 2010.
  1. Aug 10, 2010 at 11:31 AM
    tac1uscg
    tac1uscg [OP] Member
    connecticut
    08 doublecab sport
    OME 3 inch lift, Nitto Terra Grappler tires, Konig Countersteer offroad type x wheels, bed cover, grille guard w/ PIAA lights, Pioneer AVIC-X920BT head unit, Pioneer TS-A6993R front door speakers, JL C2-525x rear door speakers
    I'm Planning on getting a 3 inch OME lift with 17 inch ATX thugs and some terra grapplers.... Sound good? And what size tires would be best? Thanks guys.
  2. Aug 10, 2010 at 1:32 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    Yea I would go with 285s. Make sure you get 885 coils, or 886 if you plan on adding a bumper.
    I think you need 4.5 backspacing. Someone correct me if I'm wrong
  3. Aug 10, 2010 at 1:46 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah go with the 885's since you have the extra weight of a double cab. 886's if you are going to add an aftermarket bumper in the future so it can take the extra weight. I also have the Thugs but in 18"s instead of 17"s. I have 285's which come out to be around 32.65"s so almost 33"s but not quite. Backspacing should be 4.5"s or a -12mm offset.
