OME Lift Question for rear axle. searched already
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AgentSicker, Dec 27, 2012.
  1. Dec 27, 2012 at 10:32 AM
    AgentSicker
    AgentSicker [OP] Member
    Seattle,Wa
    ive decided to get the 3 inch OME lift for my 07' double cab tacoma. was wondering about the rear leaf setup. dakar leaf pack vs the add a leaf. does the dakar lift the rear higher than the add a leaf? just wondering if spending the extra money for the dakar leaf pack is worth it or not? is the ride quality different between the two? i have searched but have not found to many good answers on this topic. any help would be appreciated. thanks in advance
  2. Dec 27, 2012 at 10:34 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Dakars will get a DC on average , 2 1/2" of lift
    If you do not tow or haul , I would suggest a 3 leaf AAL instead
  3. Dec 27, 2012 at 10:36 AM
    OZ-T
    Peter North
    British Columbia
  4. Dec 27, 2012 at 12:09 PM
    AgentSicker
    Seattle,Wa
    thanks for the response. when you suggest a 3 leaf AAL, do you mean the OME option that adds one more leaf to my stock leaf springs or is it something else?
  5. Dec 27, 2012 at 2:37 PM
    OZ-T
    Peter North
    British Columbia
    No , not OME
    Wheelers has a 3 leaf AAL
  6. Dec 29, 2012 at 8:48 AM
    AgentSicker
    Seattle,Wa
    thanks for the help OZ-T. i am confused about one thing if you could help. wanting a 3 inch lift using the ome sport nitro shocks front and back with the ome 885 springs up front, the wheelers 3 Leaf AAL in the rear but it says only a 1.5" lift with the Wheelers 3 leaf AAL?
  7. Dec 29, 2012 at 9:00 AM
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2021 TRD Pro (upgrade from my 2nd gen)
    Work in progress, but mods so far; OTT 7.0 tune, 255/85/16 Falken WildPeak M/Ts
    3" refers only to the lift in front. The 1.5" lift in the rear will give you an almost level stance. If you want to retain the factory rake reconsider Daks.
  8. Dec 29, 2012 at 9:39 AM
    OZ-T
    Peter North
    British Columbia
    This
  9. Dec 29, 2012 at 11:48 AM
    DR Da_da
    DR Da_da Infrequent Member
    Alabama
    '06 4x4 V6 TRD Offroad auto access cab
    ToyTec ultimate lift, LR UCAs, TRD gen 1 CAI, TRD cat-back, bull bar, anytime fog lights, lighted 4x4 switch, factory SS step tubes, factory interior lighting package, factory VIP 3200 alarm, FJ TRD center caps, rear diff breather relocate, tint, bug deflector, Weather Tech liners
    With the Wheeler's progressive 3-leaf, is the 1.5" of lift achieved by leaving the stock overload leaf in? (It says they can be used with or without the overload . . . And why would you remove the overload leaves anyway?) Also, do they come with longer center pins in addition to the longer u-bolts?
    I'm thinking of replacing my ToyTec add-a-leaves with the progressives for a less harsh ride.
  10. Dec 30, 2012 at 8:26 AM
    JonnyBb
    Arkansas
    You will get 1.5" above where it sits now if you leave your overload in. If you take the overload out, you're height gain will be <1.5". Personally, I left mine in. You can use the stock centerpins if you aren't installing axel shims
