OME Lift Purchase.
Discussion in 'Suspension' started by 764mike, Jun 25, 2011.
  1. Jun 25, 2011 at 7:57 AM
    764mike
    764mike [OP] Well-Known Member
    NJ
    2008 Toyota Tacoma Double Cab
    Getting ready to order the OME lift with 885 coils and Dakar leafs for the rear. Is there anything extra I need to order before install to make life easier.
  2. Jun 25, 2011 at 9:15 AM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    From what a lot of folks have said is the stock shocks ride like shit with those, because they arent valved to handle such a stiff spring. I would look into some shocks as well, if you can afford it. Oh yeah, you might need longer u bolts. Unsure, though.
  3. Jun 25, 2011 at 9:34 AM
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2010 TRD Sport DC LB 4x4
    Work in progress, but installed so far; 265/70/17 Duratracs, Spidertrax, OME885X coils with OME lean spacer, OME N140S and N182 shocks, Wheeler's 1.5" 3 Leaf Progressive AAL (kept the overload), LR UCAs. TP14 spacers
    UCAs. Possibly extended brake lines and axel shims.
  4. Jun 25, 2011 at 9:43 AM
    swissrallyman
    swissrallyman Well-Known Member
    2017 Tacoma TRD Sport
    I'm assuming he is getting the complete lift, so it will come with OME shocks. I didnt need shims, they seem to be hit and miss. If you do need to install them later, you will need a new set of U-bolts and nuts, and a leafpack pin extender.
    Before you install the new front shocks, make sure to disconnect the upper controll arm, it will make it much easier.
    Rear brake lines are not needed, I fully flexed my rear end and they werent even tight, BUT I did install a home made rear brake line bracket extender to give you an extra half inch.
    I did the complete OME lift by myself without airtools or hoist in 4 hours, it is not very hard to do by yourself.
    TacoDaTugBoat likes this.
  5. Jun 25, 2011 at 9:47 AM
    764mike
    NJ
    I mean the complete OME lift with the 9000 shocks and 885 coils ordered through Wheelers. This is how its listed on their web page.
    Includes NitroCharger front and rear shocks, 885 front coil springs, Dakar rear leaf springs w/ bushings, front trim packer, driveline bearing drop kit and u-bolts! We include pieces that are normally overlooked by other dealers. Normally we'd supply 885 front coils but if you have another preference let us know. The price is the same regardless of which coils you choose.
  6. Jun 25, 2011 at 10:02 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
  7. Jun 25, 2011 at 10:06 AM
    neoflex
    neoflex Well-Known Member
    Does this lift give you a full 3"? I have been searching as I plan on doing 885s up front but the threads seem to conflict as some say it only gives you 2" while others claim 3".
  8. Jun 25, 2011 at 11:25 AM
    JonnyBb
    Arkansas
    Good point Oz. Super easy to do too.
    I got a little over 2.5" with just the 885s, but my stock suspension was pretty fresh (little/no sag due to age) when I put my lift on. And even though I went up less than 3" my alignment specs were shite. Putting LR UCAs on to get my caster back
  9. Jun 25, 2011 at 12:41 PM
    764mike
    NJ
  10. Jun 25, 2011 at 2:34 PM
    JonnyBb
    Arkansas
  11. Jun 25, 2011 at 6:16 PM
    Sprink669
    Sprink669 Well-Known Member
    For what is worth... I have OME 886 springs, Dakar leafs, I did get the full OME kit and I still needed to get (beefed taco's) carrier drop. I tried the OME one with 3* and then 2.5* all did not fix the drive line vibe at around 4-10 mph. Then for the alignment after 285/75/16's and it was way out of wack so onto Light Racing's control arms. Ok, back in alignment. With all of this extra expense I would have gone with the RCD lift.
  12. Jun 25, 2011 at 6:39 PM
    kieth
    kieth Well-Known Member
    British Columbia, Canada
    06 trd
    Full OME lift with Dakars, 886s and LR UCA's, Firestone air bags w\ onboard compressor, 2 kicker CVT 10" subs , MB Quart 1000w amp ,Alpine media player
    light racing UCA's for sure. oh and get 886s
  13. Jun 25, 2011 at 6:43 PM
    OZ-T
    Peter North
    British Columbia
    886's are not necessary unless you are planning on an aftermarket steel front bumper and winch
  14. Jun 25, 2011 at 7:20 PM
    BlueTaco07
    BlueTaco07 Super Mod!
    Cody
    Panama city, Florida
    Looking
    You will need money as in cash/credit card etc.
  15. Jun 25, 2011 at 7:28 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    A D29XL AAL.
  16. Jun 25, 2011 at 7:29 PM
    OZ-T
    Peter North
    British Columbia
    Have you installed your kit yet ?
  17. Jun 25, 2011 at 8:36 PM
    764mike
    NJ
    Not yet. Getting ready to order it soon.
  18. Jun 25, 2011 at 8:53 PM
    OZ-T
    Peter North
    British Columbia
    Understood OP
    I was actually asking crf69
  19. Aug 25, 2013 at 3:33 PM
    Code Gray
    Code Gray 200 years too late
    Nick
    Tampa, FL
    2011 MGM DCLB 4x4 Sport
    Limo tint, black low profile tool box, blacked out emblems, tailgate mod, black XD Addict rims with terra Grapplers, ionic 5" black railway step sides, weather tech mats and deflectors. OME 3" lift with 885s and dakars leaf packs, LED hood and bed lights from Mattgecko, back window bar from mattgecko, black headlight mod, LEDs kit for maps, dome and reverse lights, MrImYo Rear-View Mirror Lift, Red line hood struts, Grillcraft MX black mesh grill.
    Just installed my OME lift! I did alot of homework and im happy with the end look and ride. I added 885's, top plate spacers and the dakar leaf packs. Stock uca's and the allignment guy said it was good. Next time i'll try to remember to grab the spec print out. No diff drop.
  20. Jun 3, 2014 at 3:45 AM
    Spanman702
    Spanman702 Well-Known Member
    Shane
    Erie, PA
    Leer 800 cover
    Looks great I'm thinking of doing the same thing. 885 ome kit but with the aal on the back. How did it turn out with stock uca's and no diff drop?
